Old 09-14-2012, 09:51 AM   #57
fred_boosted
fred_boosted's Avatar
Drives: 2008 EVO X GSR (Sold)
Originally Posted by jamal View Post
No, bleeders are not on the bottom otherwise he couldn't bleed the brakes. His calipers are on backward so the pistons are in the wrong order.
What about change the bleeder's location like OP said?
Will that be better?
I could get Maserati Quattroporte or BMW M3/M6.
But I gived up.
Why? Because thats just not my style.
fred_boosted is offline   Reply With Quote
Old 09-14-2012, 02:51 PM   #58
jamal
jamal's Avatar
Drives: Legacy GT
Yeah that's what you should do. unbolting them and flipping them over to bleed works too. Just don't bolt them on the wrong sides.
jamal is offline   Reply With Quote
Old 09-14-2012, 05:46 PM   #59
RYU
RYU's Avatar
Drives: really slow...
It takes air bubbles a good while to float to the top i'd assume. So, you're going to unbolt the wheels. Unbolt the calipers. Flip them upside down. Hope the air bubbles float to the top while maneuvering thru internal crevices. Then bleed? It just doesn't sound ideal to me.
$0.02.
RYU is offline   Reply With Quote
Old 09-14-2012, 06:32 PM   #60
wootwoot
Drives: FRS
I could be wrong, but EBD will not solve all of your brake bias problems, especially at the track under hard braking. Maybe one of the other brake gurus can chime in.
- Andrew
The brake gurus seem to be leaving this thread alone... Come forward cowardly lurkers!
The Following User Says Thank You to wootwoot For This Useful Post:
brianL. (07-15-2014)
Old 09-14-2012, 08:40 PM   #61
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
Not a brake expert, nor coward. But this works.
Originally Posted by kiks View Post
You can bleed the brakes easily if the bleeders are on the bottom.
Just unbolt caliper, throw a bit of wood in between pads, and bleed them, bolt them back on once complete.
Takes 5 extra mins.
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline   Reply With Quote
The Following User Says Thank You to Floggin Tires For This Useful Post:
cebul (08-21-2016)
Old 09-15-2012, 10:13 AM   #62
kiks
Drives: V12
Bubbles dont 'work' their way around. You just put a bottle of fluid through and bleed them properly. High pressure release and close before bottom of pedal stroke = high velocity fluid = no bubbles.
kiks is offline   Reply With Quote
Old 09-15-2012, 10:46 AM   #63
Turbowned
Turbowned's Avatar
Of course my friend is parting out an '05 STi as we speak, and I don't have a BRZ yet to get the brakes on... arg!
I've got a mean set of Porsche Brembos lying around, but they're for a Cayenne and are wayyyy too big to fit under stock wheels. Not to mention wayyyy overkill
Old 09-15-2012, 07:44 PM   #64
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
^ lol what a tease.
TouchMyHonda is offline   Reply With Quote
Old 09-15-2012, 08:23 PM   #65
sdwztofu
Drives: FR-S, 06 evo9 SE, 84 e30 bmw
Phil came and said his peace and provided useful info. Take it or leave it but I would go with what he says since he is the only one in this thread with first hand experience with this brake set up on this car. Others are just speculating about improper brake pad wear (not saying they are wrong either but if someone whom has actually done it and been quite successful with it and says there are no noticeable issues yet I tend to believe him). As stated numerous times in this thread a system designed for this car would be the best route but if you have some sti brembos laying around or can get them cheap from a friend it is definitely an upgrade worth doing and not hard to do.
2013 whiteout fr-s -havent decided
2006 graphite gray evo 9 SE- track car build
1984 black e30 BMW- daily
2003 white wrx - wife
2010 rotor glow evoX-508 whp track monster-sold
sdwztofu is offline   Reply With Quote
The Following User Says Thank You to sdwztofu For This Useful Post:
Old 09-16-2012, 12:14 AM   #66
jamal
jamal's Avatar
Drives: Legacy GT
Phil's calipers are on backward so I wouldn't consider him a brake guru.
Old 09-16-2012, 12:58 AM   #67
wootwoot
Drives: FRS
lol.
Old 09-17-2012, 02:38 PM   #68
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
And you are only giving an opinion. You are offering advice based on zero experience running an STi Brembo setup on an FRS/BRZ.
I have the so called properly engineered StopTech kit on my STi and the brakes pads wear unevenly so I guess they got the pistons wrong.
If I listened to every piece advice I've gotten from experts and non experts I would be just as slow as everyone else.
Like I said, listen to whoever you want but make sure who you listen to, has more than just an opinion!
Element Tuning is offline   Reply With Quote
The Following 7 Users Say Thank You to Element Tuning For This Useful Post:
2013GTRNate (02-21-2016), brianL. (07-15-2014), Dustin (02-20-2013), SomeoneWhoIsntMe (07-16-2014), Spartan65 (09-20-2012), TouchMyHonda (09-17-2012), Trap63 (10-02-2013)
Old 09-17-2012, 02:53 PM   #69
Element Tuning
Oh and by the way I'm not against running the pistons in the orientation they were designed by swapping the bleeder. In my case I knew that attempting to swap the bleeder was likely to end in a useless caliper. My Brembo setup has been thoroughly abused.
I had this problem earlier this season with my Willwood setup on my Legacy GT. It snapped off the day I was leaving for my race. I was lucky to be able to extract the broken bleeder!
The Following 3 Users Say Thank You to Element Tuning For This Useful Post:
2013GTRNate (02-21-2016), brianL. (07-15-2014), TouchMyHonda (09-17-2012)
Old 09-17-2012, 03:04 PM   #70
RYU
RYU's Avatar
Some of the folks on here need to learn to be quiet and just read. Please take the advice and testimonials from people who actually race instead of driving them out of the forums since a lot of times they have no vested interest in commenting. I've seen this many times when the guys that race have useful input (sometimes right, sometimes wrong) get driven out because they don't want to put up with the BS. In almost all cases they are all still useful info right or wrong. At the very least, they are useful in knowing what not to do for your setup. If you guys want to hear yourselves talk please do it elsewhere because there are guys like me who actually want to hear more testimonials about this cheap STi caliper swap.
Element Tuning - Not saying you're right or wrong but your lap times and video seems to point in a general direction in which i'd listen to your comments. Thanks for sharing your experiences. What has been your solution for the rears?
The Following 3 Users Say Thank You to RYU For This Useful Post:
brianL. (07-15-2014), chanomatik (07-23-2013), sdwztofu (09-17-2012)
How long will my brakes last? pinoyplaya Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 08-25-2012 12:21 AM
OEM Brakes? marinjim Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-20-2012 11:26 PM
GT brakes jello AUSTRALIA 2 06-10-2012 10:10 AM
Anyone confirm the price with their dealer yet? rcubid Scion FR-S / Toyota 86 GT86 General Forum 3 04-27-2012 05:52 PM
November 13 is confirm the day of the release of the final production guys =) XxelluxionxX Scion FR-S / Toyota 86 GT86 General Forum 3 09-13-2011 01:01 PM
