Old 09-15-2012, 02:17 AM   #15
Grishbok
Volunteer Fire and Rescue
Grishbok's Avatar
Drives: Ambulance... sideways.
If your concerned about them not changing the filter, put a mark on it. I use a white shoe polish we use for applying numbers to car windows, just put a big fat dot on there. When they change it, that dot will be gone.
Keeping all service records from the dealer increases resale value, if you do the changes yourself, please keep track of mileage when changed and the recipts of the oil/filter used. This way, you are covered if there is engine failure in case there is a warranty dispute falling on "improper oil"
It's more fun to drive a slow car fast, than a fast car slow.
Grishbok is offline   Reply With Quote
Old 09-15-2012, 11:10 AM   #16
20valvewynn83
20valvewynn83's Avatar
Drives: 2013 FRS/01 Tacoma
Originally Posted by TemeCal View Post
Really??? It's just an oil change. Not that difficult to do, and hard to mess up. I work on all my own vehicles as well...turbo installs, brakes, suspension, frequent top ends on my offroad vehicles, etc... I'm certainly not a true mechanic, but have no problems tackling all my work.
I guarantee you that I am much more thorough with my work. I've had 2 issues with previous dealers, and finally stopped giving them my work (WAY overtightened oil drain bolt...other time didn't tighten the oil filter enough, which caused oil to majorly leak).
I trust myself, far more than the dealer. I'd be willing to bet, most are more cautious with their own vehicle over the dealer's work.
It's good to work on your car I'm just saying in most cases people don't complete their oil change correct. It's not they don't know how its that the don't tighten the drain bolt all the way or they over/under fill it. In my 11 years experience I have never see any technician keep the drain bolt loose and have shipped it to the customer but that's only my experience and I'm not saying it didn't happen to you because people make errors from time to time. As far as stripping your oil pan from over tightening it. Thats hard to discuss because every time you remove and reinstall the drain plug it wears out the bolt threads and I don't know the mileage you had on your car. It's just funny how people think a drain bolt will last for ever. I replace them all the time and if a customer gets pist for having to pay an extra $10 ish bucks then too bad because I'm not taking the blame for an oil pan.
20valvewynn83 is offline   Reply With Quote
Old 09-15-2012, 06:32 PM   #17
FR-S,M.D.
Drives: 2013 Argento Scion FR-S 6AT
That's what Fumoto drain valves are for. Quick, efficient, never have to replace the bolt.
FR-S,M.D. is offline   Reply With Quote
Old 09-15-2012, 07:10 PM   #18
TemeCal
Drives: 86
EXACTLY what I have on all my vehicles!! Best $20 I spend on my cars.
TemeCal is offline   Reply With Quote
Old 09-15-2012, 08:23 PM   #19
JWMotoring
JWMotoring's Avatar
Drives: FR-S baby!
Great filters. I use these on all of my cars.
JWMotoring is offline   Reply With Quote
Old 09-15-2012, 10:11 PM   #20
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
Why did you use a wix filter and not a Toyota filter? And why are you changing your oil when you get free oil changes from scion?
http://www.ft86club.com/forums/showp...5&postcount=18
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn
@Art_Mighty is offline   Reply With Quote
Old 09-15-2012, 11:32 PM   #21
20valvewynn83
Originally Posted by @Art_Mighty View Post
What does this have to do with anything? I was questioning his filter selection.
Old 09-16-2012, 12:19 AM   #22
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
you get one free oil change every 7.5k from Scion. especially this early in an engines life it's a bad idea to wait that long (which is what I believed you were inferring)
Old 09-16-2012, 12:56 AM   #23
TemeCal
Drives: 86
@Art_Mighty was just pointing out the shavings found during an oil change. If we take your advice and have the dealer do the oil change, you'd have to wait until 7500 miles. All those metal shavings are circulating around for 7500miles.
I believe he's saying this is a good reason to change your own oil, rather than have the dealer do it.
Edit: Oops...I just realized Art_Mighty replied as well
The Following User Says Thank You to TemeCal For This Useful Post:
20valvewynn83 (09-16-2012)
Old 09-16-2012, 12:56 PM   #24
20valvewynn83
Doing the oil change early is fine but of you do it too early their will still be more shavings. But that's is not what I really care about, wix filters are garbage and I would never use one on my car.
Everyone thinks that all the shavings will be out within 1000 and that's wrong. It's going to take more then 1000 miles to have the engine completely broken in. Me personally I'm doing mine every 5000 but that's me.
Old 09-16-2012, 07:26 PM   #25
Calum
That Guy
Drives: 2013 asphalt FRS MT
Source?
Old 09-16-2012, 08:12 PM   #26
20valvewynn83
This filter has metal cartridge end caps, but has a separate bypass valve assembly that rests against the front end cap. I refer to this as a two-piece filter cartridge. The separate valve takes some of the internal filter space from the filter cartridge itself, which is something to consider for shorter filters (see the Car Quest and NAPA Toyota filters for an example). It uses an anti-drainback valve that doubles as the bypass valve-to-backplate seal. Instead of the leaf spring spacer that most filters use, these use a stiff coil spring at the top of the cartridge. The only drawback to this design is that the bypass valve seats metal-to-metal against the bottom cartridge end plate. This could allow dirty oil to seep from the dirty side to the clean side of the filter, bypassing the element. The design will not allow oil to seep back into the pan, though and the amount of oil that can get past is probably negligible.
Old 09-16-2012, 11:27 PM   #27
n2oinferno
Praise Helix!
n2oinferno's Avatar
If you're going to copy and paste that much text from another website, at least give the source some credit. Or were you trying to sneak one by everyone?
http://minimopar.knizefamily.net/oil...reference.html
Old 09-17-2012, 12:30 AM   #28
20valvewynn83
Nah its called lazy and didn't want to give a site with that much reading it was quick and easy. Anyone that knows how to Google information can find it like yourself.
Scion FR-S Concept First Official Pics/Videos + NYIAS Pics and Press Conference Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 856 06-14-2018 02:53 PM
oil filter??? whitefrs Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 09-06-2012 07:43 AM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
TRD Air Filter tonystewart Engine, Exhaust, Transmission 16 06-21-2012 12:46 PM
air filter andy19804 Engine, Exhaust, Transmission 9 04-28-2012 03:35 PM
