Old 09-23-2012, 11:08 AM   #57
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Originally Posted by VSGTS14 View Post
30 psi? not even sti's run 30 psi.
maybe 20-23 on 93.
They are running 20psi on the stock engine at 12.5:1 compression. 30psi at 10.5:1 seems very likely at this point.
And for hilarity's sake; an older post of mine before Don & Friends started to push the stock engine:
Originally Posted by Draco-REX View Post
I would't be surprised to see 14lbs boost or more with those pistons.
Talk about under-estimating. 20lbs on the stock internals is mind-blowing.
Old 09-24-2012, 12:32 AM   #58
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
Agreed.
Absolutely.
Were in the same boat, and that boat should be called
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline   Reply With Quote
Old 10-05-2012, 05:09 AM   #59
Tradewind
Drives: 2006 Subaru Liberty EZ30 S/charged
Stock rods and pistons in the FA will do me all day long, total waste of time putting in untested aftermarket stuff for 15psi boost
Love your work Subaru! You finally sorted the flat 4 to be legendary flat 4
Toyota 86 test driver
Tradewind is offline   Reply With Quote
Accelerated Performance FRS/BRZ-300 Turbo Kit Don@Accelerated Forced Induction 104 11-26-2012 03:55 AM
Turbo BRZ from Accelerated performance buzznasa BRZ First-Gen (2012+) — General Topics 3 07-20-2012 11:14 AM
