Old 09-15-2012, 05:02 PM   #1
mechaghost
mechaghost's Avatar
Drives: Silver AT Limited
Visconti vs FA20Club vs Stock Tune Dyno Results
Today I went down to Drift Office LLC in Auburn Washington with a goal in mind, figure out which tune is best for my car.
I have a BRZ Limited AT with an AirRaid air intake. I bought the Visconti Tune from John during the group buy. I also bought fa20Club.com's AT tune. On a side note, I did get to give fa20Club datalogs on street runs, which in turn they came back with a optimized tune for my car.
All the runs were done back to back except for the OEM air intake and and stock tune, which was done around June I believe. These were done in 3rd and 4th gear.
mechaghost is offline   Reply With Quote
The Following 25 Users Say Thank You to mechaghost For This Useful Post:
*KID* (09-16-2012), 20valvewynn83 (11-26-2012), bedabi (06-18-2013), Boost_Junkie (10-26-2012), cmss2000 (09-16-2012), Craig (11-19-2012), Drift-Office (09-15-2012), DSTL (09-15-2012), GaN-MaN (09-16-2012), Guff (09-17-2012), ill86 (09-16-2012), Jesse (01-17-2013), JPxM0Dz (11-16-2012), kidgogeta (11-16-2012), MarkRacerX (09-17-2012), raul (09-18-2012), ShoNUFF (01-18-2013), Spaceywilly (09-15-2012), Sportsguy83 (09-15-2012), Tainen (09-15-2012), travace (09-15-2012), Travis (09-15-2012), tripjammer (09-16-2012), Tylub (10-11-2012), UncleFester (09-15-2012)
Old 09-15-2012, 05:32 PM   #2
TyperRspec789
Version 2 Coming Soon...
TyperRspec789's Avatar
Drives: Turbo Argento FRS, Asphalt FRS
Which Visconti version tune are you running? This is pretty good stuff you posted. The whole board will definitely appreciate this!
TyperRspec789 is offline   Reply With Quote
Old 09-15-2012, 05:44 PM   #3
brewksy
Drives: 2011 Subaru STI
This is where it would be great to compare the actual area under the curve in the range of usable/everyday RPMs. A peak number in this case can be inaccurate of the overall result.
Oh well, as long as people are actually seeing the full graph
brewksy is offline   Reply With Quote
Old 09-15-2012, 05:47 PM   #4
Visconti
Drives: 05 STi
Looks good
Very happy with the results especially if its only a flash and a single pull!
My flashes are setup not to run full advance until a few drive cycles!
Thanks
John
Visconti is offline   Reply With Quote
The Following 3 Users Say Thank You to Visconti For This Useful Post:
20valvewynn83 (11-26-2012), SkAsphalt (01-18-2013), TouchMyHonda (09-17-2012)
Old 09-15-2012, 05:48 PM   #5
Opposed
Drives: 2013 Asphalt FR-S
Agreed. Looks like they both have their pros and cons. Visconti's has the strongest midrange bump, while the FA20Club has a bit more top end from 6500-7500...This is very good stuff, thanks for sharing.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 09-15-2012, 06:00 PM   #6
fenton
Fa20 tune runs pretty lean up top that's why it is making more.
Looks like the airid intake is good for losing HP up top. That is significantly worse than stock.
Sure if Visconti updated his tune for the intake we would see very similar results up top between the two stage 1 maps.
Liking Visconti's midrange
Sent from my Galaxy Nexus using Tapatalk 2
fenton is offline   Reply With Quote
Old 09-15-2012, 06:04 PM   #7
fenton
Airid runs pig rich on the top end stock that's why it is losing power
Old 09-15-2012, 06:34 PM   #8
gmookher
lets get a perrin tune on tehre, youre not far from OR!
The Following User Says Thank You to gmookher For This Useful Post:
Old 09-15-2012, 06:37 PM   #9
Jordo!
Enjoy it, destroy it.
Jordo!'s Avatar
Drives: Datsun Racing Hen
Hmm. Looks like 4th gear stock runs are showing numbers on par with the MT's -- tht's good to see.
Jordo! is offline   Reply With Quote
Old 09-15-2012, 07:07 PM   #10
Zaneman
Drives: 2013 BRZ limited
Thank you Bob. That guy is a champ. Any way you could pull out the two stock runs so we can see just the tunes next to each other?
Zaneman is offline   Reply With Quote
The Following User Says Thank You to Zaneman For This Useful Post:
Old 09-15-2012, 07:17 PM   #11
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
5hp and 2.7tq with a intake and tune? I knew there was a reason why I saw the video of the intake and tuned FRS running the same times as stock.
SUB-FT86 is offline   Reply With Quote
The Following User Says Thank You to SUB-FT86 For This Useful Post:
bimmerboy (09-16-2012)
Old 09-15-2012, 07:20 PM   #12
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I wonder if you have seen videos or Dynos of MT cars instead of AT. MT 93 tune alone has netted 14 HP 10 TQ
Old 09-15-2012, 07:22 PM   #13
SUB-FT86
86 Member
The video was of a MT. When I get this car I won't spend a dime on the engine that's for sure.
Old 09-15-2012, 07:24 PM   #14
Sportsguy83
Drives: Limited BRZ
This Dyno is showing gains on an AT car, the tune works very different for both.
About not spending money on the motor, great for you, more money to spend in other stuff
In Annapolis for the weekend - Get your Visconti Tune! Visconti Mid-Atlantic 6 09-16-2012 10:10 AM
CEL with Visconti tune tjdiz92 Issues | Warranty | Recalls / TSB 44 09-16-2012 04:04 AM
A Question for Those of You WITH the Visconti Tune White64Goat Engine, Exhaust, Transmission 22 09-02-2012 05:27 PM
FA20CLUB.com Stage 1 ECUTEK Reflash Results FA20Club.com Engine, Exhaust, Transmission 20 08-25-2012 07:02 PM
1st Auto with Visconti E85 tune! white devil Engine, Exhaust, Transmission 35 08-22-2012 04:22 PM
