Old 09-13-2012, 04:13 PM   #43
wootwoot
Drives: FRS
Originally Posted by No Limit Motorsport View Post
I haven't tried it yet... but Evo brembo's are mounted the same way the BRZ calipers are. I am guessing they will be straight bolt on, no bleeder swap necessary.
That sounds legit...
Old 09-13-2012, 04:28 PM   #44
gmookher
Originally Posted by RYU View Post
What is the stock front/rear brake bias on the STi? What is it on the BRZ? If someone knows please share! Thx
That's the most important question if you guys are actually doing this for performance (not just bling).
its not as easy as slapping parts that happen to fit to design a brake system that works correctly
getting into an accident with one off home made solution is all an insurance adjuster needs in a fatal accident to have a field day. without bias adjustment, this could be a downgrade rather than an upgrade, in an ABS car
that said, awesome job and looks great
how does it stop?? slide? lock up? do tell!
I want me some! but would want the bleeds in the right orientation for faster trackside repairs
Old 09-13-2012, 04:48 PM   #45
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
I'm not going to attribute this to the Brembo brake swap alone but I'm killing these guys under braking
If you want to know more about our FRS at the Ultimate Track Car Challenge look here:
http://www.ft86club.com/forums/showthread.php?t=12453
I did the Brembo swap because I had them laying around since the Brembos are completely inadequate on a full race STi. On the FRS they work very well.
Now I didn't want to risk trying to pull the plugs out of the heat battered aluminum calipers so I swapped them left to right. This does alter the piston orientation but from the drivers perspective you can't tell the difference. In the long run there is a chance the pad will not wear as evenly but only time will tell.
As for bias this is an EBD car so it doesn't matter, it's computer controlled and therefore will deliver/reduce power where needed. Like any car that uses a Big Brake Front you need to run at least the same friction compound or better in the rear since you now have more leverage due to the larger front rotor.
With ABS on brakes are great, predictable, strong, and trail braking was fine. With ABS off the fronts lock up first but I would think that's the case even OEM.
With that said I would never buy these Brembos new over some other track oriented products. Race pads are super expensive, the calipers aren't that good, they over heat, but hey I'm not your average user I've been talking with the guys at Essex about their kit but we'll see what I settle on for racing.
Thanks,
Phil Grabow
Element Tuning is offline   Reply With Quote
The Following 4 Users Say Thank You to Element Tuning For This Useful Post:
2013GTRNate (08-30-2013), dori. (09-13-2012), mrha (09-14-2012), RYU (09-14-2012)
Old 09-13-2012, 05:39 PM   #46
jamal
jamal's Avatar
Drives: Legacy GT
I bet there is already noticeably uneven wear on those pads.
jamal is offline   Reply With Quote
Old 09-13-2012, 06:15 PM   #47
Racecomp Engineering
I could be wrong, but EBD will not solve all of your brake bias problems, especially at the track under hard braking. Maybe one of the other brake gurus can chime in.
- Andrew
Old 09-13-2012, 06:32 PM   #48
jamal
jamal's Avatar
Drives: Legacy GT
EBD only works during abs engagement. So unless you are just slamming on the brakes and letting abs do the work on track your bias is going to be off.
And stoptech for example sizes the pistons on their kits to not alter the brake bias.
Old 09-13-2012, 06:54 PM   #49
tomt5078
tomt5078's Avatar
P and L's BRZ has some on the front..............Saw it at a car show over the summer!!!!!
tomt5078 is offline   Reply With Quote
Old 09-13-2012, 09:19 PM   #50
Element Tuning
This is when I say listen to the guy who races with the stuff and has lap records, wins, and championships. The stoptech changes bias massively and the Brembo also changes bias on the FRS, I never said it didn't. On the FRS it's just a non issue but it's a significant issue on my STi as I can't get enough rear brake and it's a problem I have been working on.
Most of the newer Subarus do not have a brake bias valve anymore it's free flow to the rear. You will have more bias to the front if you have a larger rotor and more pad contact. Brake experts can be picky about their terminology so I'm going to say it's really more brake torque up front vs. Rear.
As for pad wear after two races I can't see any abnormal wear issues. All I notice is that my car is 8 seconds a lap quicker and it stops faster Tested and proven faster so if you want to go faster get bigger brakes (and sticky tires or it doesn't matter).
Old 09-13-2012, 09:33 PM   #51
fred_boosted
fred_boosted's Avatar
Drives: 2008 EVO X GSR (Sold)
This when I say listen to the guy who races with the stuff and has lap records, wins, and championships. ....
Thanks for feedback!
Did you retrofit the rears too?
I could get Maserati Quattroporte or BMW M3/M6.
But I gived up.
Why? Because thats just not my style.
fred_boosted is offline   Reply With Quote
Old 09-13-2012, 09:48 PM   #52
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
This when I say listen to the guy who races with the stuff and has lap records, wins, and championships.]
If you guys don't believe him go on the NARRA time trials website and look at this guys track times versus the competition. When Phil has advice to give, keep quiet, and listen.
No Limit Motorsport is offline   Reply With Quote
The Following User Says Thank You to No Limit Motorsport For This Useful Post:
Skye (09-14-2012)
Old 09-13-2012, 10:10 PM   #53
jamal
jamal's Avatar
Drives: Legacy GT
Well, I have seen the uneven wear from not having the right piston differential sizing first hand, so, in conclusion, installing sti brembos without swapping the bleeders is a terrible idea.
Also, I am associated with a couple of fast cars and track records. I just don't see how that's relevant to completely screwing up the brakes. A good test would be to go back to the stock tires and alignment and see if the car is still faster.
Old 09-14-2012, 02:02 AM   #54
mrha
#1819
mrha's Avatar
Drives: Lightning Red Subaru BRZ
Thanks,
Phil Grabow
So are your bleeders on the bottom then? Thanks for the info Phil!
mrha is offline   Reply With Quote
Old 09-14-2012, 03:03 AM   #55
jamal
jamal's Avatar
Drives: Legacy GT
No, bleeders are not on the bottom otherwise he couldn't bleed the brakes. His calipers are on backward so the pistons are in the wrong order.
Old 09-14-2012, 08:51 AM   #56
kiks
Drives: V12
You can bleed the brakes easily if the bleeders are on the bottom.
Just unbolt caliper, throw a bit of wood in between pads, and bleed them, bolt them back on once complete.
Takes 5 extra mins.
kiks is offline   Reply With Quote
How long will my brakes last? pinoyplaya Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 08-24-2012 11:21 PM
OEM Brakes? marinjim Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-20-2012 10:26 PM
GT brakes jello AUSTRALIA 2 06-10-2012 09:10 AM
Anyone confirm the price with their dealer yet? rcubid Scion FR-S / Toyota 86 GT86 General Forum 3 04-27-2012 04:52 PM
November 13 is confirm the day of the release of the final production guys =) XxelluxionxX Scion FR-S / Toyota 86 GT86 General Forum 3 09-13-2011 12:01 PM
