#57 | |
Drives: 2008 XRunner
But that does not invalidate my point. Reducing lift doesn't create downforce. That's like saying that reducing the amount of pulling suddenly creates pushing. The coeffecient of lift doesn't become downforce until it reaches a negative number. Same type of force different application. Hence the different names. If it was as simple as you say it is, we wouldn't call it downforce just negative lift. In which case you would be right. But as it stands now, you can add a spoiler, add downforce and do nothing to address the issue of lift under the car. Therefore the amount of lift is the same, but you are counteracting it with a greater amount of downforce than before. Making the lift you do have less effective. Excuse me, I was thinking of Drag as the physical car moving through the air, as in a blunt object vs. a pointed one. A brick and an Arrow for example. I was confusing the turbulent air behind the vehicle being smoothed out as something else. But you're right it is in fact drag.
“From the beginning, the concept was to put the driver back in the driver’s seat, and to eliminate computers as much as possible today. Powerful sports cars use a lot of computer technology so that anyone can drive and handle them. We decided not to go down that road.” - Tetsuya Tada
#58 | |
Drives: '06 AM V8V Coupe
oops you guys posted while I was typing that. well it still applies. Last edited by serialk11r; 05-24-2011 at 03:15 AM. |
#59 | |
Kuruma Otaku
From a physics point of view you are only dealing with a single force: Lift. The engineers do call it negative lift. You can't actually 'add' downforce if the overall vehicle CL is still positive after the change, it is reducing lift.
Because titanium. |
#60 | |
100 pound springs for instance move 1 inch for everyone 100 pounds applied. In a car moving it creates 100 pounds of lift. Effectively making the car 100 pounds lighter. The springs raise 1 inch. When the car is static the springs sit level. Now you add 100 pounds of downforce. You haven't reduce the lift it all because it is still in effect under the car. The springs stay at the same height because effectively you have canceled out the force of the lift with a separate and opposite force. Add 200 pounds of downforce, the springs will move 1 inch because you still have 100 pounds of lift in effect. You are overpowering the effect of the lift, but it's still working it's magic on the car. Remove the lift and add 200 pounds and the springs move 2 inches down effectively making the car 200 pounds heavier (in terms of force applied on the springs). Till the car returns to a static position in which no forces are being applied to it. Other than it's own weight and gravity. So I don't see you can say that reducing lift is akin to creating an opposite force on the car. Just because you have reduced lift, does not mean you have created an opposite force. You have created a static position. It's like spending less. It doesn't mean you're earing more, it just means you can put more in the bank. So you'll have to show me some literature where it says that reducing lift = creating downforce. I would be very interested in reading that.
#61 |
Did 2 of my posts seriously get ignored? I said that it depends on how you make modifications to the car, but there is a net force on the car and whatever you do changes it in one way or another. So it doesn't matter. However when you usually "create downforce" you are adding bodywork that has the effect of pushing down while not affecting other aspects of aerodynamics.
#62 | ||
Kuruma Otaku
It is a single force. It is simply called 'downforce' when lift is negative. From 'Competition Car Downforce' by Simon McBeath: Quote:
Same thing. Downforce is only when the lift is negative. Enough that the force of lift pushes down on the car...
Because titanium. |
#63 |
Registered you sir
Drives: 99 impreza coupe
Adding bodywork always has multiple aerodynamic effects.
#64 |
Sorry what I was trying to get at was, if you add say a wing, the wing has relatively little effect on the overall flow of air over the body. But I guess that's not bodywork lol...woops. The other thing would be like, if the sides of a car are shaped to channel air in some way, that may not have much effect on the flow of air over the top of the car. What ToyotaObsession and Dimman are arguing over is terms which are more or less arbitrary.
#65 | |
Kuruma Otaku
Because titanium. |
#66 |
That's what I meant, the terms are just describing vertical component of force on a car, with a sign flip. He seems to think they are independent.
#67 | |
I think an object in motion can have several forces working upon it at the same time in different areas. Changing the underbody won't affect forces on top of the car and vice versa.
| Scion FR-S / Toyota FT-86 / Subaru with Aggressive Body & High Wing! + VIDEO! | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 538 | 06-15-2011 02:20 AM |
