#57 |
Drives: really slow...
Also, Let's say I decide to rotate tires later...does anyone know if the instrument cluster display differentiates between which one is Front Right vs. Rear Left OR does it just tell you that one tire is low on air?
I ask because my previous car reported each tire's status but in the BRZ I only see one simple warning indicator light. |
#58 | |
SLO NO MO
| The Following User Says Thank You to Foobar For This Useful Post: | RYU (09-18-2012) |
#59 | |
Drives: '13 GBS Subaru BRZ
#60 |
Drives: Scion FRS Ht Lva(AT)
Some of the big questions that remain unanswered which make this discussion confusing:
1) Are the TPMS sensors required by your country/state/province if the system is present on your car? If they are then you better have them since there may be liability associated with not using the system if you have an accident related to tire under inflation. Remember the FRS/BRZ records events! As an example Transport Canada says this: http://www.tc.gc.ca/eng/roadsafety/roadsafety-1158.htm Another reference: http://www.albertagasprices.com/blog...stid=229&ign=2 Note the reference to ensure periodic pressure checks regardless of whether you have TPMS or not! 2) If they are not required then what happens if one chooses to install tires without them? From what I have heard it depends on the car. Some cars have a light and some a chime and a light. It appears the FRS/BRZ may only have a light? Can anyone confirm this? There seems to be some debate as to what sets it off, how long it is on, will it reset in the proximity of the TPMS equipped tires, regardless of whether they are in motion. All this may be dependent on what type of TPMS we have? Hopefully someone can clarify this? 3) If the system does not see TPMS sensors because there are none there, or none that are recognized then is anything else other than the light on the dash impacted? This seems to be an important question, but the suggestion appears to be that not having them only impacts the light on the FRS/BRZ. 4) If you need, should have, or would like a set on another set of wheels either summer or winter, then what is required to keep things working properly? Some have suggested that the dealer will of course reprogam(for a fee) for you when you seasonally change your tires? There is also suggestion that with the right (extra cost)tool you can reprogram yourself? Is the FRS/BRZ system self learning? What I find particularly frustrating is that we have a different and particular system in play that may provide a relevent safety contribution, but little useful information on how to cope with it! If you want to go for having no TPMS on your 2nd set of tires then it would be nice to know exactly what to expect(solid light, flashing light, bells & whistles, sometimes, all the time etc. etc.) So perhaps some clear information to the relevent questions would help to clarify all the speculation! cheers
#61 |
If we could simply not run them without the warning light being triggered that is perfect IMHO. I need to figure out how to address ASAP since I plan to buy winter tires soon...
| The Following User Says Thank You to Captain Insano For This Useful Post: | ngabdala (09-19-2012) |
#62 |
TPMS Followup additional info
What I found or was told
- Described as a conventional 4 sensor system -No 2nd tire Switch( so system will only hold one code) - No initialization(reset switch) - broadcasts every 90 seconds when vehicle is stationary - broadcasts every 15 seconds when vehicle is motion as determined by G sensors inside the TPMS sensor assembly. -TPMS receiver is combined with the door control receiver in a single ECU which is located under the back shelf. - TPMS Sensors have batteries in them so when the battery dies the sensor has to be replaced. Battery life expentancy is ~ 5years! Dealership suggests they have not replaced any since first introduced in 2004 - Sensors need to be reprogrammed everytime you change from winter to summer as FRS computer only holds one set of codes. So $/year at dealership/tire store? Invest in tool for DIY? Apparantly some cars can hold 2 codes, but not the FRS. Check for local government requirements: - Not required for Canada/Alberta - For Canada go here and click on horizontal arrows for details: http://www.tc.gc.ca/eng/roadsafety/roadsafety-1158.htm - For Alberta see page 41 of this PDF: http://www.transportation.alberta.ca...ualdec2009.pdf The first PDF recommends regular tire pressure checks regardless of whether you have TPMS or not! - TPMS Sensors appear to be mandatory in the U.S. !!!Check your local requirements!!! What can you expect to happen if you use tires/wheels without TPMS 1) you will not have an automated system monitoring tire pressure, check pressures manually. 2) TPMS dash light will glow all the time, or most of the time 3) Your TPMS dash light may turn off when your car is in the garage if close enough to your stored tires with TPMS sensors installed. 4) no other vehicle functions are impaired/enabled by presence of TPMS or not |
| The Following 7 Users Say Thank You to smbrm For This Useful Post: | Captain Insano (09-20-2012), Imperius (02-03-2017), Khyron686 (09-25-2012), mrjester (05-18-2013), RYU (09-20-2012), tinger00 (10-02-2012), Touge Monster (01-28-2013) |
#63 |
Outstanding. If I switch tires or wheels I'lll just live with the yellow light. No problem.... No emissions or vehicle checks where I live.
#64 |
Drives: 2013 Subaru BRZ
Just to confirm again, the dash light DOES turn OFF when your car is near the stored tires with TPMS sensors installed, after the car is on for 1 minute. The light will then stay OFF until you drive approximately 20 miles...not 100% sure of the distance required for it to come back on.
#65 |
Photo Specialist
Drives: 2013 Toyota 86 DGM 6MT
Had my TPMS transferred to my new wheels. Pictures for those who are interested. Unfortunately I don't think they print part numbers on the units themselves
![]() 20120921-TC105N_Z1StarSpec-14 by VictorN07, on Flickr ![]() 20120921-TC105N_Z1StarSpec-15 by VictorN07, on Flickr |
| The Following 5 Users Say Thank You to F1point4 For This Useful Post: | Ammunition (10-17-2015), Captain Insano (09-25-2012), dsgerbc (09-25-2012), HyperTech (12-06-2015), Imperius (02-03-2017) |
#66 |
I plan on having mine swapped into my new wheels from my stockers. I have had this done on all my cars without issues.
The only thing is it lowers the value of the stockers on the resale market. |
#67 | |
Drives: BRZ(sold), STI
I have been following some ebay auctions on these lately, so if you need a set soon - linked auction is an okay price. If you wait, you can get a set for under $80-$90. |
#68 | |
Photo Specialist
#69 | |
| The Following User Says Thank You to dsgerbc For This Useful Post: | F1point4 (09-25-2012) |
#70 |
USMC Veteran Semper Fi
Drives: 2010 WR Blue STi
I just sent VDO a product inquiry about the FRS/BRZ/GT86 I would rather buy these at 26-35 dollars each.
| The Following User Says Thank You to Spartan65 For This Useful Post: | civicdrivr (09-25-2012) |
| TPMS Sensors.. | Dave-ROR | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 31 | 04-08-2014 01:22 PM |
| Subaru TPMS Nonsense | Grimlock | BRZ First-Gen (2012+) General Topics | 67 | 10-07-2013 03:15 PM |
| TPMS Sensors | ashtray | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 78 | 05-24-2013 04:24 PM |
| Auto Parking Sensors? | Swancoat | Scion FR-S / Toyota 86 GT86 General Forum | 84 | 02-18-2012 02:01 AM |
