CANADA Canada
Old 09-05-2012, 02:38 PM   #29
stanm
stanm's Avatar
Drives: 2013 Asphalt FR-S 6MT
I've been averaging 8.x L/km (see my fully signature)
Almost entirely city driving
stanm is offline   Reply With Quote
Old 09-05-2012, 04:21 PM   #30
Ahz
Drives: None
Originally Posted by dnr View Post
any idea on how many liters left when the tank signal turn on ?
I ran it down pretty good the other day, the light came on and I kept going and going. After filling out it looks like there is about 10L left when the light comes on. I ran it past the E and it got a bit scary on the highway when I thought I would run out of gas with the needle buried like that, but when I topped up I had about 4.25L left.
About 8L/100km avg, mostly city and some aggressive/spirited.
Ahz is offline   Reply With Quote
Old 09-06-2012, 10:53 AM   #31
dnr
dnr's Avatar
Drives: fr-s
that was good
I average 8.5 l/100km
Mine went on and drove for another 25-30km and filled up 46.5 L
so 3.5 left? assuming a 50 L tank
dnr is offline   Reply With Quote
Old 09-06-2012, 11:32 AM   #32
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Originally Posted by ymboc View Post
To Clarify Further... modern engines (since ~2000 & earlier in the case of toyota) have the ability to cut the fuel to the engine when coasting in gear. The whole thing is simply termed 'fuel cut' and was introduced to improve gas mileage.
Basically the ecu knows when you've removed your foot from the accelerator, that you're in gear and that the car is traveling at sufficient speed (& engine rpm) that the momentum of the car will keep the engine (& all its accessories) turning over without having to inject fuel to keep combustion going.
If the rpms drop enough (to the point where you'd otherwise stall), or you step on the accelerator or clutch, the engine instantaneously starts injecting fuel again, combustion resumes and everything works as it should.
If you pay close attention to the car you can often 'feel' when the fuel cuts out and when it kicks in again.
I understand coasting in gear gets better mpg and why, but what about distance traveled? When in gear you don't pick up as much speed and don't accelerate as fast I'm assuming because of the add load the engine is under. So if going downhill to flat ground you could travel longer out of gear, yet at worse gas mileage. Which one is better in the long term? Idling doesn't use a ton of fuel.
I personally stayed in gear until I started slowing and then took it out to coast farther fwiw.
Old 09-06-2012, 01:53 PM   #33
jstn
Drives: '15 Vortech Supercharged
Apparently I drive my car really hard. I think I get 300ish miles before the light comes on.
jstn is offline   Reply With Quote
Old 09-08-2012, 07:02 PM   #34
l8apexr
l8apexr's Avatar
Drives: hybrid + racecar + FR-S
sbrm getting 5.7 is amazing!!!!! wow!
Team Lexus IS300 race car
'14 Lexus RX450h Sport Design daily driver
'14 FR-S fri/sat/sun car: SARD LSR wing, Downforce front lip, Mann Engineering dampers, TRDsways, Milltek xhaust, AEM Intake, RAYS 57xtreme, OnPoint Dyno ECUTek tuned: +30rwhp!
l8apexr is offline   Reply With Quote
Old 09-09-2012, 04:12 PM   #35
ANTiSOViET
ANTiSOViET's Avatar
Drives: 2013 Scion FR-S Ultramarine 6AT
Just back from travelling, but the best tank I've gotten was 5.7l/100km that happened on a trip into the interior of BC, so some spirited driving, a lot of up and downs etc.
Average tank for me lasts about 625km. My commute is 90% highway.
To the guys that are only getting 10l/100km what the hell are you doing on the road? I get over 10 when I am stuck in stop and go or trying to put in a hot lap. I can't imagine getting that on a regular basis and feeling anything other then anger.
Once I went fast.
Now its all I want to do.
ANTiSOViET is offline   Reply With Quote
Old 09-09-2012, 04:51 PM   #36
smbrm
smbrm's Avatar
Drives: Scion FRS Ht Lva(AT)
I thought so too!
smbrm is offline   Reply With Quote
Old 09-09-2012, 11:22 PM   #37
l8apexr
l8apexr's Avatar
I'm getting close to 10L/100km. But I'm always trying to put in a hot lap!
Gas mileage for first tank terrypm Scion FR-S / Toyota 86 GT86 General Forum 28 01-23-2017 03:10 AM
Dynosty Pushing the Limits... Fuel Pump and Clutch Dustin@Dynosty Engine, Exhaust, Transmission 29 08-15-2012 07:53 PM
Dealer Limit blackfireball5 Scion FR-S / Toyota 86 GT86 General Forum 12 06-29-2012 10:25 PM
Anyone else have problems with their windows after pushing the car too hard? track_warrior Scion FR-S / Toyota 86 GT86 General Forum 9 06-22-2012 12:39 AM
