Old 09-25-2012, 09:57 PM   #1
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Question Checkvalve between brake booster and intake?
I am wondering if you guys running turbo set ups are running a non return valve or check valve between the intake manifold and the brake booster. Also on which hose did you hook up the bov? I can only see one hose that could be used for that purpose. Lastly, the second hose on top of the intake manifold going down on the back of the block on the passenger side, should this get a check valve as well?
Silverdub is offline   Reply With Quote
Old 09-26-2012, 06:50 AM   #2
d1ck
Drives: Black 2013 FRS
Most brake boosters have check valves built in so that you don't lose braking force if the engine should shut off.
d1ck is offline   Reply With Quote
cold air intake vs short ram intake ? tnt Engine, Exhaust, Transmission 5 02-02-2014 12:43 AM
So cold air intake or air intake? bcmakesiteasy Engine, Exhaust, Transmission 12 02-01-2014 08:06 PM
Best Booster Seat for FRS/BRZ Kimsey47 Cosmetic Modification (Interior/Exterior/Lighting) 0 06-07-2012 11:51 AM
Big Brake? Ladnerd Suspension | Chassis | Brakes -- Sponsored by 949 Racing 32 04-30-2012 07:32 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
