Old 09-22-2012, 08:25 AM   #1
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Ghetto-Fabulous "FilterMag"
I recently had some computer hard disk drives die on me, and which were also out of warranty.
Had a nifty idea of taking apart the hard drives to get the rare earth magnets out of the hard drive and put them on the side of my 130 Subi oil filter.
The magnets are fairly strong, if stuck to the side of a fridge or metal wall you would need a screwdriver to pry them off, or at least slide the magnet off the object.
I've only stuck the magnets to the side to see how they go, so far so good - they haven't fallen off. But I am thinking of getting something to secure them down with, just in case. Probably will check out a leather dog collar for them. They magnets get very very hot after a drive.
Might be a cheap/free alternative for those guys who don't wanna shell out the 30 odd for a SS 300 Filtermag.
stevo_12v is offline   Reply With Quote
The Following 2 Users Say Thank You to stevo_12v For This Useful Post:
Anthony (07-24-2013), LXXXV1 (05-01-2014)
Old 09-22-2012, 08:40 AM   #2
ft86Fan
ft86Fan's Avatar
Drives: FR-S, Exige S, Miata
Good thinking but I'm not sure how well it will work since its not wrapped around the filter. It might just be added weight to the car.
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield
'95 Miata (Montego Blue)
ft86Fan is offline   Reply With Quote
Old 09-22-2012, 10:24 AM   #3
LivingLegend
Drives: 1994 Toyota Tercel
I don't think the magnets are heavy enough to actually be worried about the extra weight.
LivingLegend is offline   Reply With Quote
Old 09-22-2012, 12:58 PM   #4
xn7485
Drives: 1995 Acura Integra GS-R
I'd say add a zip tie or two to secure it. Anything more would trap heat. I don't know thermal limits for magnets, but less heat is better for sure.
xn7485 is offline   Reply With Quote
The Following User Says Thank You to xn7485 For This Useful Post:
stevo_12v (09-24-2012)
Old 09-22-2012, 01:26 PM   #5
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
What the ? ? You have all of these top notch TRD JDM parts on your car and you bolt up some homemade magnets?
Beyer Subaru is offline   Reply With Quote
The Following 2 Users Say Thank You to Beyer Subaru For This Useful Post:
20valvewynn83 (10-01-2012), Anthony (07-24-2013)
Old 09-22-2012, 01:40 PM   #6
ahausheer
Re-member
Drives: Toyota camry
First off, those magnets despite being stronger than hell may loose a significant amount of their magnetic strength when heated slightly, not all magnets are equal in this respect. Second, they are going to hold stuff that is already going to be held by the filter. They are like a jail inside a jail, they don't do anything. If you want to use magnets effectively you need to capture material before it gets circulated through the oil pump and filter, ie, you need to capture it in the oil pan. Get a magnetized oil drain plug or put heat stable magnets in the oil pan itself. Also keep in mind most of the metal components are not ferrous. I like your thinking and creativity but I dont think this application is all that effective.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
The Following User Says Thank You to ahausheer For This Useful Post:
Huehuecoyotl (03-25-2013)
Old 09-24-2012, 09:28 AM   #7
Hix
Hix's Avatar
Drives: 2017 WRB PP
Do people not realize that a HDD gets super fucking hot. These magnets were chosen for their extreme strength and durability when heated. Do you know how precise a HDD is? These are much better than some magnet sleeve. I am not sure what people think makes those magnets are to make them so special because they are not. Also they are ounces of weight, the shirt on your back weighs more.
Hix is offline   Reply With Quote
The Following 2 Users Say Thank You to Hix For This Useful Post:
Fett4Real (07-24-2013), stevo_12v (09-24-2012)
Old 09-24-2012, 09:35 AM   #8
zooki
Drives: waiting on a 2021...
OK, I haven't seen it yet, so I'll be "that guy"...
ahem....
what's the weight? Where are the dyno charts? Can I get them with an "86" engraved on them?
LOL
zooki is offline   Reply With Quote
The Following 2 Users Say Thank You to zooki For This Useful Post:
Anthony (07-24-2013), Ash (10-28-2012)
Old 09-24-2012, 10:00 AM   #9
stevo_12v
Update: I picked up a leather dog collar yesterday at the local pet store.
They only had purple :/ I was hoping for a black one
Anyway, looks like they are secured nicely.
@ahausheer: thanks for the idea of magnets on the sump. I will use the other 3 magnets I have and attach them to the bottom near my fumoto, then maybe use a magnetic pickup in the oil sump to get the rest of them.
@zooki: I should put a TRD sticker on the side of the leather belt, hmmm that would melt off. I could sharpie TRD on it instead
The Following 3 Users Say Thank You to stevo_12v For This Useful Post:
Anthony (07-24-2013), BRZranger (09-24-2012), Slobmw (03-25-2013)
Old 09-24-2012, 10:13 AM   #10
n2oinferno
Praise Helix!
n2oinferno's Avatar
Haha this is one of the most ghetto mods ever. And I love it!
The Following 4 Users Say Thank You to n2oinferno For This Useful Post:
Anthony (07-24-2013), ftc~brz (04-10-2013), radroach (07-19-2013), stevo_12v (09-24-2012)
Old 09-24-2012, 10:23 AM   #11
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
From what i have seen, there is very very little ferrous materials in the construction of this engine.. LOTS of alloy, still have yet to invent that non-ferrous magnet.
Most if not all of the metals will catch in the filter anyway (hence why it's designed to 'filter' the oil..)
HKS use a magnet in their filter.. charge you a fortune.. good marketing don't buy one.
Take the collar off, take off the magnets and use them to clamp your missus's nipples..
Something something butter..
www.vic86brzclub.com
fuddbutter is offline   Reply With Quote
Old 09-24-2012, 11:09 AM   #12
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Now THAT one is super ghetto-fabulous!!
Old 09-24-2012, 11:12 AM   #13
n2oinferno
Praise Helix!
n2oinferno's Avatar
Ugh, I imagine that would hurt so bad. Last time I took apart a hdd, the magnets were able to hold when placed on either side of my hand. Then I slipped and pinched my finger between the edges of two of them and it ripped it right open.
Those things don't play around.
Old 09-24-2012, 01:09 PM   #14
serial gixxer
This car deserves a spiked collar.
serial gixxer is offline   Reply With Quote
The Following User Says Thank You to serial gixxer For This Useful Post:
Rear Deck "popping/clicking/tapping/ticking" noise. Sigh-on-Rice Issues | Warranty | Recalls / TSB 637 04-28-2020 04:55 AM
Odometer Functions - "S" & "G" What are they? kablammo BRZ First-Gen (2012+) — General Topics 59 12-01-2013 12:28 AM
Subaru BRZ Prototype First Drive Review: "Off the Chart" (Motor Trend) Hachiroku BRZ First-Gen (2012+) — General Topics 67 11-09-2011 05:58 PM
