Old 05-22-2011, 11:45 PM   #29
NESW20
2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
another update regarding the high-idle issue. my TPS sensor will not calibrate into spec, and it appears to be the problem with my idle. spec is .4-.5V and mine will only adjust down to 1.6V or so.
i tested my coolant temp sensor, and it changed resistance according to spec, and has good power and ground. what i did notice was some corrosion buildup on the terminals on the ECTS and the harness connector. i cleaned the corrosion off and it seems to be working properly now.
so it looks like i'll have to spend another $80 on a new TPS in addition to the $80 headlight switch. still fixed it right up for under $400, and it runs SO MUCH better now than when i got it, there's no comparison. completely different car now.
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs
1990 240SX Coupe - sold
2008 Civic Si Sedan
NESW20 is offline   Reply With Quote
Old 05-22-2011, 11:53 PM   #30
NESW20
2.1L 3SGTE
Originally Posted by NikostC View Post
Nice man ! time for a SR20DET swap a set of coilovers and engine management and your good to go!
it'll be a while before i think about swapping it, but it's in the plans for down the road. i'll probably stick with a stock ECU, just because i want the factory reliability and driveability. my MR2 has an AEM EMS and while it is super handy, i don't plan on heavily modding the SR20 when it goes in.
my MR2 still takes priority, and will continue to do so until it's "finished." :happy0180:
2008 Civic Si Sedan
Old 05-23-2011, 07:16 AM   #31
Abflug
Abflug's Avatar
Drives: MR2
YAY
Abflug is offline   Reply With Quote
