Old 09-18-2012, 11:30 AM   #15
Memphis
Memphis's Avatar
Drives: Scion FantasticRoad-Sex
Originally Posted by Eric1855 View Post
Maybe when its new, but it doesn't take too many times of going back to 1st in an AutoX before the transmission also starts to say nope. The sound of the syncros grinding into first is pretty hard to get out of your head.
There shouldnt be a reason to go back into first :p
Memphis is offline   Reply With Quote
Old 09-18-2012, 03:12 PM   #16
hankster
hankster's Avatar
Drives: 2013 FR-S Argento
will be doing an all-day rookie autocross school in October in my A/T. Then the next day the real deal autocross event. I have no worries about my car being A/T. Should be a blast
hankster is offline   Reply With Quote
Old 09-18-2012, 03:21 PM   #17
mechaghost
mechaghost's Avatar
Drives: Silver AT Limited
another cool point about AT is that you never worry about stalling when you spin out :p
mechaghost is offline   Reply With Quote
Old 09-18-2012, 04:00 PM   #18
korinfox
Drives: Lexus IS300 Sportcross
Actually, I've stalled out my auto IS300 before from spinning out. If you're not hard enough on the brakes when you spin, you don't lock the tires, and if you go backwards you can stall the car.
tldr: Clutch and brake to the floor when you spin (or just brake in an AT)
korinfox is offline   Reply With Quote
Old 09-18-2012, 04:04 PM   #19
whataboutbob
AutoX-10/10ths every run
I found that Manual Mode + 2nd + Sport Mode + VSC Sport worked great for me in my first AutoX. I might try Manual + all the Nannies off at my next event.
I also agree that once I got into 2nd, I didn't need to shift up or down anywhere in the course, except at the finish
The Following User Says Thank You to whataboutbob For This Useful Post:
amram (03-17-2014)
Old 09-18-2012, 06:41 PM   #20
Eric1855
Drives: LP DSP / CSP '13 BRZ
This. I have rarely been on a course where the time spent shifting to first then back to second was actually faster than just leaving it in second, especially in a N/A car where you're not worried about bogging a turbo down.
I tried going with Full traction control off (holding it down for 3s) and it did not end well on the stock tires...it ended backwards, with the car stalled out. Yes you can stall an Auto just as easy as a mt when spinning.
Eric1855 is offline   Reply With Quote
Old 09-18-2012, 07:51 PM   #21
RYU
RYU's Avatar
Drives: really slow...
If the AutoX track is big enough where you find yourself shifting 2nd to 3rd I highly recommend trying out the Sport mode in "D". If you let it shift for you, you might be surprised how well it can predict and anticipate downshifts.
RYU is offline   Reply With Quote
The Following User Says Thank You to RYU For This Useful Post:
amram (03-17-2014)
Old 11-01-2012, 03:20 AM   #22
Echo
Drives: Scion FR-S. Black.
After six hours my brakes wore, I understeered into a cement wall. Then it was at the shop for 2 and a half months. Other than that, Autox the AT is fun.
Pro tip: Check yo brakes.
Echo is offline   Reply With Quote
The Following User Says Thank You to Echo For This Useful Post:
amram (03-17-2014)
Old 11-01-2012, 03:27 AM   #23
whataboutbob
My last event I tried a number of runs with the nannies off...spun out 4x.
Not sure if it is better to leverage the TC to my advantage with the nannies on, or turn them off. I've been told that I should learn to handle the car with them off, but given my lack of exp/skill it seems really easy to spin out.
Build thread:Here
Old 11-01-2012, 03:48 AM   #24
Echo
Leave em off on the track. And listen to the instructors
EDIT
I mean, that's why you're there for, to improve as a driver. I ran a few times with VSC Sport on D, but even then it corrected most of my mistakes. If you can drive at like...level 10...when you're driving on regular roads at level 2 and crap hits the fan, say a truck veers into your lane, you can go He-man on that road.
whataboutbob (11-01-2012)
Old 11-02-2012, 02:03 PM   #25
DR 86
DR 86's Avatar
EDIT
Lol, says the guy who had so much sense to go six hrs on stock brakes and ended up in the wall.
With this auto tranny, it's fun driving in manual on the streets for the occasional pull etc, but on track, you'll be much faster just keeping it in auto + sport mode. The computer will amaze you with how accurately it anticipates downshifting and how aggressively it rev-matches. It pretty much keeps you right in the power band in all instances. This allows you to just concentrate on your racing line, steering input, and throttle/brake modulation. And yes, it stalls just like a MT when you spin out violently.
DR 86 is offline   Reply With Quote
Old 11-02-2012, 02:05 PM   #26
whataboutbob
Yeah, mine did stall at least once on one of the better spinouts. Took a second for me to get it restarted as I was laughing too hard
Build thread:Here
Old 11-04-2012, 03:12 AM   #27
Echo
Meh, it wasn't for six hours straight.
Automatic Transmission devinclfalcons Engine, Exhaust, Transmission 60 04-29-2014 09:42 PM
Which transmission do you have ? Manual or Automatic ? PRO Import Tuners Engine, Exhaust, Transmission 14 08-24-2012 09:21 AM
FT-86, manual or automatic transmission??? luisjr Scion FR-S / Toyota 86 GT86 General Forum 22 07-25-2012 03:00 AM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
Any info on the automatic transmission? ryude Engine, Exhaust, Transmission 31 12-01-2011 05:30 PM
