Old 08-28-2012, 11:36 PM   #15
ahausheer
Re-member
Drives: Toyota camry
Those of you with difficulty shifting, check the transmission fluid level. I have seen cars (and there are threads here) that are low from the factory. Modern transmissions can be very picky with fluid level.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 08-30-2012, 05:56 PM   #16
Billman
Billman's Avatar
Drives: 00 Honda S2000
My S2000 does the same thing, I need to regrease the shifter which will help smooth it out but it's pretty much a cold transmission issue. Also syncros don't work as quick as you can actually shift, try holding 1-2sec more before you try to force it in gear as it could simply be trying to rev match.
Billman is offline   Reply With Quote
Old 08-30-2012, 07:27 PM   #17
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
I changed my Transmission fluid at 1.5k miles. All is good now.
Old 08-30-2012, 08:59 PM   #18
gmookher
as in you HAD a notchy cold 2nd gear and now you dont after using a thinner lube?
Old 08-30-2012, 09:15 PM   #19
rice_classic
Actually my transmission shifted just fine with the OEM stuff in it, nothing out of the ordinary. With the yellow bottle it just does what it does better. Also I knew I was going to be on the track (where we heat the oil a lot) and the OEM stuff, IMHO, is not up to the task.
The 2nd reason I used the yellow bottle... The OEM stuff isn't available in the states yet AND I wanted to change my tranny fluid sooner than later for the same reason I wanted to change my engine oil. Get the break-in oil out of there.
I've stated this in a few threads now but the OEM stuff, looks, smells and feels identical to Honda Manual Transmission Lubricant.....identical. And I don't like using the Honda MTL in my transmissions, even my Honda boxes. I've been using the Yellow bottle in my S2000, my Prelude, my CRX race car and now my FRS (since it's an Aisin tranny like the s2k).
No more 1st gear thump or 2nd gear notchiness kc4mne Scion FR-S / Toyota 86 GT86 General Forum 28 09-06-2012 09:39 PM
Top Gear blackfireball5 Scion FR-S / Toyota 86 GT86 General Forum 3 08-17-2012 02:58 PM
5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? kharn83 Issues | Warranty | Recalls / TSB 9 08-06-2012 08:44 PM
86/BRZ/FRS on Top Gear: When??? FT-86GOD Scion FR-S / Toyota 86 GT86 General Forum 20 07-04-2012 01:08 AM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 02:21 PM
