#85 |
Drives: SWP BRZ
I wish they would of learned from the older BMW and put a thread behind the petal so you could use on of these.
http://store.uucmotorwerks.com/share...ts.asp&x=0&y=0 It makes doing this adjustment a 5 second job. |
#86 |
Drives: Whiteout FR-S
Would this be something i can just take it to the dealership and have them adjust it, under warranty ?
#87 |
Drives: FR-S, Exige S, Miata
I don't think so. Its not a defect with the car.
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield '95 Miata (Montego Blue) |
#88 |
#89 |
Trident Motorsports Owner
Drives: DGM. DD for my EvoX
mine is about a mm or 2 above the brake and it is perfect for me. I'm not worried about clutch wear and it made it to where the engagement is a lot closer than stock.
previous cars:1998 chevy s10 2001 Prelude SH 1992 (JDM)RX7 FD Current Cars:2010 Mitsubushi Evo X GSR 2013 Subaru BRZ Sponsors:Mishimoto/Flossy/Tomei
Craig.tridentms@gmail.com |
#90 | |
Drives: 2013 BRZ Limited SWP
You can try. My dealership at the time didn't even know how to do it. I told them to forget it. It took me all of 5 minutes. I would just try lowering it a little- you'll find even moving it a little is a big improvement with clutch engagement.
Past Subarus: 08 STI, 05 Legacy GT, 98 Legacy L wagon, 97 SVX LSi
Daily Driver: 2013 Acura MDX |
#91 | |
Drives: 2013 Whiteout MT Scion FR-S
Do it yourself, it cannot be easier: Loosen one nut, rotate rod (one turn at a time), re-tighten nut, Drive and see how your like the adjustment. Like many of us here agree, adjust your clutch pedal down to the same level as your brake pedal. Adjusting the clutch yourself gives you the ability to dial in what feels "right" to you, especially when the smallest of adjustment can affect the engagement point. |
| The Following User Says Thank You to TennisHsu For This Useful Post: | alrashwa (09-22-2012) |
#92 | |
Drives: 2013 Scion FRS MT / Argento
http://www.nicoclub.com/archives/how...ssan-370z.html |
| The Following User Says Thank You to smokeyFRS For This Useful Post: | ft86Fan (09-22-2012) |
#93 |
Drives: 2013 Firestorm FRS, 97 BMW M3
Just finished doing this a few minutes ago, only did the forward reverse testing but seems like I'm going to like this positioning a lot more. Note: I did have to use some pliers to be able to turn the threaded rod even with removing pedal pressure.
Thanks for the DIY! |
#94 | |||
Drives: '04 350Z/ 2013 LR BRZ (LM)
I do like to tackle each challenge on my own -- its just that much more satisfying in the end. Quote:
I know this may sound like one of those "beat a dead horse" -- but if anyone can manage to post a quick Youtube/ vid (even if its just a short clip) -- it would be greatly appreciated. I'll send some change for a few Brews :happy0180: |
#95 | |
[ame="http://www.youtube.com/watch?v=1EkJKjfIQ9A"]How to Adjust the Clutch on a Dodge Stealth or Mitsubishi 3000GT Non-Turbo: HD Video Tutorial - YouTube[/ame]
| The Following 4 Users Say Thank You to smokeyFRS For This Useful Post: |
#96 |
#97 |
#98 |
Drives: 2013 Scion Frs(Scarlet)
Finally adjusted it and it feels alot better..i thought the clutch wud feel a little tighter but the engagement is so mcuh better
| Tags |
| clutch adjustment, clutch helper spring |
| power steering feel adjustment | brillo | Engine, Exhaust, Transmission | 29 | 11-06-2017 03:41 PM |
| BRZ front camber adjustment confirmed | sparks | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 03-28-2013 10:17 PM |
| Any (easy) way to stiffen up the feel of the clutch? | Partial Stall | Engine, Exhaust, Transmission | 41 | 07-19-2012 02:17 PM |
| My Great Experience at Scion of Glendora *LONG, BUT AN EASY READ* | wanger | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 06-02-2012 01:41 PM |
| ATS carbon clutch collaboration model prototype clutch 86 & BRZ | kanundrum | Engine, Exhaust, Transmission | 41 | 02-27-2012 03:48 PM |
