#141 | |
Drives: subatoy
what do you prefer a crooked one that meets the needs of the airflow of the freaking intake by and insignificant amount or keeping straight to ensure the best oil flow on the turbo? The 5-10 or so degrees it would take to fix the angle wouldn't change ANYTHING in terms of performance. It's just the tube for the air filter. |
#142 |
Drives: 400whp Scion tC
#143 | |
Drives: 2013 Ultramarine FR-S
IMO, the only reason to mount the turbo with the shaft parallel to the ground is aesthetic. And again, IMO, that's a compromise. Plus, as John already pointed out, it looks badass. I suspect there will be more issues with the elevated engine bay temps.. |
#144 |
987 Motorsports
Drives: '13 WO FR-S
guys, i'm still trying to dig up that article. the turbo can be straight also. but it goes about saying that too much angle is bad.
#145 |
That guy
Drives: Ultramarine mt FR-S
There's a garrett writeup that says their turbos are fine at an angle. it warns against angles of more than 33. I posted a link to it a little while back. This is an old argument, and angled turbos are nothing new.
Ultramarine mt FR-S
P&L stage 1 turbo Prime Motoring Flex fuel Jr Tuned 506whp @17psi (e73) |
#146 |
Drives: V12
Angle on turbo is nothing compared to g forces.
1g of accel = 45deg. Be it lateral or longitudinal. So much for being a wanker arguing about little angles. |
#148 |
Drives: '13 Turbo BRZ (AT) & '13 FRS
A quick video of we put together of our BRZ equipped with the P&L stg. 1 turbo kit!
[ame="http://www.youtube.com/watch?v=hvy5Rkl0lkk&feature=g-upl"]P&L MotorSports - 2013 BRZ / FR-S Stage 1 Turbo Kit - YouTube[/ame] Thanks! |
| The Following User Says Thank You to P&L Motorsports For This Useful Post: | Lonewolf (09-20-2012) |
#149 |
Drives: 2013 FR-S Whiteout
So the AT seems to be holding up well. No known issues as of yet?
#150 | |
The turbo is angled 8 degrees for a couple of different reasons that I wont get into because you still wont like it anyway. Obviously you don't like our design and you have made that very clear on multiple occasions, thank you for your concerns but we designed this kit with certain benefits in mind and having the turbo sit on a 8 degree angle is one of them. Every kit we have designed for the past 7 years from our 2 record setting 8 second dragcars to our TA/AutoX dominating customer 100+ turbo'd Subarus have the turbo angled 8 degrees, why because it works. Heck the worlds fastest BRZ by Accelerated performance (which we really respect) has the turbo at a 5 degree angle facing forward, is that wrong too? |
| The Following User Says Thank You to P&L Motorsports For This Useful Post: | OmarGC (09-22-2012) |
#151 | |
Its not in the same spot! its 8 inches to the driverside. More room maybe? I sure would hate to be that nice cold air in that charge pipe that now travels right above that really hot downpipe right below it! |
#152 | |
I wasn't meaning "exactly" in the same spot. Exhaust wrap for the charge pipe, perhaps. I do have some questions regarding the Auto trans. What can you tell us as far as the behavior of the auto trans when shifting with the paddles in manual mode vs letting it shift by itself. Does it handle the new power ok if you leave it shifting by itself? Also....1/4 mile run at the end...What's with the No Time posted? |
#153 |
Drives: 13 GTI
Looks like a lot of fun. Is that the iconic Subaru boxer rumble at the end of the 1/4 run?
#154 |
P&L, I would still like to hear from the manufacturer (you) about your thought (and potentially concerns) regarding the turbocharger's location, considering the immense amount of heat it brings to engine bays. Thanks.
| Dynosty Turbo FR-S FA20 Highest Horsepower Record 324WHP | Hal@Dynosty | Forced Induction | 363 | 11-19-2014 10:03 AM |
| The Record, Cars section FR-S review | muffinman | Scion FR-S / Toyota 86 GT86 General Forum | 0 | 07-01-2012 05:17 PM |
| Toyota captures Nurburgring EV record | 1660 | Other Vehicles & General Automotive Discussions | 2 | 09-01-2011 03:05 AM |
| Toyota looks to set Nurburgring record for EV | 1660 | Other Vehicles & General Automotive Discussions | 1 | 08-21-2011 10:34 AM |
