Old 09-10-2012, 07:23 AM   #113
xcelir8brz
Drives: 2013 BRZ Limited
Still nothing works. Hmmm. Pin 17. Color pink. Right?
xcelir8brz is offline   Reply With Quote
Old 09-10-2012, 08:41 AM   #114
Foobar
SLO NO MO
Foobar's Avatar
Pink with a green stripe. I've tested this with navigation input, DivX movie playing, and going into settings while the vehicle was in motion. I did not test phone input - maybe that uses an additional nanny signal? Try some of these other functions.
Old 09-10-2012, 09:17 AM   #115
xcelir8brz
Originally Posted by Foobar View Post
None of the other options did anything for me. I could adjust them but they don't affect the rearview camera display.
I don't think I tried scrolling it out completely, let me give that a shot.
I tried everything regarding this and no go. Stuck with the lines.
Old 09-10-2012, 09:19 AM   #116
xcelir8brz
Maybe it's the radio's firmware? Yup, I used the correct wire, cut it, and put a toggle serially in the middle. Hmmm...
Old 09-10-2012, 09:23 AM   #117
xcelir8brz
I ended up ordering the VTL425 from Amazon. Then I changed the mine and ordered this instead VTK200C:
http://visiontechamerica.com/site/portfolio/vtk200c/
I figured I'd mount this in the OEM location and then wouldn't have to worry about the lines as it would be damn near exact. Was cheaper than the VTL425 also.
I decided that when I receive this, I'll mount it in place of the left (drivers) side license plate screw location. Ill also swap out the right (passengers) side license plate screw location with a bolt. This will keep it the most clean rather than spending time mounting it OEM and that's a permanent change. Hmmm. We'll see when I get it, but that's the plan for now and what this product was intended for.
Old 09-10-2012, 09:35 AM   #118
Foobar
SLO NO MO
Foobar's Avatar
So with the toggle off, your menu shows the phone/settings/video available while stopped, but as soon as you start moving, it becomes disabled? If so, that would indicate to me that the vehicle speed sensor signal is not disconnected. Try it without the switch, leaving the wire completely disconnected?
Only thing else I have done is grounded the e-brake line on the 16-pin, but that shouldn't be necessary for phone/navigation/settings. That's only used for video playback as far as I know.
Old 09-10-2012, 01:20 PM   #119
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
I double checked today and mine does do phone also.
Flat Black VW is offline   Reply With Quote
Old 09-11-2012, 12:19 PM   #120
sure74
sure74's Avatar
Drives: 2016 Toyota 4Runner Trail Premium
That's the Rydeen Duo, right? Let me know how that works out for you
Just posted some pics on the camera installation:
http://www.ft86club.com/forums/showthread.php?t=17020
sure74 is offline   Reply With Quote
Old 09-15-2012, 12:55 AM   #121
xcelir8brz
Just replaced the Pyle license plate cyborg camera with a Boyo. Looks 100x better and stock! Adjusted the backup lines as well.
Take a look:
Old 09-16-2012, 04:19 AM   #122
Furtive
Furtive's Avatar
Drives: 13' SSM BRZ
i just bought a boyo vtk360 .. hopefully it will work.. specs on it seem a little bit better than the boyo you bought xcelir8br
..also which link on ae64 is the right cord for the brz ?
Furtive is offline   Reply With Quote
Old 09-16-2012, 04:45 AM   #123
Furtive
Furtive's Avatar
Drives: 13' SSM BRZ
(use an add-a-circuit to tap into power).
which fuse should I tap into?
Old 09-16-2012, 08:57 AM   #124
Foobar
SLO NO MO
Foobar's Avatar
Whichever's convenient and driven off of ACC, not always live or you'll kill your camera sooner. Just use the same amp fuse rating on the bottom slot of the add-a-circuit, since that replaces the functionality. The top slot goes to the new circuit.
I used the seat heater fuse.
Old 09-16-2012, 10:09 AM   #125
xcelir8brz
But where are you going to mount it? It requires a large hole.
Old 09-16-2012, 01:50 PM   #126
Furtive
Furtive's Avatar
Drives: 13' SSM BRZ
I was thinking the original camera location.. (i didnt see the size specs on it.. but I hope fits) if not. I may just return and get something like yours.
Did you use SVXdc wires?
What will you hang from your rear view mirror? Dillano609 Scion FR-S / Toyota 86 GT86 General Forum 148 11-15-2013 02:52 PM
Zoom Engineering Rear View Mirrors Kami Speed Interior Parts (Incl. Lighting) 13 07-17-2012 02:18 PM
Taking rear view mirror off ? JB1 Cosmetic Modification (Interior/Exterior/Lighting) 7 06-21-2012 09:53 AM
Rear view Mirror pic nixeighty6 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 45 01-27-2012 05:10 PM
