Drives: waiting on a 2021...
Rear camber adjustment options?
So what are the options available for adjusting the rear camber on the BRZ/FR-S? I know Whiteline makes an adjustable bushing kit, anything else? Either current or in the pipeline? I thought I saw Eibach may be coming out with something?
#2 |
Conedancer
Drives: 2013 Subaru BRZ SWP
Cusco and few others offer Rear control arms with adjustment...that and the rear is very ride height dependent on Where it would be for camber..
Join my BRZ/FRS FB Group ![]() Thanks to:Kartboy/Wheeldude/Nameless Performance /Gaurd Transmission LSD |
#3 |
Drives: @redline, '14 BRZ, '98 Forester
#4 |
#5 |
Drives: Pearl BRZ Limited
SPC makes a rear control arm that is super easy to adjust. I have owned several differant brands on my 09/11 STi and they were the easiest.
Yes, they are listed for a 08+ STi/WRX but they share the same rear control arms. http://www.spcalignment.com/componen...AFrom&to=USATo Also if you are interested: http://www.ft86club.com/forums/showthread.php?t=16641 |
#6 | |
Drives: BRZ Limited
![]() here is a pic of the arm adjustment parts apart |
#7 |
drool...
#8 |
Boosted
Drives: Sideways
Good lord. I only paid $150 total for both of my rear camber arms including the bigger bolts on my 370Z. What a ripoff we've got currently.
Sent from my Nexus 7 using Tapatalk 2
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
#9 |
Drives: 2013 FR-S Matte Orange
I agree. Not much out there and the prices are outrageous. I mean to get a setup that allows good adjustment we are currently looking at a grand if you want front camber plates, rear control arms, and the whiteline rear bushing camber bolts while your in there.
#10 |
I considered rear camber arms, but right now I'm at -2.5 degrees in the rear, which appears to be w/in spec.
I also considered roll center adjustment, but I just got my alignment... |
#11 |
Boosted
Drives: Sideways
I believe the maximum in spec is -1.75 in the rear. At 2.5 you will definitely see the inside parts of your tires wear substantially faster than the middle. You won't even notice any wear on the outside. That is unless you are tracking the car of course.
| The Following User Says Thank You to Synack For This Useful Post: | BRZranger (09-08-2012) |
#12 |
Drives: 2013 FS FR-S
Don't want to spend $500 for adjustable arms so I'm making my own...
![]() I'll start a thread next week when I make some progress...
Robbie S.
-13 FR-S -12 H-D 48 Instagram: @twincamrob ![]() |
#13 |
Grip>Drift
Drives: FRS
After lowering my car on KWs I wound up at -1.9 on one side and and -2.0 on the other.
#14 |
Drives: Rx7
There are alot of features on GTSPEC that are not available through SPC/Eibach or even the cheapo made it urself camber arms.
To list a few 1. Up to -6 degree camber 2. Camber joints are CNC cut out instead of normal stamp out. 3. It's made out of chromely steel and spray down with anti rush protection coating to prevent rush during the winter where salt and weather will rush regular steels. 4. GTSPEC also made the toe arms to work with the camber arms. Toe arms will be needed if more camber needed. |
| power steering feel adjustment | brillo | Engine, Exhaust, Transmission | 29 | 11-06-2017 03:41 PM |
| Bushing upgrades, geometry options and other component options? | der_rainman | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 06-26-2013 12:53 PM |
| BRZ front camber adjustment confirmed | sparks | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 03-28-2013 10:17 PM |
| Clutch Pedal Engagement Adjustment | denverizzles | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 07-25-2012 05:01 PM |
| Gearing Options and Diff options | airboy808 | Engine, Exhaust, Transmission | 26 | 12-25-2011 01:11 PM |
