#71 | |
Drives: really slow...
![]() I'm not in a huge rush but if anyone knows where one can get another "wiring kit" I'd really appreciate it! |
#72 | |
Drives: 2013 BRZ Limited
I have a 6AT Limited, and am not happy about this. I truly think it might have to do with the RADIO Firmware version. This is what I got under the 'Unit Version Information' screen: Manufacturer Name: Fujitsu TEN Version: 44.103 12/04/1 CD DSP Version: 1.04 Can you guys check with yours and see if there is a comparison? THANK YOU! |
#73 | |
SLO NO MO
I'll check the head unit version info tonight after work and let you know. |
#74 |
SLO NO MO
Oh and just to rule it out - you definitely have the e-brake line grounded on the 16-pin right? Doubt that's causing your problem, but that's one other thing that I did on mine.
#75 |
E-Break is good. The Info screen proved that when I did this mod when I installed my Amp/Sub.
Thanks! |
#76 |
SLO NO MO
This is from my software version screen:
Navigation: 16:24/17.04 9.2.2.230646 Audio: 04,17,2012 Ver.44.1003 |
#77 |
the tuna, no crust.
Drives: 2014 Hachiroku of the year
so is this the only sure way to bypass the lockout? ground the e-brake wire, and then put a switch to this gps signal or w/e it is wire? i'm tired of waiting to stop to put anything into the nav.
#78 | |
Drives: 2013 BRZ Limited SWP
I'm assuming the GPS notices the car is moving and locks the user out, even when the car is not running.
Past Subarus: 08 STI, 05 Legacy GT, 98 Legacy L wagon, 97 SVX LSi
Daily Driver: 2013 Acura MDX |
#79 | |
SLO NO MO
Sent from my Galaxy Nexus using Tapatalk 2 |
| The Following User Says Thank You to Foobar For This Useful Post: | TSY (10-25-2012) |
#80 | |
Radio wiring harness guru
Drives: 1996 SVX L AWD
What is the model number printed on the front of your factory HU? Same question -- what is the model number printed on the front of your factory HU? I'm wondering if later models switched to using GPS. ADDED: You both should also look up the firmware version on the diagnostics screen. EDIT: Not diagnostics screen. See my next post.
#81 | |
SLO NO MO
Let me know which screen you want me to get (let me know the button sequence to get to it as well to make sure I'm looking at exactly the right info). |
#82 | |
I'll check the version tomorrow.
#83 |
Thanks for the update!
#84 |
I checked my HU today.
Model: FA601US Nav: 15:50/30.07 9.2.2.250040 Audio: 08,07,2012 Ver.44.1004 So it does appear I have a more updated version of the HU's firmware.
| DIY Nav unit in FRS with e-brake bypass and iPhone cable by cupholders | Nitro | DIY (Do-It-Yourself) Guides | 42 | 07-02-2016 11:10 AM |
| Name that spoiler! (SOLVED) | WingsofWar | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 70 | 12-06-2014 01:22 PM |
| BRZ NAV/DVD bypass | Scooby South | Electronics | Audio | NAV | Infotainment | 88 | 02-24-2014 03:41 PM |
| how I solved my gilrfriend's problem with headrest angle | alexmotrix | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 08-08-2012 08:00 AM |
| Drove the 86GT and NC miata back to back on GT5 | Hanzo | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 39 | 01-07-2012 12:56 PM |
