Old 08-30-2012, 08:47 PM   #1
AVOturboworld
Dirty throttle body
While pulling the stock inlet tube off after about 400 miles (for installation of the AVO Inlet Tube), saw this buildup already in the throttle body.
It's that black line running along there.
It was easy enough to remove, I just put some brake cleaner on a rag and wiped it off with a bit of elbow grease.
It does make me wonder how effective the standard Toyota air filter is, given that it has only been 400 miles, and it's not exactly pollution heavy here in Seattle. Checked the inside of the inlet filter, and it's not from blow by oil.
The Following User Says Thank You to AVOturboworld For This Useful Post:
Guff (08-30-2012)
Old 08-30-2012, 08:51 PM   #2
Keith@AIRAID
Drives: 51 Kaiser, 97 4Runner, 07 Civic Si
The PCV vents right in front of the TB, could it be oil from that?
Keith@AIRAID is offline   Reply With Quote
Old 08-30-2012, 08:58 PM   #3
Apex Chase
El Presidente
Apex Chase's Avatar
Drives: it like I stole it!
Gotta get a catch can from Day 1.
Apex Chase is offline   Reply With Quote
Old 08-30-2012, 09:00 PM   #4
AVOturboworld
I was thinking it would be that - Subaru's are just a touch notorious for blow-by - but there's not even a hint of oil on the bottom of the standard inlet nor the throttle body. Wiped it down just to check.
Old 08-30-2012, 09:03 PM   #5
gmookher
any logic in reloc'ing the pcv?
Old 08-30-2012, 09:27 PM   #6
Tradewind
Drives: 2006 Subaru Liberty EZ30 S/charged
Smile Blow by
As someone who works with a lot of Subaru NA H4 with added FI - I can definitely agree with that
Toyota 86 test driver
Tradewind is offline   Reply With Quote
Old 08-30-2012, 09:34 PM   #7
zoomzoomers
zoomzoomers's Avatar
Should have checked when I installed my Airaid intake. I'll make sure to check the next time I have the tube off.
Old 08-30-2012, 11:25 PM   #8
vubaru
Now with Boost!
vubaru's Avatar
Drives: 2013 SWP BRZ Ltd.
Thanks for the heads up Paul! This is definitely worth knowing early so we can keep an eye on it and clean it going forward.
vubaru is offline   Reply With Quote
Old 08-30-2012, 11:46 PM   #9
arghx7
Drives: car
it's just a slight deposit; nothing to worry about on a stock or mildly modified vehicle. They all do that. The electronic throttle will compensate for it at idle.
Old 08-31-2012, 01:57 AM   #10
Swift Racing Technologies
Swift Racing Technologies's Avatar
Keep in mind that the factory uses a thick dye to mark where the throttle plate comes in contact with the TB during assembly for calibration purposes. From what it looks like in the pic, it is the factory dye you are looking at and it takes considerable more "elbow grease" to remove that dye than normal blow-by that causes TB contamination. Looking at the picture after cleaning I would say 99% sure you were removing the dye as there is still residue left after cleaning which definitely in not blow-by as blow-by would have easily melted off with brake cleaner and left you a pristine clean surface on such a low mileage car.
Swift Racing Technologies is offline   Reply With Quote
The Following 4 Users Say Thank You to Swift Racing Technologies For This Useful Post:
ahausheer (08-31-2012), dura1198 (08-31-2012), sw20kosh (08-31-2012), tripjammer (08-31-2012)
Old 09-06-2012, 01:49 PM   #11
gmookher
i dont think you need to over think this, I added a generic oil catch from Moroso today..
http://www.ft86club.com/forums/showt...ight=oil+catch
Old 05-11-2016, 11:58 AM   #12
KalbiCool88
KalbiCool88's Avatar
Drives: 2005 SLK350, 2015 RS 1.0 FRS
Bumping an old thread here, but I recently installed my TRD air intake and saw this same scenario with black soot or carbon in my throttle body during install. Was a little concerned at first, but eventually just let it go. Glad to see its nothing out of the norm especially since I've only got just under 10,500 miles...
Sent from my A0001 using Tapatalk
KalbiCool88 is offline   Reply With Quote
Cusco Throttle Body? track_warrior Engine, Exhaust, Transmission 66 06-28-2016 07:28 PM
Cusco Overbore Throttle Body Brimford Engine, Exhaust, Transmission 15 09-05-2012 07:17 PM
Windshield appear to be dirty. trueno86power Issues | Warranty | Recalls / TSB 17 08-03-2012 03:20 PM
Clean & Dirty trueno86power Other Vehicles & General Automotive Discussions 1 02-07-2012 01:54 PM
