Old 08-31-2012, 12:39 PM   #365
fenton
Originally Posted by JoeBoxer View Post
I know a lot of OEM turbo applications are able to reach peak torque under 2k rpm is this something that would be possible on an aftermarket kit?
example: Audi A4
Horsepower: 211 @ 4300
Torque: 258 @ 1500 2.0L/121
I know its a different engine style but if we could get peak torque lower I think it would work well.
Full spool on most of the low PSI kits on here are hitting at about 2500rpm.
Only difference between these turbo's and the VW ones is we aren't running out of steam in the top end.
Do you know how bad it feels to be in a gti/a4/speed3 that falls flat on its face at 4000 rpm?!
When you hit peak power at 4000rpm it is all downhill from there, some cars are worse than others.
For a commuter car like a a4 sure this is more acceptable but for a perfomance/sports car this is certainly not a desired trait.
Sure if you used a tiny turbo you could get peak power at 2000 rpm but you would tail off power on the top end quite a bit once the turbo becomes a restriction.
fenton is offline   Reply With Quote
Old 08-31-2012, 12:41 PM   #366
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
Originally Posted by subatoy View Post
hey AVO how much do you guys charge for installation?
Come down to Orlando, it'll cost you exactly 1 12pack of blue moon :happy0180:
Ironsquid is offline   Reply With Quote
Old 08-31-2012, 12:50 PM   #367
fenton
See attached dyno's for a look at what a small turbo means for the top end.
Old 08-31-2012, 01:02 PM   #368
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Thanks guys i've had some turbo cars but they were oem, VW GLI and Sonata Turbo. I guess i would be looking for something like AVO posted on the 2.5 Impreza.
Old 08-31-2012, 01:04 PM   #369
subatoy
subatoy's Avatar
Drives: subatoy
Originally Posted by Opposed View Post
But, the MK6 utalizes a turbo, which you said you hate because they don't kick in until 5k...Not trying to continue to go off topic, but just saying.
GTI's turbo full boost kicks in at 1,800 rpm and it holds.
I love it.
subatoy is offline   Reply With Quote
Old 08-31-2012, 01:05 PM   #370
subatoy
subatoy's Avatar
Drives: subatoy
For that deal I would get you 2x12 packs!
Old 08-31-2012, 01:15 PM   #371
fenton
I love it.
Although the GTI is much better than a Speed 3 it certainly doesn't hold it indefinetly.
Peak power is at about 5000 rpm when torque and power start falling off to the 6500rpm redline.
Old 08-31-2012, 01:33 PM   #372
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
The small turbo discussion is going on good, GTI's vs Speed3, etc... I wonder if we could get back on topic now
@AVOturboworld, any update on turbo selection?
Old 08-31-2012, 08:06 PM   #373
Apex Chase
El Presidente
Apex Chase's Avatar
Drives: it like I stole it!
Apex Chase is offline   Reply With Quote
Old 08-31-2012, 09:16 PM   #374
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
Originally Posted by AVOturboworld View Post
Technically, it's possible, but it means a really small turbocharger that will peak out quickly (note the 211hp is made at 4300rpm in example above).
Our turbocharger kits for the 2.5i Impreza's looked basically like this:
The dyno doesn't show the onset of boost, but road tuning shows the magic starting to happen at 1500rpm. Peak is reached relatively early at 2800rpm, and it plateau'd till 6400rpm, where the 2.5i's start getting in reach of their redline.
Now - this is not the 2.0-liter BRZ motor! It's just an example. The 12:1 compression, different combustion chamber design, and higher rev limit/available power band means different results and different setups. With the turbocharger up front and right off the exhaust manifold, though, it will probably respond quicker and may get to peak torque sooner.
If you can make the 86 do the same results as that graph i will hand my money over right now!
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 09-01-2012, 10:12 AM   #375
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
@AVOturboworld , keep up the good work guys. Very impressed. Is the throttle response dulled on your turbo?
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
Old 09-01-2012, 11:17 AM   #376
KAR
Drives: Whiteout 6spd
Me personally would rather have lag and great top end than vise versa
Boost is only a downshift away
KAR is offline   Reply With Quote
Old 09-02-2012, 10:53 PM   #377
fred_boosted
fred_boosted's Avatar
Drives: 2008 EVO X GSR (Sold)
I missed most parts of the thread.
I read it quickly.
Can anyone tell me:
What turbo AVO are going to use?
Any upgrade choice in the future for the turbo?
Most importantly, do they keep the stock cat?
Thank you.
I could get Maserati Quattroporte or BMW M3/M6.
But I gived up.
Why? Because thats just not my style.
fred_boosted is offline   Reply With Quote
The Following User Says Thank You to fred_boosted For This Useful Post:
2forme (09-08-2012)
Old 09-02-2012, 11:20 PM   #378
subatoy
subatoy's Avatar
Drives: subatoy
I read it quickly.
Can anyone tell me:
Thank you.
I think the turbo is top secret still.
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
