Old 09-17-2012, 09:32 PM   #5517
Calum
That Guy
Drives: 2013 asphalt FRS MT
Wow, I had to look. Those guys on spyderchat are relentless. I'm shocked at your level of patience.
serialk11r, my limited experience with throttle position sensors is that the PCM will accept a max of 0-5v. But the vast majority of sensors wont get anywhere near that range so the PCM will interpolate the values based on the max range it actually receives. Unfortunately most OBD2 readers aren't setup for this and just show you the percentage of the expected 0-5v.
0v output from an O2 seems wrong to me, the fluctuations at idle though seems pretty normal. Ever see an AFR gauge in a car with narrow band O2 sensors? It's just a light show bouncing back and forth at idle.
Calum is online now
Old 09-17-2012, 10:55 PM   #5518
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
We need more animations like this that explain the many basic aspects of cars...
[ame="http://www.youtube.com/watch?v=GRDWO5qo_iI"]Clutch Industries - How a clutch works - YouTube[/ame]
When you are trying to teach others, these sort of things are invaluable...
- The Ancient BRZ Sacrament
by Zaku
Guff is offline
Old 09-17-2012, 11:08 PM   #5519
S2kphile
Resident HoneyBadger
S2kphile's Avatar
Drives: Toyota Tacoma TRD Off-Road
Originally Posted by serialk11r View Post
lol iono generally I don't see many good looking ones around Stanford when I am around there, but maybe I'm just not looking in the right places...that's what everyone tells me
I think I might have been in the right section of the stadium or I have find fine ladies vision or something because I always seem to spot them.
Walk like a King, Be like a Sir, Swag it out like a Boss
S2kphile is offline
Old 09-17-2012, 11:09 PM   #5520
Dimman
Kuruma Otaku
Dimman's Avatar
Are you a solidworks master yet?
Could start your own project. And if you just happened to use accurately modeled Supra or Twins parts for it... Well that would be pretty epic.
(Please share models! )
Because titanium.
Dimman is offline
Old 09-17-2012, 11:09 PM   #5521
serialk11r
Drives: '06 AM V8V Coupe
Oh okay, thanks man.
~0V from the post cat sensor I guess could make sense, because the oxygen content is supposed to go down (it's burned in the cat afterall), and as I understand lower voltage = lower oxygen concentration Since I have this super strong unburned gas smell I assume my car likes to spew out a bit of extra gas for whatever reason and that certainly helps consume oxygen too.
Now the load really bothers me though. The number clearly isn't directly correlated to throttle position, so that means it's being calculated off some different measured parameters. Except my OBD2 scanner is only able to track MAF, not MAP or barometric pressure. So what the hell is it using the calculate load? The ECU cannot possibly be doing stupid speed-density calculations and then trying to correlate that with MAF readings, that would be completely retarded. Since I can't read MAP, I have no idea what's really going on, but I think my passenger told me that when I floored it on the highway at 3500rpm instead of in the 2000s, the "load" was only 69%. I hope I don't have an air filter that has an inch thick layer of dirt stuck to it lol.
Smog is only going to get tougher to pass, so I think I'll replace the 2 sensors used for fuel trim sometime before the next smog check. Still tracking fuel economy and oil consumption of course, when I get a better idea of that I'll figure out what to do.
By the way, in 1st gear my car is a bit jerky, as in when it's engine braking then I step on the throttle, instead of bam kick of power, there's kick, back off slightly, resume power. Is this just a normal cable throttle thing, or is it an indication of dirty MAF/something else?
serialk11r is offline
Old 09-17-2012, 11:12 PM   #5522
Asterisked Accolade
Pedals over Paddles.
Asterisked Accolade's Avatar
Drives: Celica GT-S | 89 Supra | 07' Accent
"I found that despite time-travel and dimensional warping, it didn't matter. I'd changed the past and I'd changed the present, but every reality led to the same future-- a fight. No matter how I diverged from my own path, I was always led to fight for the freedom and livelihood of humankind. I couldn't avoid it, and it was at that very moment when I stopped trying to." - William B. Hendriks, White Rook II: Dawn of the Accolaid
2002 Celica GT-S Track Car | 1989 Supra Track Car | 2007 Hyundai Accent AutoX | 2003 Cadillac CTS Daily
Asterisked Accolade is offline
Old 09-17-2012, 11:14 PM   #5523
Asterisked Accolade
"Although the past was laden with death, sorrow and loss, I knew something very definite in my heart. After the searing flames of the dying world faded and the songbirds sang in the summer sun once more, the scarred world would see that it was always going to be saved; It just had to deserve it first." - William B. Hendriks, White Rook III: Exodus
Old 09-17-2012, 11:14 PM   #5524
Dimman
Kuruma Otaku
Dimman's Avatar
It could be cross checking it against throttle position and rpm. That is 'Alpha-N' measurement.
Edit: read first, then post, Dim...
Because titanium.
Dimman is offline
Old 09-17-2012, 11:21 PM   #5525
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Note to myself. Getting phone # is always a great thing... BUT when she's 19, that's different story... It's 10 yrs difference man! 10 freaking years!!!!
ichitaka05 is offline
Old 09-17-2012, 11:31 PM   #5526
S2kphile
S2kphile's Avatar
Why so worried? Shes of legal age. When does it become wrong to date a woman way younger then yourself. Oh yeah when social shaming & condition comes into play.
As long as you genuinely desire each other then age don't mean shit and IMO, it's better when the guy is older then the woman preferably 4 years or more.
S2kphile is offline
Old 09-17-2012, 11:46 PM   #5527
Guff
Guff's Avatar
Drives: BRZ LZR
Our SAE has a CAD Class, but sadly I have no room in my schedule for it...
One day, man... One day...
by Zaku
Guff is offline
Old 09-17-2012, 11:47 PM   #5528
Re~Mix
Re~Mix's Avatar
Drives: 13' Scion FRS MT
[ame="http://www.youtube.com/watch?v=bw9CALKOvAI"]HYUNA - 'Bubble Pop!' - YouTube[/ame]
Now that I own an over engineered, Asian car is this my destiny? The longing looks from the local JDM girls in their S2K, Civics and WRXs seem to say so.
07' Z4M Coupe | KW Clubsports | AFE Intake | Stromung Mufflers | UUC Shortshifter | Advan RS
15' 228i MSport
13' FR-S | TRD CAI | TRD Catback | UEL Header | OFT Stg 1 | Rota Grid-V | RCE Suspension | Hankook |
Re~Mix is offline
Old 09-17-2012, 11:49 PM   #5529
Dimman
Kuruma Otaku
Dimman's Avatar
Isn't Hyuna Korean?
Shoulda got a Genesis Coupe...
Heh...
Because titanium.
Dimman is offline
Old 09-17-2012, 11:51 PM   #5530
Re~Mix
Re~Mix's Avatar
Isn't Hyuna Korean?
Heh...
Touché, sir. Don't mind the new attention, wondering how long the FRS awe factor will last
15' 228i MSport
Re~Mix is offline
