Old 09-21-2012, 02:19 AM   #15
FrsSwag
Drives: Frs,civic
Nice.
FrsSwag is offline   Reply With Quote
Old 09-21-2012, 02:29 AM   #16
Tim_Asphalt_FRS
Is it fast? No.
Tim_Asphalt_FRS's Avatar
Drives: 2013 Scion FR-S Manual-Asphalt
Originally Posted by kmbkk View Post
I think it would be cool to use the side marker as the turn signal and convert the turn signal housings into fog lights somehow.
I bought these...
http://www.v-leds.com/Vehicle-Specif...-p9809064.html
They work perfect. Kinda makes them look like fog lights while driving, but they still blink amber.
2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars}
[Wanted: Delicious Stg 2 tune, Bilstein struts]
Tim_Asphalt_FRS is offline   Reply With Quote
Old 09-21-2012, 12:35 PM   #17
djdnz
1337
Drives: 2013 BRZ WRB S/C
Is there any way to wire it so they blink at the same time?
djdnz is offline   Reply With Quote
Old 09-22-2012, 08:50 PM   #18
xcelir8brz
Drives: 2013 BRZ Limited
Mine blink at same time.
xcelir8brz is offline   Reply With Quote
Old 10-05-2012, 01:28 AM   #19
psk
Drives: scion fr-s
i just ordered a pair of nokya hyper yellow bulbs to replace the turn signals to give it a faux fog light look. i'll see how that goes when they get in.
psk is offline   Reply With Quote
Old 10-05-2012, 02:00 AM   #20
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
- The Ancient BRZ Sacrament
by Zaku
Old 03-29-2013, 10:22 PM   #21
cmspooner
cmspooner's Avatar
Drives: 2013 SWP Limited BRZ - Manual
Does anybody think this will work with LEDs in the side markers? I know people had issues with rapid blinking when moving to LED turn signals. Am I right to believe that this would not be the case if the you piggyback the LED side marker off of an incandescent turn signal? Is there something I am missing in relation to line voltages/currents on LED bulbs that will cause problems?
cmspooner is offline   Reply With Quote
Old 04-01-2013, 09:20 AM   #22
cmspooner
cmspooner's Avatar
No info?
The Following User Says Thank You to cmspooner For This Useful Post:
Kids Heart (10-17-2013)
Old 04-04-2013, 12:42 AM   #23
boonFRS
Drives: 2013 Scion FRS whiteout
Originally Posted by cmspooner View Post
No info?
I'm not an light expert but from what I read, you can use led but it cause hyper flashing. Last I check which is about 4 month ago, a few vendors on here were selling led bulbs with built in relays(?) to prevent the bulb from hyper flashing.
I have yet to change mine out for led so I can't help you there.
boonFRS is offline   Reply With Quote
Old 04-05-2013, 12:41 PM   #24
Yruyur
Yruyur's Avatar
If you get hyper blinking just replace the turn signal flasher relay that has the resistance built in. This will prevent any hyper blinking and only requires one thing to be installed.
Ill be doing this mod today. Thanks for the DIY.
Old 04-06-2013, 12:33 PM   #25
psk
Drives: scion fr-s
any way to keep the side marker bulbs off until initiating the turn signal?
Old 04-06-2013, 01:29 PM   #26
Yruyur
Yruyur's Avatar
They should be off if you are only hooking up to the blink circuit.
Old 04-06-2013, 06:11 PM   #27
psk
Drives: scion fr-s
which is exactly the blink circuit? red or green?
Old 04-06-2013, 06:54 PM   #28
Yruyur
Yruyur's Avatar
Not sure. Grab a volt meter and see wuich one it is and let us know.
clear side marker part number NOBROWS Cosmetic Modification (Interior/Exterior/Lighting) 34 09-11-2017 09:12 PM
**Toyota 86 Fog Light Bezels $34.9, 86 Arm Rest, GT86 Badge, Fog Light Set for $112.9 nigel-jdmparts Exterior Parts - The Rest 524 02-28-2016 10:24 AM
Converting side marker to turn signals ayau Cosmetic Modification (Interior/Exterior/Lighting) 30 12-13-2015 03:41 PM
does your car come with side door marker light? excited86 CANADA 12 08-02-2012 06:07 PM
Raven blacked out side marker before and after Roadstercycle FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 06-24-2012 10:52 PM
