View Poll Results: Should equivalent type of tire be used when comparing lap times of cars?
YES: To accurately compare the cars, equivalent tires should be used. 75 82.42%
NO: The tire that came with the car is part "of the car" and should remain unchanged for comparison. 16 17.58%
Voters: 91. You may not vote on this poll
Old 09-15-2012, 09:33 AM   #57
DarkSunrise
DarkSunrise's Avatar
Originally Posted by fatoni View Post
i got "different skidpads" from the fact that you are using data to support your claims that was collected on..."different skidpads"
I didn't want to get drawn into this debate, but felt the need to correct that statement. Edmunds' skidpad measurements (and actually all their testing) is quite regimented and is as consistent as you're going to get. They have a single test facility that they use, they've got a set policy for fuel and tires, they do repeated runs in multiple directions (CW and CCW on the skidpad), use asphalt that complies with the friction coefficient requirements of the FMVSS-135 brake-certification test, use timing lights instead of hand timers for the skidpad, etc. Also the weather conditions in southern california are about as temperate and consistent as you'll find in the world. To the extent you can compare cars' performance using objective testing, Edmunds has done it.
http://www.insideline.com/features/p...s-gallery.html
Now if you're arguing you can never compare objective numbers on cars because of the variables involved, that's a different story, but I know you don't believe that yourself as you've obviously quoted numbers before (also don't kid yourself, during development, even automobile OEMs will record objective performance data and benchmark against competitors).
i know we can analyze the term handling but i think objectively it might still be up for debate as to which is the best handling car. obviously the vette puts up tons of grip. its obviously the better high speed handler (thats what it was designed to do) but i wouldnt be surprised if figure 8s and slalom tests show the elise performs better in the low speed and transient handling areas
The slalom numbers are there in my post you quoted. That's the second number in the "triple slash". The ZR1 is faster.
1.06 g / 74.7 mph / 96 ft -- Corvette ZR1 (Michelin PS2)
1.03 g / 71.6 mph / 109 ft -- Elise (Yoko A048 LTS)
The Elise also loses in MT's figure-8:
23.7 seconds @ 0.87 g -- Corvette ZR1
24.8 seconds @ 0.75 g -- Elise
Also just as a general note, the problem with your concept about leaving tires stock and drawing conclusions about the chassis from that is that it can lead to some absurd conclusions. To take an extreme example, a 2013 Mustang comes from the factory with all-season tires. A 2013 STI comes with summer tires. If you tested both cars in the snow to see which one did better in it, the Mustang would destroy the STI. But no one would seriously argue the Mustang was a better car for the snow than an STI. Why? Because once you match tires on both (snow v. snow, etc.) you'll find the STI is a much better car through snow due to its lockable center differential and limited slip differentials in the front and rear. Tires have to be taken into consideration when comparing cars. That's why tires are equalized across the board in just about every competition event, even in the so-called "stock" classes of autocross.
The Following 3 Users Say Thank You to DarkSunrise For This Useful Post:
brewksy (09-15-2012), SubieNate (09-15-2012), xwd (09-15-2012)
Old 09-15-2012, 07:33 PM   #58
xwd
Not sure why people try to reason with fatoni, who has been proven to ignore rational thought over and over again.
Old 09-15-2012, 09:03 PM   #59
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
a peak of .98g doesnt count for much. those kind of singular instances are not really related to static sustainable lateral grip. that being said, you could probably set your sights a little higher than that. an na miata with decent coilovers and 225 rs3s will do 1.25-1.33g on the skidpad.
I recorded that on the street with 40psi in the srock tires, and I wasnt pushing all that hard
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Old 09-15-2012, 11:06 PM   #60
gmookher
she'll do 1.00g with stock suspension and star spec z1...
Old 09-16-2012, 07:47 AM   #61
fatoni
i started talking about the different skidpad after you corrected his skidpad force of the zr1. he said he was using your data but saying that the zr1 pulled 1.02g on a skidpad. he came to the conclusion that the elise handled better than the zr1. not even you agree with that. either he is using more than one set of data, or the margin of error is too great for an objective test. either way, he came to a conclusion that is skewed.
im not coming to any conclusions about chassis or anything. the only point ive ever been making is that if you want to do a stock test, drive the car the way the manufacturer delivered it. if you want to change things to shed light on a cars performance potential, great. just realize that frs people are going to want to change the tires, 370z guys are going to want to change the brakes, ms3 guys are going to want to tune out the torque throttling in 1st and 2nd, v6 mustang guys are going to want to rid the car of the governor etc.
making the use of the stock class (or any class really) allowing for changing tires could be used in the same argument for allowing a change of shocks or sways or brake pads. the only time ive ever said that changing tires isnt fair is when comparing cars values to eachother. when you change the tires on the frs, it loses value
Old 09-16-2012, 03:07 PM   #62
Kunzite
Drives: Toyota Auris
Are you talking about me? OK, let's cut the BS:
Originally Posted by Kunzite View Post
What are the Edmunds numbers for the ZR1? 1.02g was all I found.
Obviously (but not to you, it seems) I was looking for numbers comparable with those posted by DarkSunrise; and I wasn't so sure about what I've found, so I asked. Thankfully DarkSunrise provided the correct figures.
I don't remember claiming the Elise handles better than the ZR1; I can't, since I've driven neither.
Unfortunately you're going way further than that; you're working hard on persuading people that comparing cars with the same tires is "unfair", and would generate some sort of tuning spree (oh, really?). You're completely rejecting all the arguments about why someone would want to compare cars with the same tires.
In other words, you're scared about putting good tires on the GT 86, it would be too good for your liking.
Kunzite is offline   Reply With Quote
Old 09-16-2012, 06:03 PM   #63
fatoni
okay maybe you didnt say the elise outhandled the zr1. this has been going on for a while and im not going to reread all this jazz for that sake. sorry dude.
slow down. im not rejecting any thing. the only thing i ever said was unfair was changing tires in a stock comparison.
Old 09-16-2012, 06:09 PM   #64
Kunzite
Did it ever crossed your mind that maybe, just maybe we're not interested in your kind of stock comparisons?
Old 09-16-2012, 07:10 PM   #65
fatoni
if by my kind of stock comparison you mean the industry standard for stock comparisons, yes. did you ever consider that being interested in something doesnt make it fair or rational?
Old 09-17-2012, 03:28 AM   #66
Kunzite
Industry standard? Do you even know what an industry standard is?
Oh, now the clearly explained reasons why one would want a same tires comparison are "irrational". You're irrationally scared at the thought the GT 86, with proper tires, can also give some decent numbers.
Obvious troll is obvious. And, as dwx said, would ignore rational thought over and over again.
Old 09-17-2012, 09:12 AM   #67
DarkSunrise
I actually agree you can make arguments to equalize brake pads, fluid, and tires. Tires will make the largest difference on most cars though -- I think that's why people are adamant about at least equalizing tires before comparing track performance.
Sways are technically allowed in stock class autocross, but IMO that's really a large compromise to get more people involved in the sport. At that point, you're clearly changing the car's suspension from my perspective.
Old 09-17-2012, 11:20 AM   #68
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
Upgrading dampers is also allowed in stock class autox, as long as they use the stock mounting points.
Old 09-17-2012, 03:50 PM   #69
fatoni
yeah, im not actually crazy. its just that people hear a fraction of what im saying than then jump to conclusions. i understand if people want to try to equalize tires and that might move toward a more realistic performance comparison. ive just been saying that doing all that other stuff will to. then it really hits the fan for some reason.
i think that sways are part of the suspension too (so are tires imo but thats beside the point). im just bringing it up because one of the largest arguments people make is that you are allowed to change tires in stock classes.
Old 12-13-2012, 07:40 PM   #70
Bugbeat
Drives: '00 Avalon (daily driver), '05 A8L
On one of the spectrum, if you work for a car magazine whose audience is the general public, then you should compare cars as they come from the factory (stock tires). Then again, to the general public, track times should mean next to nothing anyway.
On the other end of the spectrum, if you're into autocross or tracking, then you should absolutely compare cars on equivalent tires. Why wouldn't you? Tires are probably one of the most commonly changed-out consummables on cars that see track time and can make a significant difference in handling and laptimes. For any kind of competition event, tires are largely equalized across the board anyway.
This here is why I don't read MT or C&D (or any of the big publications, really). Their size allows them access to certain resources smaller publications like Grassroots Motorsports can't, but they're just so... corrupted. In addition they have to almost cater to the public while maintaining a marginal gearhead fanbase - almost like Top Gear to an extent.
Bugbeat is offline   Reply With Quote
Nameless Performance Equal Length Stepped Header Jason@Nameless Engine, Exhaust, Transmission 4525 11-21-2022 06:38 PM
Interested in comparing the FT86 to the Silvia? regal FR-S / BRZ vs.... 36 11-06-2012 06:59 AM
FS: Gramlights 57d 17x9 +38 5x114.3 w/ tires 1500 miles on tires, $1800 shipped apexsti46 Wheels and Tires 6 09-05-2012 03:54 AM
To those who keep comparing the FRS to another car on specs... Moto-P Scion FR-S / Toyota 86 GT86 General Forum 60 06-06-2012 09:39 AM
Comparing front end of the FR-S/FT-86 to BRZ DIG1992 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 66 11-21-2011 06:26 PM
