Old 09-16-2012, 09:18 PM   #141
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Originally Posted by SWPBRZ415 View Post
Do you hear popping when you are turning?
Nope just over bumps
Old 09-16-2012, 09:28 PM   #142
SWPBRZ415
Drives: brz
For me it was popping when i was turning also. So i got in contact with whiteline, they sent me a replacement set of top mounts. I think i had bad bearings. Installed new set and no sounds, smooth as butter. Did about 100 miles so far and still good. On the old set, when i spin the bearings it wasn't smooth. The new ones were. Not saying you have bad bearings but thats something to consider. Lets see what Myles think first.
SWPBRZ415 is offline   Reply With Quote
The Following 2 Users Say Thank You to SWPBRZ415 For This Useful Post:
ATL BRZ (09-16-2012), Smudgeous (09-17-2012)
Old 09-16-2012, 09:29 PM   #143
SWPBRZ415
Drives: brz
Originally Posted by r4m3n View Post
Regardless, gonna need to take it back to @Evasive Motorsports again and see what's up. This time I'll be sure to bring along the printed manual and have them walk through what they did in detail on the install.
Are you having sounds again?
Old 09-17-2012, 05:00 AM   #144
Smudgeous
Smudgeous's Avatar
Drives: 2013 WRB 6MT BRZ Ltd.
Definitely has me hopeful that my replacements in the mail from Whiteline do the trick for me also. I've got no popping except when the wheel is turned.
Smudgeous is offline   Reply With Quote
Old 09-17-2012, 09:56 AM   #145
ATL BRZ
ATL BRZ's Avatar
Just talked to Myles. He was extremely helpful. I'm becoming increasingly convinced that Whiteline has put out a bad batch of Com-C top mount bearings and/or there is a washer required for BRZ specific installs in between the black top spring perch and the top mount. Not sure but since it's been reported that the stock top mounts aren't making any noise with the RCE kit then the burden of proof is definitely on Whiteline's shoulders.
Now I'm waiting for Whiteline's NA office to open at 12pm ET so I can call them.
Old 09-17-2012, 10:59 AM   #146
mechaghost
mechaghost's Avatar
Drives: Silver AT Limited
Please keep us informed as to what whiteline says
mechaghost is offline   Reply With Quote
Old 09-17-2012, 11:21 AM   #147
r4m3n
r4m3n's Avatar
Drives: Ultramarine FR-S
Yea... clunking in the rear now. It was fine the first day or so after I took it back to have the springs correctly installed.
6.4.12 | Ultramarine | SoCal
r4m3n is offline   Reply With Quote
Old 09-17-2012, 12:04 PM   #148
ATL BRZ
ATL BRZ's Avatar
Just spoke with Jan @ Whiteline US and emailed him my RCE sales invoice to have new Com-C's sent to me. Hopefully I will have them by the end of the week, but who knows. Really hoping that the new ones will be quiet. I don't want to disassemble my struts multiple times to troubleshoot this.
Old 09-17-2012, 12:35 PM   #149
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Those with the clinking...did you use the proper tool to remove and install the top nut without spinning the strut/shock shaft? If not you likely damaged the strut/shock internally which is causing the clunk...
Or one of these and the proper sized allen works too:
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following 2 Users Say Thank You to Opie For This Useful Post:
jkamelo (01-07-2021), Tristor (02-28-2018)
Old 09-17-2012, 12:38 PM   #150
ATL BRZ
ATL BRZ's Avatar
Thanks for posting that image and yes, I used a Gearwrench Pass thru socket, which allowed me to get a long allen wrench with a ratchet adapter to hold the shaft steady to remove the top nut.
The Gearwrench set and these:
are the most useful tools ever!!!
The Following 2 Users Say Thank You to ATL BRZ For This Useful Post:
Opie (01-07-2021), Tristor (02-28-2018)
Old 09-17-2012, 01:11 PM   #151
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
GearWrench vortex pass-through sockets are my favorites. You'll have to kill me to take them from me. Every shadetree mechanic should have a set.
Old 09-17-2012, 01:14 PM   #152
Smudgeous
Smudgeous's Avatar
I contacted Jan last Tuesday evening by phone, sent out an email on Wed after getting a copy of my sales order, got a reply asking for me to confirm my shipping address on Thursday (it changed, so I replied with the correct one), and he shipped the replacement ones out on Friday. They're currently en route and due to be delivered to me tomorrow.
Old 09-17-2012, 01:25 PM   #153
ATL BRZ
ATL BRZ's Avatar
Have you been driving with the bad com-c's all week? If so, did the noises get progressively worse? On the fence about swapping the stockers back on at this point... If I drive carefully and consciously avoid bumps its not rattling, so on the highway it's ok for the most part.
Old 09-17-2012, 01:27 PM   #154
ATL BRZ
ATL BRZ's Avatar
Has anyone installed the Whiteline rear camber adjustment kit/bushings themselves? If so, how did you remove the stock bushings? I'm pretty sure those are close to impossible to get out by hand and will require a very powerful tool to remove them.
White n' Yellow. Asterisked Accolade Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 33 08-02-2015 04:01 AM
Yellow fog tint looks awesome! DookDookDGM BRZ Photos, Videos, Wallpapers, Gallery Forum 37 11-07-2012 03:40 AM
RCE YELLOW Performance Lowering springs intro buy! RCE Suspension Starter Pack! Racecomp Engineering Brakes, Suspension, Chassis 141 10-07-2012 08:12 PM
Amber Turn signals to yellow? deedz Cosmetic Modification (Interior/Exterior/Lighting) 1 08-01-2012 02:44 AM
FT86s at Megaweb (more footage of the yellow 86) ESBjiujitsu FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 16 05-26-2012 02:08 PM
