#127 |
Yes, PM us with some details.
#128 |
Drives: 2013 WRB 6MT BRZ Ltd.
As a few people have posted problems with the lowering spring + Whiteline Com-C strut tops making popping sounds, I wanted to post a bit of an update of my own situation. I gave Whiteline US a call on Monday and got ahold of Jan, who asked me to email him a blurb of the problems I'm having and a copy of the sales invoice. Looks like they're going to be mailing me a new set, and will attempt to diagnose the ones I ship back to see what the problem was.
#129 |
Instructions:
http://www.racecompengineering.com/i...s-instructions If you have noise, please double check your install to make sure you got the bumpstops and dust boots right. - Andrew |
| The Following 7 Users Say Thank You to Racecomp Engineering For This Useful Post: | ATL BRZ (09-13-2012), djdnz (09-13-2012), JoeBoxer (09-13-2012), r4m3n (09-16-2012), stratodyne (07-17-2013), Tristor (02-28-2018), whataboutbob (10-21-2012) |
#130 |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
Why aren't spring compressors used in the disassembly instructions for the rear?
#131 | |
Drives: Whiteout FR-S
#132 |
#133 | |
Drives: 13 BRZ Ltd 6MT(sold), 03 WRX (RIP)
#134 | |
Drives: BRZ DGM
#135 |
Drives: Legacy GT
And what's up with "swingarm?"
But as far as wheel nut torque goes I don't see a problem with wrx specs. The hubs, lugs, nuts, taper, wheel offset etc are all the same. I think it's kind of odd that they would change it to almost 90-lb ft. But anyhow I usually go for around 85 and consider it more important to use a torque wrench and get them even than the actual number, assuming it's in the right ballpark. Also, if you don't know how to properly torque lug nuts you probably shouldn't be installing your own springs. Last edited by jamal; 09-13-2012 at 10:56 PM. |
#136 |
Drives: CBS BRZ Limited
Shouldn't the wheel lug nut torque be 89 lb-ft?
#137 | |
As for "swingarm"....I have no clue why Dan wrote that instead of lower control arm. ![]() - Andrew |
#138 |
Just finished installing my RCE starter pack minus the rear camber adjustment kit (looked menacing to get the stock bushings out of the rear upper control arms, didn't even attempt).
I am hearing loud popping/rattling when driving over bumps from the Whiteline top mounts. I installed the springs and reassembled the struts exactly as the instructions were written. Torque specs on all bolts are good. Bump stops and dust covers are correct. I'm willing to bet that swapping the stock top mounts back on will get rid of the noise. It sounds like metal on metal almost like something is loose but I'm certain that everything is tight. Will be calling Myles tomorrow :confused:
#139 | |
Drives: brz
#140 |
Drives: Ultramarine FR-S
Regardless, gonna need to take it back to @Evasive Motorsports again and see what's up. This time I'll be sure to bring along the printed manual and have them walk through what they did in detail on the install.
6.4.12 | Ultramarine | SoCal
| White n' Yellow. | Asterisked Accolade | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 33 | 08-02-2015 04:01 AM |
| Yellow fog tint looks awesome! | DookDookDGM | BRZ Photos, Videos, Wallpapers, Gallery Forum | 37 | 11-07-2012 03:40 AM |
| RCE YELLOW Performance Lowering springs intro buy! RCE Suspension Starter Pack! | Racecomp Engineering | Brakes, Suspension, Chassis | 141 | 10-07-2012 08:12 PM |
| Amber Turn signals to yellow? | deedz | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 08-01-2012 02:44 AM |
| FT86s at Megaweb (more footage of the yellow 86) | ESBjiujitsu | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 16 | 05-26-2012 02:08 PM |
