Old 09-15-2012, 03:26 PM   #15
johnb831
johnb831's Avatar
Drives: SWP 2013 Subaru BRZ Limited
looks very nice and clean!
johnb831 is offline   Reply With Quote
Old 09-15-2012, 03:31 PM   #16
zoomzoomers
zoomzoomers's Avatar
Awesome!
Old 09-15-2012, 10:08 PM   #17
xcelir8brz
Drives: 2013 BRZ Limited
The Boyo was $85.00 from Amazon. I believe it was the 200C model. It's made to go into a license plate hole. But, you cut the blue wire to remove the guidelines and cut the white wire if you flip it upside down (like I did). The image is so clear and though it doesn't have IR, in the pitch black it has an extremely vivid and clear picture. Well worth it!
xcelir8brz is offline   Reply With Quote
Old 09-15-2012, 10:22 PM   #18
Furtive
Furtive's Avatar
Drives: 13' SSM BRZ
hmm I'm inclined to try this out but with .http://www.ebay.com/itm/320975791221...witem=&vxp=mtr seems too good to be true lol
Furtive is offline   Reply With Quote
Old 09-17-2012, 09:37 AM   #19
sparks
sparks's Avatar
Originally Posted by sure74 View Post
Used the lines to back in to a spot, car was dead center in the spot. No need to adjust the lines (close enough) since I put the camera where the head unit was expecting it.
The service manual says the "+" should centered 20 inches behind the car.
2013 BRZ Preimum #452 - Sterling Silver
sparks is offline   Reply With Quote
Old 09-17-2012, 09:47 AM   #20
sparks
sparks's Avatar
Reading the Forester owners manual, it says the marks are approximately:
Approx. 10 feet (3 m) from the bumper (green horizontal line)
Approx. 6.5 feet (2 m) from the bumper (green horizontal line)
Approx. 3 feet (1 m) from the bumper (yellow horizontal line)
Approx. 1.5 feet (0.5 m) from the bumper (red horizontal line)
Old 09-17-2012, 10:27 AM   #21
RYU
RYU's Avatar
Drives: really slow...
If the mounting of the cam was places dead center on the trunk lid fascia would the guide marks be skewed? My guess is no, but perhaps someone can confirm.
You can easily notice here that the image and guide marks are skewed already but on my previous vehicles (with oem rear cams) the image isn't skewed even though the cameras are mounted offset to the side.
RYU is offline   Reply With Quote
Old 09-17-2012, 10:34 AM   #22
xcelir8brz
What I did is put a 'brick' behind the bumper on the ground away from my bumper about 24" to where I felt comfortable the red line started. I centered it on the brick edge and the red line via the Radio.
Tested it out this morning where I park and it worked like a charm. Perfect.
Old 09-17-2012, 10:37 AM   #23
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
subscribed cant wait to see other builds thanks op for the idea!
Lee358 is offline   Reply With Quote
Old 09-17-2012, 08:39 PM   #24
BRZranger
WHere are the SVXdc instructions on this how to? Did you have to splice into existing wires or do you use a pin connector?
I think I am going to go w/ the Rydeen Duo, looks OEM.
I did ask the Subaru dealer if they would do the install, but they said it's a mod, which they won't do and it would affect warranty for electronics.
BRZranger is offline   Reply With Quote
Old 09-17-2012, 09:00 PM   #25
Foobar
SLO NO MO
Foobar's Avatar
I've never seen a car warranty affected by installing aftermarket audio/navigation/camera equipment. Your dealer might be misinformed. Which dealer is this?
Anyway, it involves plugging in two wires into the existing stock harness. If your dealer doesn't like that, simply unplug the two leads if you have to bring it in for electrical warranty work. Or wait until SVXdc has a reverse harness/normal harness setup that goes between the stock harness and headunit, although the only thing on the stock harness is one wire that connects to the ebrake sensor, which you can safely just leave unlplugged and just get a replacement 16-pin harness to connect your video cable to.
The Following User Says Thank You to Foobar For This Useful Post:
BRZranger (09-18-2012)
Old 09-18-2012, 08:46 AM   #26
sure74
sure74's Avatar
Drives: 2016 Toyota 4Runner Trail Premium
No cutting, SVXdc's RCA w/ pins plugs right in to the 16 pin plug in the back of your BRZ's nav unit.
SVXdc will send you instructions via email after you purchase the RCA w/pins. He gives you pretty
detailed instructions with links to pictures. The short version is plug the pins in to the harness.
sure74 is offline   Reply With Quote
The Following 2 Users Say Thank You to sure74 For This Useful Post:
BRZranger (09-18-2012), tripjammer (01-29-2013)
Old 09-18-2012, 08:51 PM   #27
BRZranger
Alrighty, just bought the Rydeen Duo and emailed SVXdc for the harness. Looking forward to having this functional mod.
@sure74, did you have to "delete" parking lines from the camera or did they come that way? Hopefully the one I ordered doesn't come with them...
Old 09-18-2012, 09:39 PM   #28
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Great write up. I have the same question as above, is there an option to turn off the lines? With that said, how is the user interface on the stock nav in regards to the camera? What exactly do you press to choose the camera view?
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
DGM BRZ limited on the way? Coheed Member's Car Journals 16 04-11-2013 02:09 AM
My LR BRZ Limited epson1 BRZ Photos, Videos, Wallpapers, Gallery Forum 11 09-08-2012 02:18 PM
BRZ Limited Available JohnATL Southeast 3 08-12-2012 11:32 AM
Want to buy a BRZ Limited AT kgc Northwest 1 06-16-2012 11:45 PM
DGM BRZ Limited (man) available Mitchs_86 BRZ First-Gen (2012+) — General Topics 6 06-14-2012 12:50 PM
