Old 08-31-2012, 07:50 PM   #869
Visconti
Drives: 05 STi
Originally Posted by choi0706 View Post
the tapping sound is me pressing the pedal.. I dont know what version my car came with..
You have a tune?
In the video you have a CEL - did you read the code? Car is in limp mode because of the CEL
Visconti is offline
Old 08-31-2012, 09:11 PM   #870
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
Originally Posted by JimmyMac View Post
Thanks John for the flash this morning. I didn't get a chance to upload it till after my teaching job, but had to go to my other job afterwards so I had no time to post up anything. Anyways, it's a little wet out here. Didn't get too much of a chance to run the car through, but I can feel a difference in the tune. Yes, it will do 60 in 2nd gear. The torque dip is more transparent. The car feels better/faster as you go up in the gears. The car also sounds different. I dunno, I'll have to listen better when I have more time with the car.
Question, you sent us 2 files. One was "your" tune and the other was the "stock" tune. (Correct?) If I had to flash back to stock, do I have to contact you so that I can reflash your tune back into my car? (Meaning, do you need to open up a flash license again?) Also, is it safe assume that you will open up new flash license when there is an update to your tune like flat foot shifting, changeable maps, etc..
Anyways, thanks again. Keep up the good work. Someday I'll hit you up for the E85 tune. Maybe when this tune wears off... hehe
John, just quoting my post. Can I keep flashing my ECU from stock to your map back and forth as many times as I want without you resetting my licenses? If you want a reason, I'll PM it to you. Anyways, tonight I need to do some data logs to sort out a problem.
JimmyMac is offline
Old 08-31-2012, 09:28 PM   #871
choi0706
Drives: t
You have a tune?
I have a p0019.. It did this before the code as well..
choi0706 is offline
Old 08-31-2012, 09:34 PM   #872
NotSoJDM
NotSoJDM's Avatar
Drives: '13 BRZ | '04 E55
Why would you ever flash your ecu when you have an existing cel?
NotSoJDM is offline
The Following User Says Thank You to NotSoJDM For This Useful Post:
Lonewolf (08-31-2012)
Old 08-31-2012, 09:40 PM   #873
ruskymx
ruskymx's Avatar
Drives: 13 HotLava FRS, 93 4Runner, 97 Taco
That's one of the camshaft codes isn't it?
ruskymx is offline
Old 08-31-2012, 09:42 PM   #874
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
Yep, looks like the cam issue.
See: http://www.ft86club.com/forums/showthread.php?p=401458
cobrabyte is offline
Old 08-31-2012, 10:12 PM   #875
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Originally Posted by Memphis View Post
116 OCTANE! RACE GAS FTW
Leaded? That's what are 116 is.
No e85 close though...
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline
Old 08-31-2012, 10:44 PM   #876
Visconti
Drives: 05 STi
Yup - flash away - no problems
OK - you need to flash back to stock and go to the dealer.
Did I send you the stock rom for your car?
yup - no good.
yup
Visconti is offline
The Following 2 Users Say Thank You to Visconti For This Useful Post:
civicdrivr (08-31-2012), dura1198 (09-01-2012)
Old 08-31-2012, 10:51 PM   #877
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
@Visconti is there going to be a valet mode in the on the fly map switching? I seem to recall some one saying something about it.
Lee358 is offline
Old 08-31-2012, 10:56 PM   #878
Visconti
Drives: 05 STi
Yup at some point - lots of stuff to do first.
Visconti is offline
Lee358 (08-31-2012), ngabdala (09-01-2012)
Old 08-31-2012, 11:12 PM   #879
Yruyur
Yruyur's Avatar
I would try a copy of my flash that john has from my replacement ecu that fixed my p0019. Curious if it would fix it.
Sent from my PH44100 using Tapatalk 2
Yruyur is offline
Old 08-31-2012, 11:12 PM   #880
Memphis
Memphis's Avatar
Drives: Scion FantasticRoad-Sex
I believe it is unleaded. I think...
Memphis is offline
Old 08-31-2012, 11:15 PM   #881
xjohnx
Grip>Slip
xjohnx's Avatar
might want to make sure before your cats become a clogged mess.
xjohnx is offline
ill86 (08-31-2012)
Old 08-31-2012, 11:18 PM   #882
Memphis
Memphis's Avatar
What cats? JK I know. Going to take the car to track on the 14th for road course driver ed Find out then.
Memphis is offline
The Following User Says Thank You to Memphis For This Useful Post:
ill86 (08-31-2012)
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 02:05 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 07:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) — General Topics 130 09-01-2011 01:42 PM
