Old 09-21-2012, 11:45 PM   #1
karbon
Drives: DGM BRZ
Snow mode = more fuel efficient?
In the auto, Snow mode makes it so that the lowest gear you can access in either D or M mode is 2nd. Many luxury cars start in 2nd gear from a stop. For cruising, lately I've been putting snow mode on for what I think would be improved fuel efficiency.
What do you guys think?
Does this make sense? Am I harming the car in any way by neglecting 1st?
karbon is offline   Reply With Quote
Old 09-22-2012, 12:11 AM   #2
ahausheer
Re-member
Drives: Toyota camry
What luxury cars start in second and what do they do with first?
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 09-22-2012, 12:31 AM   #3
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 09-22-2012, 12:42 AM   #4
karbon
Drives: DGM BRZ
BMWs, for one. I think some Lexus models do it too.
http://www.e90post.com/forums/showthread.php?t=382455
Old 09-22-2012, 09:36 AM   #5
Turbowned
Turbowned's Avatar
I feel like I've heard about Prius owners doing this... I don't think I'd want to start in second, rather just go easy on the gas pedal from a stand-still.
Old 09-22-2012, 10:17 AM   #6
Zaggeron
Zaggeron's Avatar
Drives: '13 BRZ Limited '10 370ZR
If you redline it before every shift, starting in 2nd might save you some gas -- of course if you are doing that you likely are not concerned about gas.
But, if you normally short shift to 2nd anyway right after you get going, then the gas savings are likely very minimal and certainly not worth whatever strain you'll be putting on the transmission by being in the wrong gear. Just leave it in auto mode, the car will pick the best gear and you'll probably get the best gas mileage that way
2013 GBS Subaru BRZ Limited 6MT
2010 PG 370z Roadster: Sport/Touring 6MT
Zaggeron is offline   Reply With Quote
Old 09-22-2012, 05:51 PM   #7
serialk11r
Drives: '06 AM V8V Coupe
Prii don't have gears, they're effectively continuously variable.
Anyways, no starting in second is not going to save gas because now you're unlocking your torque converter in 2nd which needs more engine torque to start, and the more torque the torque converter transmits through fluid coupling the greater the "slip" and the more energy you lose.
If you want to save gas, get out of first sooner by pulling the upshift paddle, accelerate normally/quickly, then shift to the highest gear possible or let the auto tranny take care of that for you, since the car locks the torque converter in 2nd gear and up. If you don't want to deal with the paddle shifting, press lightly on the gas when you're starting from a dead stop.
Wasting gas is using more power than you need (and then slowing down), driving around with unlocked torque converter, or being light on the throttle in a lower gear than you need.
The Following User Says Thank You to serialk11r For This Useful Post:
Rawhyde (09-22-2012)
Old 09-22-2012, 07:13 PM   #8
GNS
Drives: .
Sounds like you're putting unnecessary strain on the transmission for minimal gain in fuel efficiency. I wouldn't do it.
GNS is offline   Reply With Quote
Old 09-22-2012, 08:22 PM   #9
fatoni
how does that put more strain on the transmission?
Old 09-22-2012, 10:08 PM   #10
serialk11r
It doesn't.
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
snow mode = girlfriend mode? Nepenthe Scion FR-S / Toyota 86 GT86 General Forum 9 07-01-2012 03:02 PM
sport mode... pr086 Scion FR-S / Toyota 86 GT86 General Forum 6 06-01-2012 11:50 AM
Tailgating is safer and more efficient: Volvo Want.FR-S Other Vehicles & General Automotive Discussions 3 04-25-2012 11:22 PM
