Old 09-14-2012, 10:15 PM   #5447
wrxgoose
WUB WUB
Drives: 2013 Firestorm
needs more boobies. also:
wrxgoose is offline
Old 09-14-2012, 10:22 PM   #5448
Originally Posted by boucher View Post
Are internet memes becoming too popular and overused?
Isn't that pretty much the definition of a meme?
Dadhawk is online now
Old 09-14-2012, 11:04 PM   #5449
wrxgoose
WUB WUB
wrxgoose is offline
Old 09-14-2012, 11:14 PM   #5450
boucher
Leaux Down Krewe
boucher's Avatar
Drives: 2014 SSM Limited
I can just remember a time when memes were like inside jokes for the people of the internet. Everyone on facebook posts memes now and a bunch are bad, and they should feel bad.
boucher is offline
Old 09-14-2012, 11:35 PM   #5451
wrxgoose
WUB WUB
because none of them are origional now. if we came up with some new ones, we could RULE THE INTERNETS! BWA HAH HAH!
wrxgoose is offline
Old 09-14-2012, 11:39 PM   #5452
serialk11r
Drives: '06 AM V8V Coupe
What is the timeframe? One school year?
Yep, more or less.
Originally Posted by Calum View Post
67!!! degrees of overlap, wow, now I understand wanting to a full tooth.
Yeah, as Dimman said, I was thinking of manually phasing the cams, grinding the keyway for a few degrees, or re drilling/slotting the locator pin hole that sort of thing.
With those conditions, I'm actually surprised they didn't just drop the intake back the full tooth and run it anyway. But I'm way out of my league so I'll go back to lurking.
I'm pretty sure the deal is to make any changes you want to have data showing that it actually improved things, and they didn't have time to go testing this sort of thing.
serialk11r is offline
Old 09-15-2012, 01:05 AM   #5453
serialk11r
Just bought the full Torque app, screwed around with the pretty gauges for an hour. lol.
Too bad I don't have a mount for my phone yet, I could stare at this thing all day.
Old 09-15-2012, 01:47 AM   #5454
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Went to my friend's uncle's boss's wife's (maybe aunt. I didn't fully catch it) party. Even tho I wanted to play tekken or sleep, why I went to this party?
Cuz few things:
1. Wanted to see this HUGE mansion... correction, "vacation house" they owned.
2. Food was hella worth it. I ate some much... too bad, I couldn't make it "carry out"
3. Some ppl that came to the party were hella beautiful (different from sexy) & yes, some were dead sexy (jaw dropping sexy dresses).
4. But main thing that convince me going was boss's wife own Porsche Carrera GT. I always wanted to sit in one. she's a Porsche fan & for a dd car, she drives Panamera Turbo.
That was a great night... If I came home w even 1 of those lady, I would be happy... but tekken will do
ichitaka05 is offline
Old 09-15-2012, 08:20 AM   #5455
Calum
That Guy
Drives: 2013 asphalt FRS MT
Ah, understood.
Calum is offline
Old 09-15-2012, 12:57 PM   #5456
girlracer
All I do it study. So nice outside and I'm stuck studying..
girlracer is offline
Old 09-15-2012, 02:30 PM   #5457
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
O HAI! DIS IS BUU! I WAN TO ORDER SOME CHOCORAAATTTEEE
- The Ancient BRZ Sacrament
by Zaku
Guff is offline
Old 09-15-2012, 03:31 PM   #5458
Allch Chcar
Drives: N/A
Injection strategy is port injection, rpm cutoff is 12k (they didn't change the cams or anything to adapt to the restrictor), 14:1 compression ratio, 100 octane race gas (standard for FSAE, no additives allowed ). My guess is the 14:1 compression ratio has something to do with why they run so "lean".
If they were going for max power richer would be better, I know that much. Max power for Gasoline is at least .85-.90, it could change depending on the composition but realistically the Lambda sensor(I hate calling it an oxygen sensor) isn't reading completely accurate values. And the combustion chamber can also unevenly distribute the Air:fuel making lean and rich spots.
I remember a conversation with @WingsofWar that the Lamda sensor was almost worthless for tuning his Rotary, either due to bad placement or what have you, and so he would use exhaust temperatures for tuning. In his case the sensor would read far richer than what it actually was, like 10:1 on a turbocharged engine. Of course this isn't 1:1 with what we're talking, so take it for what it's worth.
GSXR600
Might be an older one, since they mentioned being able to pick up blocks for 400 bucks. Not sure though.
I specifically asked, "I thought usually max power is at 0.9 or so?" The guy told me "well, depends on your setup". Yea not sure what's going on. Apparently a few years ago there was a guy on the team who was an expert at tuning, and the fuel maps he left behind were aiming for about 0.94.
Okay checked gixxer.com, they seem to agree on 13.2:1. Except pump gas is probably a little different from race gas... I think the pump gas stoichiometric ratio (with oxygenates) is like 14.1-14.3? In that case, 13.2 is about 0.93 lambda. Going by the usual 14.7, 13.2 is 0.90. Higher compression may work better on a leaner mix.
Stoichiometric is the same when reading Lambda sensors, 1.0, so don't let the different values confuse you. I'm suspecting that the new guy doesn't know what he's doing as much as this previous guy. You don't shoot for stoich except for emissions. Better power run rich and then lean it until fuel efficiency is adequate. A fuel economy competition would do the opposite. Lean it out until just before power becomes insufficient.
There is an argument for not reinventing the wheel, especially under time constraints, but I'd still test it out since goals change with time. Especially if the E85 rules leave them uncompetitive.
Fuck, I can't keep my numbers straight. Where did 14.3 come from ?
Stoich is 14.8 according to my bike engine book (2008). They hold to the 12 to 13 is optimal for Power on a typical performance bike of the era, but while race tuning it can adjusted leaner for better mixing/charge motion/combustion chamber shape. It's pretty involved, gets into fuel volatility curves and stuff. (Stuff I gloss over. ..)
Also is the fuel a spec fuel, or just can't exceed 100 octane?
Also the race fuel means leaner mixture. I would be tempted to run E85 even with the 19mm restrictor. But it would depend on the other requirements. If they're requiring running same fuel tank size or measuring fuel efficiency, the Race Gasoline might be better but if you're talking max power, better energy efficiency, or better emissions I'd go with E85 over Race Gas.
Are you a 4chan elitist? In all seriousness, I find the popularity of memes to be great IMHO. I use memes all the time to communicate with people of different ages. I can share memes with pre-teen siblings or even my 30 year old uncle and they can pick them up without a problem.
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline
Old 09-15-2012, 04:52 PM   #5459
Dimman
Kuruma Otaku
Dimman's Avatar
@serialk11r
Do these guys often do port work on their motors? Possible for them to fill the intake ports to increase intake velocity everywhere since overall flow potential is choked we don't have to worry about them being big enough to reduce high rpm friction.
Maybe.
Because titanium.
Dimman is offline
Old 09-15-2012, 04:59 PM   #5460
S2kphile
Resident HoneyBadger
S2kphile's Avatar
Drives: Toyota Tacoma TRD Off-Road
I'm thinking of getting the Razr M, Gallaxy S II or III, what would you choose?
S III because I like the ability to ROOT and customize my tech gadgets to my liking.
Cuz few things:
TFTI MAN...If you had me as a wingman you wouldn't have had to play with your joystick alone.
USC vs STANFORD in a couple of hours. Gotta get me some sunblock. YEee!
Walk like a King, Be like a Sir, Swag it out like a Boss
S2kphile is offline
