Old 08-31-2012, 07:39 PM   #1
slaxx
Drives: '13BRZl, '14FiestaST2, '10Insight2
Minimal safe setup for a track day/hpde?
I'm looking for advice on what minimal prep you've done to your brz/frs for a track day.
So far I'm ready to swap brake pads in front, and fluid. I have lightweight wheels on with stock rubber that I'm happy to burn up--Not going for fast lap times yet just fun and instruction.
What pads have you run on the track and street? I don't want to swap back after the event if possible.
Any specific fluid experience?
What else?
Thanks guys. Awesome site this is
slaxx is offline   Reply With Quote
Old 08-31-2012, 07:47 PM   #2
ayau
Drives: Some rust bucket
i'm interested in this topic as well. it will be my first track event.
from researching, many recommend going with carbotech xp10 pads for front and back. i'm not sure if sticking with OEM rear pads is recommended. for fluid, it's either ATE super blue or some racing oriented fluid from motul.
the stock tires will be fun to learn on, but they will begin to chunk (rubber pieces falling off) after so many laps. you may want to look at some dunlop star specs or other high performance summer tires.
edit: you may also want to look at the BRZ crash bolts to add some negative camber to the front. they're cheap and only cost about $8 per bolt. this will save your tires from wearing out prematurely and provide you with more grip in the corners.
Old 08-31-2012, 08:21 PM   #3
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Everything Ayau said. Everything.
Old 08-31-2012, 08:48 PM   #4
CB762
CB762's Avatar
Drives: Scion FR-S
Well, I don't think first-time drivers, without any other previous high performance driving experience, will need to do anything with car.
I doubt even born-drivers could get more than 50-60% (conservative estimate) out of the car performance on the very first day at the track.
CB762 is offline   Reply With Quote
Old 08-31-2012, 10:12 PM   #5
Feffman
Drives: None
The big thing is to make sure your brake fluid is fresh throughout the system. We have more tech failures (despite multiple warnings before a track event) due to old, nasty brake fluid than anything else combined.
Some upgraded brake pads may be in order. Call Danny Puskar at Carbotech Brakes (www.CTBrakes.com). He'll guide you to the appropriate pads.
Have fun.
Feff
Feffman is offline   Reply With Quote
Old 08-31-2012, 10:31 PM   #6
ayau
i think it will depend on the driver. some inexperienced drivers may overdrive the car eg., abrupt braking, hard acceleration, cornering too hot, etc etc. all these things will wear out the brakes/tires much faster than an experienced driver.
Old 08-31-2012, 10:46 PM   #7
Jedi1
STX build in progress!
Jedi1's Avatar
Drives: Whiteout FRS. Just Gorgeous!
Took mine out bone stock. 100 miles for the day. 60+ miles sideways! The brake pedal is a tad soft, but it was fine for day one.
Jedi1 is offline   Reply With Quote
Old 08-31-2012, 10:57 PM   #8
CB762
CB762's Avatar
Drives: Scion FR-S
That is what an instructor for -- to not allow such.
Going on the track for the first time without a good instructor would be a top nonsense.
Old 08-31-2012, 11:23 PM   #9
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Agreed.
Minimal what you need is driver prep. Evergthing else doesn't matter for a novice or someone looking to experience a track setting.
In other words... Listen to your instructor, stay hydrated and have fun. Last session of the event take it down a notch . You will be fatigued. Mentally and physically.
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline   Reply With Quote
Old 09-01-2012, 01:05 AM   #10
Jedi1
Jedi1's Avatar
I will say this. The brakes CAN and probably WILL cook a bit. If you can get some decent fluid in there at the very least before your first track day, it's a great idea. I had 2 days off from a three month tour and the opportunity to play presented itself with no warning. It had to be done! When I go back it will be with RS3's, decent brake fluid, stainless lines and a few other tweaks.
Not saying you can't track the car bone stock. I am saying if you do, BE CAREFUL.
Old 09-01-2012, 03:16 AM   #11
slaxx
Yeah I've a couple years racing tunnel hull boats and karts. But never street cars.
Old 09-01-2012, 06:36 PM   #12
FRSpdDmn
Drives: 128i, Z3 Coupe, Fiero GT
I ran my car for one session at Summit Point totally bone stock when I was there coaching. It held up great. The brakes did get soft, but never faded away and there is a hard downhill braking zone there that really worked them. It is track-capable in stock form.
That said, I would try to get a pad like the Hawk HP+ if you're running on stock tires and don't want to swap. I would try to get front AND rear pads, though. Many people underestimate how hot the rear pads get and how much they help the fronts do their job. Personally, I think a Carbotech XP-10 is vast overkill for stock tires and you may not be operating in their optimal range. I haven't done any brake testing on the car, though.
-Anthony
Former '13 Whiteout FR-S, BMW 128i, BMW Z3 Coupe, Pontiac Fiero GT
2017 Pirelli World Challenge TC Rookie of the Year
2012 NASA SpecE30 National Champion
www.DriveFasterNow.com
FRSpdDmn is offline   Reply With Quote
Old 09-01-2012, 07:04 PM   #13
gmookher
carbotech is good stuff
Old 09-01-2012, 07:32 PM   #14
CSG Mike
CSG Mike's Avatar
You can street drive the XP10 once they're bedded properly with minimal noise. However, being a novice, it may be difficult to do so. Without being fully bedded, they're gonna squeal like pigs. It may go away for a few days after your track event, but will come back eventually (sign of "almost" bedding them).
Our BRZ as well as my personal cars are all street driven on race pads; we don't see freezing temperatures in Southern California, so stopping power has never been an issue, even when cold. Even at 40F, the "cold" bite of race pads has always been greater than the bite of street pads.
Safe to use DOT 5.1? mechaghost Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 10-27-2015 03:32 AM
Going to track with stock setup good or bad idea? evasquez7 BRZ First-Gen (2012+) — General Topics 11 08-21-2012 02:33 PM
PacNW Track Day/HPDE/School thread rice_classic Northwest 12 07-10-2012 08:58 PM
Safe to wax new car paint? Nitro Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 06-09-2012 01:08 AM
HPDE Day video Dragonitti Other Vehicles & General Automotive Discussions 34 06-12-2011 10:11 PM
