Old 09-12-2012, 09:53 AM   #127
Racecomp Engineering
Yes, PM us with some details.
Old 09-12-2012, 07:26 PM   #128
Smudgeous
Smudgeous's Avatar
Drives: 2013 WRB 6MT BRZ Ltd.
As a few people have posted problems with the lowering spring + Whiteline Com-C strut tops making popping sounds, I wanted to post a bit of an update of my own situation. I gave Whiteline US a call on Monday and got ahold of Jan, who asked me to email him a blurb of the problems I'm having and a copy of the sales invoice. Looks like they're going to be mailing me a new set, and will attempt to diagnose the ones I ship back to see what the problem was.
Smudgeous is offline   Reply With Quote
Old 09-13-2012, 02:41 PM   #129
Instructions:
http://www.racecompengineering.com/i...s-instructions
If you have noise, please double check your install to make sure you got the bumpstops and dust boots right.
- Andrew
The Following 7 Users Say Thank You to Racecomp Engineering For This Useful Post:
ATL BRZ (09-13-2012), djdnz (09-13-2012), JoeBoxer (09-13-2012), r4m3n (09-16-2012), stratodyne (07-17-2013), Tristor (02-28-2018), whataboutbob (10-21-2012)
Old 09-13-2012, 02:47 PM   #130
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Why aren't spring compressors used in the disassembly instructions for the rear?
Old 09-13-2012, 02:50 PM   #131
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Instructions:
- Andrew
Excellent work I have technicians to do mine but with those instructions i feel like i could do it myself.
Old 09-13-2012, 02:52 PM   #132
For the rear it is not needed because there is very little preload on the springs. Definitely be careful but it is easy with help from a friend.
- Andrew
ATL BRZ (09-13-2012), jkamelo (01-07-2021)
Old 09-13-2012, 04:22 PM   #133
wrxneffect
wrxneffect's Avatar
Drives: 13 BRZ Ltd 6MT(sold), 03 WRX (RIP)
Instructions:
- Andrew
Good write up. Is there a reason why you state on the last page to torque the lug nuts to 65.7 ft-lbs and not 89 ft-lbs? I thought the specified torque spec for the lug nuts on the brz is 89 ft-lbs. 65.7 ft-lbs is the wrx spec, correct?
wrxneffect is offline   Reply With Quote
Old 09-13-2012, 10:28 PM   #134
Coastermikey
Drives: BRZ DGM
Instructions:
- Andrew
that car looks so familiar
Coastermikey is offline   Reply With Quote
Old 09-13-2012, 10:39 PM   #135
jamal
jamal's Avatar
Drives: Legacy GT
And what's up with "swingarm?"
But as far as wheel nut torque goes I don't see a problem with wrx specs. The hubs, lugs, nuts, taper, wheel offset etc are all the same. I think it's kind of odd that they would change it to almost 90-lb ft. But anyhow I usually go for around 85 and consider it more important to use a torque wrench and get them even than the actual number, assuming it's in the right ballpark.
Also, if you don't know how to properly torque lug nuts you probably shouldn't be installing your own springs.
jamal is offline   Reply With Quote
Old 09-13-2012, 10:44 PM   #136
schtebie
Drives: CBS BRZ Limited
Shouldn't the wheel lug nut torque be 89 lb-ft?
schtebie is offline   Reply With Quote
Old 09-14-2012, 09:37 AM   #137
Right, we used the WRX specs. The important part is to keep it even and use a torque wrench like Jamal said.
As for "swingarm"....I have no clue why Dan wrote that instead of lower control arm.
- Andrew
Old 09-16-2012, 08:54 PM   #138
ATL BRZ
ATL BRZ's Avatar
Just finished installing my RCE starter pack minus the rear camber adjustment kit (looked menacing to get the stock bushings out of the rear upper control arms, didn't even attempt).
I am hearing loud popping/rattling when driving over bumps from the Whiteline top mounts. I installed the springs and reassembled the struts exactly as the instructions were written. Torque specs on all bolts are good. Bump stops and dust covers are correct. I'm willing to bet that swapping the stock top mounts back on will get rid of the noise. It sounds like metal on metal almost like something is loose but I'm certain that everything is tight. Will be calling Myles tomorrow :confused:
Old 09-16-2012, 09:10 PM   #139
SWPBRZ415
Drives: brz
I am hearing loud popping when driving over bumps from the Whiteline top mounts. I installed the springs and reassembled the struts exactly as the instructions were written. Torque specs on all bolts are good. Bump stops and dust covers are correct. I'm willing to bet that swapping the stock top mounts back on will get rid of the noise. It sounds like metal on metal almost like something is loose but I'm certain that everything is tight. Will be calling Myles tomorrow :confused:
Do you hear popping when you are turning?
SWPBRZ415 is offline   Reply With Quote
Old 09-16-2012, 09:15 PM   #140
r4m3n
r4m3n's Avatar
Drives: Ultramarine FR-S
Regardless, gonna need to take it back to @Evasive Motorsports again and see what's up. This time I'll be sure to bring along the printed manual and have them walk through what they did in detail on the install.
6.4.12 | Ultramarine | SoCal
r4m3n is offline   Reply With Quote
White n' Yellow. Asterisked Accolade Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 33 08-02-2015 04:01 AM
Yellow fog tint looks awesome! DookDookDGM BRZ Photos, Videos, Wallpapers, Gallery Forum 37 11-07-2012 03:40 AM
RCE YELLOW Performance Lowering springs intro buy! RCE Suspension Starter Pack! Racecomp Engineering Brakes, Suspension, Chassis 141 10-07-2012 08:12 PM
Amber Turn signals to yellow? deedz Cosmetic Modification (Interior/Exterior/Lighting) 1 08-01-2012 02:44 AM
FT86s at Megaweb (more footage of the yellow 86) ESBjiujitsu FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 16 05-26-2012 02:08 PM
