Old 07-15-2012, 07:00 AM   #1
regal
Interested in comparing the FT86 to the Silvia?
The title was supposed to have a question mark.
Probably most here are familiar with the 240sx but in case you are not it was the only other alternative to the Miata for a sporty rwd lieghtweight car. It wasn't a hit like the miata in the USA because the EPA required Nissan to selll it with a 2.4L low revving truck engine. In Japan however it was very popular because it had the engine it was designed for called the SR20DET model called 200sx.
Its an interesting comparison because I'm seeing a lot of 240SX's in the USA restored with an SR20DET and sellling for 1/3 the price of the FR-S.
The new FR-S and an SR20DET 240SX are somewhat similiar "on Paper".
Wheel base : FRS: 99.4 in S14: 101.2 in
Width: FRS: 69.9 in S14: 68.0 in
Weight: FRS: 2737 lb S14: 2,762.4 lb
HP: FRS: 200hp @7k S14: 200 HP @ 6k
Torque: FRS: 161 ftllb @6.6k S14: 203 ftlb @ 4k
MPG: epa estimates are fairly useless but a well tuned S14 SR20DET reportedly gets 33-35 mpg on the HWy about the same as the FR-s, both require 93 octane.
Both have Mcpherson strut front suspension, rear suspension are both indepedant but the FR-S has been shown to not be a conventinal double wishbone as advertised. The 240sx can be upgraded to the later model 6 speed manual which is reportedly not the greatest but adequate to ~350hp.
The older Nisasan engine is proven very reliable kept stock. IMHO probably a suprior engine since it has forged internals, 50 hp can be addded with little expense, and of course much more torque.
Now what has 20 years of technology gained us? Better emmisions for sure.
But the biggest difference I think is the Chassis. The 240sx doesn't have what I would call a stiff unibody, in fact its a bit flexy. I get the impression that the FR-S has a very stiff chassis and we all know about the low center of gravity.
As far as performance: the SR20DET in stock form is 0-60 in about 6.5" and high 14's quarter mile. Sound familiar? Now the differene is that less than $1k in fuel management and boost increase its a 13 second car.
As far as handling finding info on the SR20DET powered 240sx (japan version) is difficult but I remember sport compact mag reporting 73mph and 0.95G with just coilovers.
All in all I think the cars are close enough that true driver enthusiasts would be comparing the two yet I haven't seen much discussion.
regal is offline   Reply With Quote
The Following User Says Thank You to regal For This Useful Post:
DarthNads (07-15-2012)
Old 07-15-2012, 07:16 AM   #2
NickD
Drives: '05 Corvette
240sx/silvia is comparable on paper, good luck trying to find one that hasn't been slammed/quarter panels pulled/setup for drift/rattlecan painted etc.
NickD is offline   Reply With Quote
The Following 2 Users Say Thank You to NickD For This Useful Post:
enjoi23 (11-04-2012), xravexboix (07-15-2012)
Old 07-15-2012, 08:41 AM   #3
Fussy08X
Fussy08X's Avatar
Drives: Toyota GT 86 Pearl White
surprised the two havent really been compared yet. I have an s15 and i still really like it even after like 8 years. buying an 86 because I wanna try out an n/a car and im a fan of the original 86 ever since initial d
Fussy08X is offline   Reply With Quote
Old 07-15-2012, 11:19 AM   #4
Ocho-Seis
Ocho-Seis's Avatar
Drives: Raven FR-S 6MT
I have an S14 Kouki also sitting in my lot, but I'm not comparing it because it's in tear down mode waiting for that faithful day I drop the RB26 in it. The thing is The Silvia chasis is so interchangable none of them remain stock or anything for long. SO there is no point in comparing it to an 86. Thats just IMO.
Ocho-Seis is offline   Reply With Quote
Old 07-15-2012, 11:26 AM   #5
fatoni
they have been compared. a lot. you would probably have more luck looking in the vs section for things of this nature
The Following User Says Thank You to fatoni For This Useful Post:
blu_ (10-24-2012)
Old 07-15-2012, 11:37 AM   #6
regal
There are plenty in stock form left on the east coat (most in automatic form easily coverted), and the comparison is to the stock Japan version, which one can easily build in the USA. Its a valid comporison stock Japanese Silvia to the FR-s.
Old 07-15-2012, 11:40 AM   #7
Ocho-Seis
Ocho-Seis's Avatar
I see. Well I know people who rather compare the Hyundai Genesis 2.0T to the Silvia in that case. Good luck with finding your comparisons though.
Old 07-15-2012, 12:05 PM   #8
Max Schnell
Drives: Lexus GS350 F-sport
As someone who had owned and modified a 240sx let me give you some perspective from my end. I owned a 1995 S14 base which I started with. All my comments refer only to the US 240sx, please do not compare it to any other specs.
I started modding my 240sx when SR swaps were still being researched back in 1998. Needless to say I have tested the good, the bad and the ugly of 240sx aftermarket. I will state though that I never actually went with the SR, I ended up with a turbo KA.
The 240sx is kind of similar in concept to the FRS/BRZ except with much older technology and the US got the KA24 motor.
The 240sx is a capable chasis but not while stock. Stock it is a slow, flex prone and softly dampened car on skinny tires, weak brakes, with the main virtue being relatively small, and low body compared to alot of similar cars. It has the pancake shape which I always kind of liked.
The real promise of the 240sx is in the potential based upon aftermarket modification. The car has been around forever and has alot of potential with the right modifications. Your MAIN enemy will be AGE and WEAR based upon age.
The sheet metal on the 240sx is not the strongest and certainly not very rust proof. To find a clean rust free example to start with is not easy.
The you start the aftermarket. Lets just say that to get a 240sx into a clean physical shape (not some bondo, omg low drifta gansta pos status) will cost you a nice bill at the body shop (kit, refresh, ding removal, possibly rust removal too). Oh I'd say 5k.
Next all suspension must go and reinforced bushings put in. Another 5k in parts and whatever labor.
Motor has to be either built or swapped for boost. Good swaps are 5k range with basic bolt-on upgrades.
So by the time you are done you have basically rebuilt the car on aftermarket stuff. Car will be worth more in parts than it is as a car.
A good modded 240sx handles like very well but with a tail happy attitude and runs with the best of them in a straight line. It will ride like a dump truck and is likely obnoxious in loudness. Stuff will vibrate and you will always wonder if the motor will take another 5lbs of boost.
Luxury What? I can't hear you over my exhaust!
I loved mine for many years until the bill hit over 30k and the car still didn't run right and more stuff was going due to age.
Max Schnell is offline   Reply With Quote
The Following 4 Users Say Thank You to Max Schnell For This Useful Post:
FTEIGHTSIX (07-15-2012), LivingLegend (07-15-2012), regal (07-15-2012), Turbowned (09-09-2012)
Old 07-15-2012, 12:11 PM   #9
Enilder
Drives: Porsche
S15. Best looking Silvia, ever.
Enilder is offline   Reply With Quote
Old 07-15-2012, 01:02 PM   #10
FTEIGHTSIX
Switched to the dark side
FTEIGHTSIX's Avatar
Drives: 91 & 95 240sx KA-T SOLD, 2013 BRZ
Originally Posted by Max Schnell View Post
As someone who had owned and modified a 240sx let me give you some perspective from my end. I owned a 1995 S14... (AWESOME LONG STORY OF OWNERS HISTORY W/ 240sx's)
Sounds almost exactly like my story, except I bought and started modding my S14 in 2005.
FTEIGHTSIX is offline   Reply With Quote
Old 07-15-2012, 01:29 PM   #11
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
n/a supra is fun, more reliable, and hold its value better.
adprokid is offline   Reply With Quote
Old 07-15-2012, 01:42 PM   #12
fatoni
...where did that come from?
GenkiElite (07-15-2012)
Old 07-15-2012, 01:58 PM   #13
brzzz
Drives: White BRZ
I think the argument should be, that if a new s15 were available today how much would it cost. If they were comparable, would you still get the ft86? Does the ft86 feel like a car that has 15+ years of technology advantage?
brzzz is offline   Reply With Quote
Old 07-15-2012, 02:47 PM   #14
Synack
Boosted
Synack's Avatar
Drives: Sideways
The reason I'm getting the FR-S is because I've been waiting, I'm sure with many thousands of people, for a RWD lightweight car that was very similar to the 240 to come out. We've been getting close but not quite what we all wanted with cars like the RX8 and the Genesis and others. But they weren't lightweight enough or they had a rotary motor, which most people don't want. IMHO the FR-S is like the rebirth of the 240. I know I know it was built after the original AE86 but it definitely feels like a modern day 240. Which works great for me. I have contemplated buying a 240 numerous times but I always wanted a new version where I didn't have to worry about aging parts. Not to mention out of the box audio and interior. I'll be proud to be the first owner of my Whiteout 6MT FR-S. Maybe even the last.
Anyone forsee a New Silvia / 240sx to come ? MarkRacerX Other Vehicles & General Automotive Discussions 103 11-26-2012 09:00 PM
To those who keep comparing the FRS to another car on specs... Moto-P Scion FR-S / Toyota 86 GT86 General Forum 60 06-06-2012 08:39 AM
Comparing front end of the FR-S/FT-86 to BRZ DIG1992 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 66 11-21-2011 05:26 PM
My friends ask why I'm so interested in this car... KaliKev Scion FR-S / Toyota 86 GT86 General Forum 68 11-19-2011 10:46 PM
