| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#15 |
I tried the mt-90 in my e36 m3
I prefer factory fill: my m3 tranny gets this http://pentosin.net/pressreleases/CR...nto_MTF2_2.pdf same as factory that liqui moly gl4 is good stiff too in a pinch absent the toyota fluid, I'd use either the liqui or pento gl4 my brz rear diff = motul 300v 75w90 |
#16 |
Running in the 90s
Drives: 2014 Scion FR-S Monogram
How's that working for you? Any noticeable differences from OEM? I've been considering Motul 300v or Motylgear when I get past break-in.
藤原とうふ店(自家用)
MattR's Tofu Runner |
#17 |
I usually post drunk
Warranty repair to transmission? Are you allowed to say what the issue was?
#18 |
Dont be skeptical of the pentosin, it FIXes 2nd gear, and makes them all feel better
http://www.ft86club.com/forums/showthread.php?t=16604 do NOT use the MT 90 its not gonna give you the 100% improvement that can be had |
#19 |
BR-Zizzle
Jeff, I can look into this for you on Monday.
A little addiction goes a long way...
2013 Dark Grey Metallic Subaru BRZ 1986 Toyota Corolla GT-SR5 1985 Toyota Corolla SR5 |
| The Following User Says Thank You to DookDookDGM For This Useful Post: | Jeff Lange (09-08-2012) |
#20 | |
Drives: Altezza RS200-Z 6MT
I don't have any issues with cold shifting but the coldest it gets here on a winters morning is @ 35°F Last edited by SXE10; 09-19-2012 at 05:02 PM. |
| The Following User Says Thank You to SXE10 For This Useful Post: | Brzce (09-19-2012) |
#21 | |
Drives: 2004 Subaru Forester 2.5XT
It's going to be easier to find a GL-4 oil since the API considers GL-3 obsolete. -Dennis |
#22 |
Drives: '13 Ultramarine
I've had good luck so far with the MT-90. I've got about 4000 miles on this fluid. It gets pretty cold here over the winter and I suspect cold enough that I may need something a little less viscous. I have a quart of MTL (it is thinner-like a honda fluid) here that I could add to the trans if things start to get crunchy or otherwise unruly. Failing that, I will try the Pentosin fluid. I found a local shop that deals with CRP and they can get it. Pricey stuff, but worth it if it does the trick.
| The Following User Says Thank You to roddy For This Useful Post: | gmookher (09-20-2012) |
#23 |
Drives: TR2,CooperS,BRZ
Anyone used eneos GL 5 gear oil in their transmission?
#24 |
It's not advisable to use a GL-5 in these transmissions. Supposedly it is harmful to yellow metals/brass. Stick to GL-3/4 as per the factory specs. Redline, Amsoil & Pentosin all make suitable GL-4 75w-90.
#25 |
Drives: Blue BRZ
Sorry to bump an old thread, but did you ever end up figuring out how to get the fluid, or did they just get a GL4 after all?
#26 |
gl3 standard was replaced by gl4
simple you want a gl4 oil sae weight means nothing its all about cst unless you know the oe fluid cst, you need to make an educated or scientific guess, or shoot in the dark for what aisin specs not sure why there is so much experimentation when there are one or two fluid specs that seem to work I'm having success with 75w oils that flo 100c cst 8.0 or lower in my 6MT honda and miata dealers are stocking oils that are also low cst oils fwis on cars that have dealer fluid support and use our trannys Good luck to thos of you searching for something else, lmk what you find Last edited by gmookher; 11-16-2012 at 10:03 AM. |
#27 | |
Drives: Blue BRZ
Hey man,
I know you're quite passionate about this topic, but I was more interested in what happened with this since it was warranty work. Quote:
#28 | ||
You won't have a problem with the warranty since GF-3 has technically been obsolete since 1995. -Dennis |
| subaru brz navigation system wire diagram? watching movies usb works !! | SgtBolt | Audio/Visual, Electronics, Infotainment, NAV | 3 | 06-21-2012 11:31 PM |
| Subaru BRZ Earns 9 of 10 in Top Gear Magazine First Drive Review | Spaceywilly | BRZ First-Gen (2012+) — General Topics | 43 | 05-12-2012 07:11 AM |
| On the road: Subaru’s new BRZ (Top Gear) | Mr Franky | BRZ First-Gen (2012+) — General Topics | 4 | 03-29-2012 07:58 AM |
| Top Gear Magazine Review of Subaru BRZ and Toyota GT86 | davey90 | BRZ First-Gen (2012+) — General Topics | 122 | 01-09-2012 11:15 AM |
| Top Gear Online Subaru BRZ review - if you enjoy driving, this is the car for you | Hachiroku | BRZ First-Gen (2012+) — General Topics | 54 | 12-13-2011 06:32 PM |
