Old 09-21-2012, 12:00 PM   #29
UncleFester
Originally Posted by mla163 View Post
It's not switching the map that's the issue. It's switching a tank from gas to E85 that is super inconvenient. You'd have to arrive at the event on fumes. Then fill it up with E85 from a can. Or you could run on E85 all the time, but even around DC, the stations are few and far between.
I'm OK with it being legal - it is technically "pump gas". I just hope that it is not a necessary modification for this car in STX.
edit - read your post again. Either way, having multiple fuels is a PITA.
FYI there are eight E85 stations within the beltway around DC.
http://e85vehicles.com/e85-stations.html is a good site to reference local stations.
Guys/Gals, no one is holding a gun to your head and making you run E85. If it bothers you that much, stick with CS or RTR. Besides autocross is a driver's sport, not a who has the most mods and/or horsepower contest.
Back on topic, I'm happy with their decision. It will be refreshing competing in STX next season.
UncleFester is offline   Reply With Quote
Old 09-21-2012, 12:00 PM   #30
Mitch
form follows function
Drives: RIP '13 BRZ
Originally Posted by TouchMyHonda View Post
confused.
What about?
Mitch is offline   Reply With Quote
Old 09-21-2012, 12:10 PM   #31
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
STX is good news!!! My GTI was STX prep even though I'd get toasted by RX-8 and WRX it is a fun class!
I also have the lack of E85 availability. Back when I lived in Michigan it was like E85 grew on trees (or maybe in the ground?!?!).
Old 09-21-2012, 01:08 PM   #32
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Originally Posted by jix87 View Post
The subject of this thread is STX, for which an E85 tune is legal.
The Visconti E85 tune made 187/147 on an otherwise bone stock car. I think over 200whp is very realistic. Torque will be hard to come by though, so the 325 will probably keep its advantage there but not by much.
DoH!
I had a thread on RTR/CS open also and my mind was there. My bad
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 09-21-2012, 01:09 PM   #33
Racecomp Engineering
STX is great news. Next year should be interesting!
- Andrew
Old 09-21-2012, 01:17 PM   #34
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
Originally Posted by ABQautoxer View Post
Thats the problem here. There is literally two pumps in this northern half our state. It doesn't really make it a realistic option for a street car. It's a moot point.
I'm curious to see if those large E85 gains are safe for autox and common numbers or an extreme example.
As long as the drivetrain will take it, there should be no reason the motor cant dish it reliably.
Excited to see the conclusion was not to "oversell" the potential of the car. It would have been an infuriating first few years being backmarkers in STU or STR.
And side note: Give me SP or give me death!!
well.... not really death, but I'm pining at the possibilities of this thing in SP... I assume it will be inevitable that the 2013s will benefit from the ud/bd rules as the so called "special editions" and STi versions are released.
Sccabrz192 is offline   Reply With Quote
Old 09-21-2012, 01:21 PM   #35
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
I just meant are the numbers of the E85 tune a dyno queen type number or one that nearly everyone will be able to hit.
TomR
ABQautoxer is offline   Reply With Quote
Old 09-21-2012, 01:25 PM   #36
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
BTW...congrats on your good finish at Nats..... and your right... Steam rollers have become way out of my budget...however I could see some 275's x 16 on this things and some OMG Engine mods...'might' make it competitive in SP... CSP??? guess we'll see..
Scooby South is offline   Reply With Quote
Old 09-21-2012, 01:25 PM   #37
Sam Strano
Sam Strano's Avatar
Drives: 2013 FR-S Asphalt
Originally Posted by apexaddict View Post
Unfortunately, if it wasn't in this month's Fastrack, then we have to wait until at least 2014 for the CS switcheroo to take effect.
Kind of a bummer actually, because CS has been hurting for numbers since the trunk kit cars arrived. Leaving them there and classing the FRS/BRZ in STX is only going to continue that trend as STX is now unquestionably the best class to run the car in.
Two things happened here. I think one or two FRZ's showed up for CS, which isn't a great showing. The 370Z won one course too and was in the mix. Which makes it a hard argument to move the others... especially if no new cars show up in numbers.
That said, remember these cars are hundreds of pounds less than the 370Z, I'm sure that would have helped on the West course, but the 370 would have still been the car on the East. I don't know guys... I still think this thing has a shot at the Z0K/MSR bunch just looking at the numbers.
Sam Strano is offline   Reply With Quote
The Following User Says Thank You to Sam Strano For This Useful Post:
Scooby South (09-21-2012)
Old 09-21-2012, 01:29 PM   #38
Scooby South
Conedancer
^^^ Agreed..
Old 09-21-2012, 01:58 PM   #39
apexaddict
It's not really that clear cut... even if you arrive at the event on fumes, you still aren't going to be on pure E85. You need to go through at least a tank of the stuff to ensure that what you're putting in is actually E85, or E70, or whatever it's tuned for.
Here's what I did when I had my STU Evo (I had map switching for 93 and E85):
- Run the car to fumes a couple days before the event, fill up on E85, switch map
- Top up the E85 in the tank the night before an event, and also fill two 5-gallon jugs
- Drive to event, run, fill as needed
- Put 93 in the car on the way back home if needed, or when I run out a day or two later.
It's inconvenient but not horribly so. The tougher part is making sure you're consistent with your ethanol mix. My E85 tune was pretty conservative so I could run as low as E50 without issues... a real aggressive tune that DEMANDS a perfect E85 mix is definitely going to be a PITA, though.
Andrew P.
#14 STX Scion FR-S - powered by Stranoparts and Moto-East
apexaddict is offline   Reply With Quote
Old 09-21-2012, 02:16 PM   #40
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Thanks Bill! I'm very pleased with the result, I hit my goal and I knew I left a good amount of time on course... so bonus!
I think CSP will be murder... NA Miatas with NB engines are just too epic... they ran significantly faster than ASP on both courses at nationals this year, and that is pretty typical in general.
I could see it being a competitive BSP car, it'll likely be the lightest car in the class at the rule limit and with some rolled fenders, should be able to fit some good sized meat. Engine wise I wouldn't expect to make a whole lot more than ST trim, the only real difference being the ability to gut all the emissions.
I am really happy to see this thing go to STX, if eventually I want to do a somewhat still streetable prep level between stock and going SP, I can still run competitively... though I don't know if I particularly would be... I hate street tires
Old 09-21-2012, 05:02 PM   #41
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
I figured out what this thread was about lol all is well.
TouchMyHonda is offline   Reply With Quote
Old 09-21-2012, 05:17 PM   #42
Miniata
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
I'm very happy to hear this. I competed locally in STX for a few years in my Mustangs, and we have a great bunch of guys locally in the class in a variety of different platforms that provide some good competition. Most likely next year I'll be swapping back and forth between my Mustang and BRZ in STX and might even throw some springs and swaybars on our Forester XT and bring it out if the weather is particularly cold or wet.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar
Miniata is offline   Reply With Quote
FRS/86/BRZ monthly winner? xAgentzero13 Site Announcements / Questions / Issues 8 10-05-2012 03:20 PM
Stillen FR-S Body Kit Design Winner Synack Scion FR-S / Toyota 86 GT86 General Forum 59 09-25-2012 03:12 PM
Our newest winner Hawaiian Issues | Warranty | Recalls / TSB 36 09-22-2012 03:04 PM
First 86 winner on the east coast -NJ/NY/PA JERZgrl88 NY / NJ / CT / PA 9 05-17-2012 10:24 PM
First 86 Winner may back out in MA ngabdala Scion FR-S / Toyota 86 GT86 General Forum 0 05-13-2012 10:54 PM
