Old 09-05-2012, 12:10 PM   #15
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
That's awesome. Any plans for 3" piping on an exhaust like the Magnaflow?
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
Old 09-05-2012, 12:17 PM   #16
VSGTS14
987 Motorsports
VSGTS14's Avatar
Drives: '13 WO FR-S
3" is too much for a car of this nature. unless it's FI.
sounds awesome!!!
VSGTS14 is offline   Reply With Quote
Old 09-05-2012, 01:22 PM   #17
AVOturboworld
We will have 3" available for the turbo kit builds.
Old 09-05-2012, 01:33 PM   #18
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
sounds mean!
is that 2,5" OD tube version? to which HP you estimate this exhaust when going FI till it gets restrictive?
I mean when do one will definitely need 3" OD pipes?
MSTiFK8R is offline   Reply With Quote
Old 09-05-2012, 01:45 PM   #19
VSGTS14
987 Motorsports
VSGTS14's Avatar
Drives: '13 WO FR-S
Originally Posted by MSTiFK8R View Post
sounds mean!
with a turbocharger, yes.
with the N/A motor, no.
Old 09-05-2012, 01:53 PM   #20
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
sorry to be nerdy, but your black'n'whiteness sounds a bit rough
having FI doesn't mean your exhaust is choking your engine, it just promts you to ask "when do I need a bigger exit door?"
I know the gas velocity physics and thermodynamic stuff around pretty well, that was the reason me asking when is the brakepoint for the tubing becoming a restrictive exit for the exhaust gases, generated by the motor?
let's say I have 2,5" tubing all around from the turbo, to the exhaust tips, so when do I start seeing choke signs and wanting to switch to 3"?
For example, AP BRZ-300 kit shows ~300whp, which is nearly doubling stock power, staying 2,5" in exhaust piping
Even more, you may stick with a stock mid-and-rear sections, which are hella restrictive being bendy and 2.1" OD
Old 09-05-2012, 02:23 PM   #21
VSGTS14
987 Motorsports
VSGTS14's Avatar
Drives: '13 WO FR-S
wouldn't it really relate to what kind of turbo you're dropping into the car? what goes in...must come out.
Old 09-05-2012, 08:10 PM   #22
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
True, but it just doesn't mean that the stock exhaust is maxxed out at stock.
Don himself has said that up to 300 HP the stock exhaust was good on his setup. Adding an exhaust system to replace stock did not net any significant gains.
I'd say you NEED and exhaust for sure if you go over 300 WHP.
Stock resonator removal? jm1681 Engine, Exhaust, Transmission 33 10-11-2019 06:58 PM
Intake resonator?? DIE1000DEATHS Engine, Exhaust, Transmission 16 12-03-2014 08:17 PM
Brz/frs video. Bleeped version! nytfury FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 1 08-30-2012 12:01 AM
Exhaust baffle/ box structure between cat and resonator? ahausheer Engine, Exhaust, Transmission 14 04-25-2012 01:57 PM
Subaru Version (video) #87 BRZ First-Gen (2012+) — General Topics 7 10-31-2009 01:44 AM
