#15 |
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
Its sad that some of you guys own the damn cars yet know not enough about its balance. It is 55/45 with no one in the cars and 53/47 with 2 occupants in it.
#16 |
86 Member
#17 |
FT86Club Vancouver
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Alot of the weight in the centre/rear is the frame...then you add the differential, drive shaft, rear axles, driver & rear seats, gas tank, trunk lid, and etc...
![]() ![]() ![]() To give you a better idea of the structural weight...look at the rear...then look at the front; majority of the front are panels...(which also includes the super light-weight aluminum hood) The front still house all the heavy stuff like the engine, battery, transmission, and etc, but engineers put it as far back as possible...relocating the centre of gravity all the way back...help evening out the weight ratio.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT 2010-2012 2013 BRZ Sport-Tech 6AT Since '12 (OEM+ STI tS Build) 2015 Lexus IS250 AWD F-Sport 2 2015-2018 2018 Lexus NX300 F-Sport 3 Since '18 |
| The Following 2 Users Say Thank You to DaJo For This Useful Post: | 20valvewynn83 (09-20-2012), FRiSson (09-20-2012) |
#18 |
Drives: 91 Corolla (dd) S14 (daily drifter)
Man you guys ar makeing something simple really complicated. Please, go on.
#19 |
Drives: 2013 FR-S Ultramarine
#20 | |
Drives: Firestorm FR-S (MT)
I could've sworn I saw on the Subaru website they said 55/45, but they were probably stating what it is without people. |
#21 |
| The Following 2 Users Say Thank You to Shagaliscious For This Useful Post: | 20valvewynn83 (09-20-2012), fatoni (09-20-2012) |
#22 |
86 Member
#23 |
86 Member
Here's a explanation of how it it works
With no occupants the car weighs 2,760 lbs stock so 55% of weight is (somewhere around) 1,518 lbs and the 45% is 1,242 lbs Now lets say two occupants weigh 150lbs a piece. That would mean around 2/3rds of their bodies will be on the rearward side of the car so it would have about 200 lbs on the rear and about 100 on the front. 2760+300=3,060 lbs and minus 53% from that and you get 1621.80(f) and 47% 1438.2(r) on the rear. |
#24 |
Drives: 2013 Asphalt FRS
Go take a corner, pray to the subaru gods, understand how easy it was to drift, and stop bickering. Car handles amazing. Plain and simple. Now what you should really be wondering is why they didn't slap a turbo on it with 6/4 breaks and a heavier clutch with adjustable suspension. <- O wait because that would add another 10 grand on the price tag and put it on a STi level which they don't want to do for marketing. This is an afordable sports car... you got what you paid for. If you don't like it. sell it for the 25-30 grand you picked it up for and buy a prius.... then complain how you didn't get 60+ MPG.
#25 |
Drives: Supercharged Golf Cart
Really? If true, that explains why I keep seeing both set of numbers mentioned.
Then I read this reply: So who is right or are we still in the assumption phase? |
#26 | |
Re-member
Drives: Toyota camry
Auto X?
Nothing decays like progress, and nothing preserves like neglect.
#27 | |
Re-member
Thanks, this is the kind of thing I was looking for, not a debate about 45 this 47 that. That picture of the frame is pretty cool.
#28 |
im not assuming (although that doesnt mean im right), scion has marketed the car as having a 53/47 split but that was with passengers. some people get bent out of shape about that but a) weight balance front to rear isnt as important as people make it out to be and b)if it is, that is a great balance as you should be accelerating at the apex of most curves shifting a little weight rearward giving you the best weight distribution when you actuall need it
| The Following User Says Thank You to fatoni For This Useful Post: | SpeedR (09-21-2012) |
| Help Removing Rear Seats and Rear Part of Center Console | ZC6BRZ | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 08-27-2012 03:11 PM |
| curb weight | 7thgear | BRZ First-Gen (2012+) — General Topics | 8 | 07-17-2012 04:05 PM |
| Weight..... | icemang17 | Tracking / Autocross / HPDE / Drifting | 2 | 07-02-2012 06:24 PM |
| Non USDM BRZ oil weight | BMWDavid | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 06-21-2012 02:55 PM |
| Weight of FT-86? | Levi | Engine, Exhaust, Transmission | 38 | 06-14-2011 10:43 PM |
