Old 09-24-2012, 10:51 PM   #1583
2forme
Originally Posted by cnk View Post
LOL. . nice. Now someone needs to get John a aFe Takeda unit to tune as well.
That's what I'm running right now. Going down to visit John on Thursday. Will have dynos galore.
2forme is offline
Old 09-24-2012, 10:55 PM   #1584
DSTL
Drives: 2013 BRZ Limited 6MT
I suggest starting off with the flash and drop-in filter first.
The exhaust gains aren't proven just yet and I haven't had the chance to test any out.
Don's Car showed 0 gain with his exhaust on 6 PSI.
That doens't mean his exhaust isn't good, just the stock exhaust isn't bad
From 8-19-12. John's no dummy! I'll personally still be getting some form of exhaust regardless though, just haven't seen / heard the right one for me yet. The smiles exhaust and intake sounds put on your face are worth far more than the small HP gains anyhow.
DSTL is offline
Old 09-24-2012, 11:03 PM   #1585
cnk
Drives: '13 DGM BRZ Limited
John - just a question regarding the base image that you're using for your tunes. With all the issues with CEL's going on I believe I recall seeing someone in this thread stating that they had gotten an updated ECU or flashed ECU that fixed their CEL issues. Are you using that new/flashed ECU image for your tunes or the original one?
cnk is offline
Old 09-24-2012, 11:21 PM   #1586
Visconti
Drives: 05 STi
Crawford yum!
Visconti is offline
Old 09-24-2012, 11:28 PM   #1587
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
3 14 mm bolts to remove that a/c
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline
Old 09-25-2012, 01:19 AM   #1588
gmookher
Originally Posted by DSTL View Post
Seems like a theme with this car, more confirmation that exhaust on top of a tune doesn't add much of anything. Not set in stone of course with limited data to this point, but makes sense with so many intake / exhaust mods on the stock tune showing a leaner afr. Thanks for all the hard work figuring this stuff out.
I'd like John to tune a Perrin headerback MT and see what happens @PERRIN_Chris @PERRIN_Jeff you may wanna see about setting john up with some of your headerback catted vs catless gear, to sell, tune and help those east coast folks out. I'm interested in the visconti tune-for perrin.
gmookher is offline
Old 09-25-2012, 01:43 AM   #1589
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
They might, but then again, they might not. They also are EcuTek licensed dealers, and may not want to cut into their own profits.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline
Old 09-25-2012, 01:49 AM   #1590
twinturba
Drives: 86
+1
Just got my car back from the dealer who reflashed my ecu to correct the cel issue. Is this going to affect our Visconti tunes?
Current:'15 Prius V, '14 GLK bluetec, '04 Taco, '00 E320, '51 Merc
Past:''13 FR-S, '06 SLK55, '01 M5, '11 ML Bluetec, '06 S500, '05 Elise, '98 Gs400 Spectra Blue, '94 Supra TT, '89 5.0 GT, '87 ASC Mclaren, '87 5.0 GT, '84 conv 5.0 LX, '70 Coronet 440
Bayareatwostroke
twinturba is offline
Old 09-25-2012, 03:00 AM   #1591
DSTL
Originally Posted by Opposed View Post
Do you mean, that bolt-ons such as exhaust and intakes only add power due to its natural ability to lean out the stock map? And that when tuned, this is already being addressed by the tune itself? So on stock ECU, intake and exhaust add X amount of power. But once tuned, those same mods bolted up do not add anything? That would in theory indicate that the stock exhaust and intake may not be as restrictive as perceived. This kind of would make sense. But during Perrin's testing, they were still able to improve the torque dip and power by adding intake and exhaust on top of the Ecutek tune. One would think that all mods should work together. This is all interesting stuff. I can't wait to see more results once finished.
Ugh just had a long reply almost done and my phone died. Don't have it in me to type it again this late. Yes thats exactly what I've been seeing so far but there's not all that much data yet. Been waiting for what John's doing now and excited to see final results, wish I had the means to do it myself or help out. Interesting stuff for sure.
DSTL is offline
Old 09-25-2012, 09:46 AM   #1592
Visconti
Drives: 05 STi
I need more time but ill get it done
I have dynosheets I need to put together
Originally Posted by twinturba View Post
+1
Did you have a flash before?
We did it with out
Not yet
Visconti is offline
Old 09-25-2012, 10:15 AM   #1593
tonystewart
John, you didn't remove the a/c? Oh you are good!
Old 09-25-2012, 12:11 PM   #1594
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
I hope you get some power out of that intake...considering I own it and I have your flash to do still haha
SkAsphalt is offline
Old 09-25-2012, 07:56 PM   #1595
Visconti
Drives: 05 STi
Anyone that does not have my updated 6 Speed Pumpgas map please speak right now !!!
Couldn't find any power with the intake.
Visconti is offline
Old 09-25-2012, 08:00 PM   #1596
xjohnx
Grip>Slip
xjohnx's Avatar
1.06b9 is the latest, correct?
xjohnx is offline
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 02:05 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 07:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) — General Topics 130 09-01-2011 01:42 PM
