View Poll Results: What Differential fluid is in your BRZ/FRS?
Amsoil Severe Gear Synthetic EP Gear Lube 75W-90 22 12.94%
Mobil 1 75W-90 synthetic gear lubricant LS 11 6.47%
Motul 300v 75w-90 83 48.82%
Redline 75W-90 NS GL-5 Gear Oil 22 12.94%
Dealer Brand 32 18.82%
Voters: 170. You may not vote on this poll
Old 09-15-2012, 04:00 PM   #1
ft86Fan
ft86Fan's Avatar
Drives: FR-S, Exige S, Miata
Since we have a "What Brand of Oil is in your BRZ/FRS?" Poll, lets do one for diff fluid. Owner's Manual recommends API GL-5 and SAE 75W-85 or API GL-5 and SAE 75W-90 spec oil. Since we have a Torsen gear-type differential without clutches, we don't need or want friction modifer(FM)?
What are you using and the reasoning? When did you swap the fluid?
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield
'95 Miata (Montego Blue)
ft86Fan is offline   Reply With Quote
Old 09-15-2012, 08:05 PM   #2
roddy
roddy's Avatar
Drives: '13 Ultramarine
Redline 75W85. I changed the gear oil around 1200 miles, iirc. The drain plug is magnetic, and had a fair bit of metal stuck to it (looked like a fine grey paste). This is most likely due to the ring and pinion "taking a seat" to each other. I don't expect to see much on the 2nd change (likely next spring).
The Following User Says Thank You to roddy For This Useful Post:
ft86Fan (09-17-2012)
Old 09-17-2012, 08:56 PM   #3
Skye
Drives: TR2,CooperS,BRZ
Anyone used subaru extra-S?
Skye is offline   Reply With Quote
Old 09-18-2012, 01:31 AM   #4
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Amsoil 75w-110.
Old 09-18-2012, 11:28 AM   #5
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Originally Posted by rice_classic View Post
Amsoil 75w-110.
this is good shit. i sued on all my previous car
Old 11-04-2012, 01:43 PM   #6
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Red Line 75W85
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 11-08-2012, 10:48 AM   #7
empower-auto
Kouki-Monster
empower-auto's Avatar
http://www.redlineoil.com/product.aspx?product=57904
Ps - use this or 75W85.
Not the NS variant.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 11-09-2012, 03:31 AM   #8
Nardi330
Nardi330's Avatar
Drives: 86
I just replaced stock diff oil with Redline 75w90NS and it seems the LSD engages very easily. If I turn and take off in 1st gear at the same time, LSD seems to engage. I was letting off the clutch very slowly and balancing gently with the throttle on dry tarmac (ie not slippery surface) and im running on stock Michelin. It never seemed to do that with stock diff oil. Is this a good thing? Would LSD wear out more quickly? I'm sure the diff oil was filled up correctly.
I also fitted coilovers, changed gearbox oil with Redline MT90 and Whiteline subframe insert at the same time. I wouldn't think these would effect the LSD.
Anyone has the same thing after filling redline 75w90NS?
Thx
Nardi330 is offline   Reply With Quote
Old 11-12-2012, 08:39 PM   #9
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
The ExtraS is good but the Motul Gear 300 in our experience is as smooth or smoother, but since it's synthetic (unlike the ExtraS) it holds it's properties longer than the ExtraS.
-Mike Paisan
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
The Following User Says Thank You to AZP Installs For This Useful Post:
flippy (10-09-2014)
Old 11-12-2012, 08:57 PM   #10
RiskyTrousers
RiskyTrousers's Avatar
Drives: '87 Corolla GTS, '13 FR-S 6MT
OS250R
RiskyTrousers is offline   Reply With Quote
Transmission fluid swap? flawedchemical Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 48 09-12-2014 02:23 PM
Plasti-dip or painting the fluid caps in the engine bay Turbowned Cosmetic Modification (Interior/Exterior/Lighting) 8 09-07-2012 03:03 PM
Brake fluid volume celica73 Tracking / Autocross / HPDE / Drifting 1 08-20-2012 02:05 PM
Differential growl or ratcheting Roadstercycle Scion FR-S / Toyota 86 GT86 General Forum 2 06-17-2012 09:13 PM
Confirmed Torsen Differential Andy Engine, Exhaust, Transmission 50 12-12-2011 11:01 PM
