#141 | |
hashiryu
Drives: Mk4 Supra
Hope they get around to them wen things pick back up cause the next tundra isn't due till when? 2017? |
#142 | |
Drives: N/A
I'd pick the rotary Renesis over a F20C, although I'm no expert and I've never driven either. I admit the Renesis does need better oiling and boosted it doesn't compare with the F20C because it's prone to predetonation. MPG is the only problem I have with the RX-8 but it's a true blue sports car. If they had used a version with the 4 port engine and taller gearing it would probably get decent MPG. The rumor is that the Auto version gets better MPG, it is geared for 2000RPM at 60mph! I'm not sure what BHP the 4 port puts out exactly, I've heard 180-200BHP. I'd give up 30-50BHP for 5 more HWY MPG. It would still be a fun car to drive .
#143 |
Drives: 2010 GTI 2dr Tornado Red
The rotary is an amazing piece of tech. Diesel rotaries are great on fuel and make absolutely SILLY amounts of torque. I'd LOVE a turbo-diesel RX-7. It would be silly fun.
If the rotary engine had received anywhere NEAR as much tech development over the last 100 years as the piston equivalent, it would be a vastly superior system. As it is, I look forward to the new version of Mazda's rotary with extreme impatience. If they can fix their styling issues and offer a rotary that will give me about 27mpg highway, I'd be all over that in a heartbeat. I've driven the RX-8 and it's an amazing performer, even if it is way down on power. |
#144 |
Drives: '06 AM V8V Coupe
The next Mazda rotary might solve a lot of the current problems though. Judging from the first few links on the internet, the main problems that the rotary faces are sealing, low compression ratio, and a suboptimal long combustion chamber. Ceramic seals might make it into cars sometime in the future, the new Mazda engine has a much better compression ratio, and they've probably improved combustion efficiency a good deal by now. Exciting stuff...
#145 |
Drives: 2013 DZE/01 (sold for MX5 ND1)
Given the choice, I'd take 148 HP & 2400 lbs over 200 HP & 2700 lbs, but either would make me happy.
As far as the rotary goes, IMO the RX8 is one of the most fun 4 seaters ever built (though it's unfortunate that it wasn't closer to the RX-01's 2425 lbs and shorter wheelbase). The 13B-MSP didn't attain its targeted MPG and I doubt the 16X will improve things enough for mainstream appeal, but if they can get it up to 20/27 MPG city/highway @ 240 HP & 185 ftlbs in a 2600 lbs RWD 4 seater, I'd buy one in a heartbeat. Don't see it happening. |
#146 | |
Feeling Iffy?
Drives: it like I stole it
#147 |
Elite Padawan
Ask those guys who are still driving 1993+ RX-7 around. They might know the tips how to maintain the car.
#148 | |
I really don't know how much that would help but its something. Could I get someone possibly knows more about this clarify? Don't wanna just give out false info.
I am the Ice Queen.
Logic > Emotion ┬──┬◡ノ(° -°ノ) Yashio Factory Pink adds +10HP to anything. TOYOTA FT-86 ![]() |
#149 | |
Kuruma Otaku
Edit: Giccin, rotaries need to inject oil into the combustion chamber or else they will die. So they go through a lot of oil.
Because titanium. Last edited by Dimman; 05-14-2011 at 11:10 PM. Reason: Edit: |
#150 | ||
Drives: N/A
You should carry a quart of oil with you just in case for any ICE. Piston engines burn oil too. Both engines start to burn a lot of oil as they age and more so as they get close to failure of the internals. The earlier Rotaries were more reliable because they didn't have to limit oiling for emissions. Proper oiling is important to protect the apex seals in Rotary engines. I can't go to far into it simply because I don't have the information memorized and I'm simply not as knowledgeable as the Rotaryheads but the Renesis is infamous for not being reliable for good reason. The most common conclusion I've heard of it being unreliable is due to lack of sufficient oiling. The most common solution is to premix oil with Gasoline. The Rotaryheads often recommend redlining the engine once a week too. I personally feel keeping the RPMs up to avoid lugging is close enough since the oil pump is designed for higher RPM operation. Redlining is at the end of the normal range of operation. I've heard that meticulous maintenance makes a difference too. Dimman is being pessimistic about it but what he's saying is not unheard of. Mazda has a 100K mile warranty but the process to get the engine replaced is rather, stringent. 100k miles is not unheard of on the Renesis but there are plenty of RX-8s on their second or third engine. |
#151 |
Mr. Detail
Drives: 2003 Celica GT-S
Thank you sir, you've given me another justification to hit 8,450 RPMs more often.
#152 | |
GL 86!
Drives: Maybe FR-S... maybe not
#153 | |
Anyways I went back and read some articles on the 16X today, they claim they've gotten the fuel efficiency pretty good but emissions is still a problem :/ Sounds like the oil burning or NOx emissions? I think rotaries might have a tough time as fuel efficiency standards get even tougher since it's a bit more difficult to implement throttleless control since there aren't any valves to block airflow off for part of the intake cycle. I imagine eliminating that source of partial load loss will be pretty important to hit fuel efficiency regulations further down the line. |
#154 | |
Mr. Detail
(or than just low)
| New set of Toyota FT-86 interior photos from the studio (some great details) | Hachiroku | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 52 | 09-15-2013 01:29 PM |
| Dealer Installed Badges | ToyotaObsession | Scion FR-S / Toyota 86 GT86 General Forum | 55 | 05-14-2011 12:16 AM |
| FB engine details from C&D | chulooz | Engine, Exhaust, Transmission | 4 | 05-06-2011 03:38 PM |
| More details of FT86 from Autocar | madaadda | Scion FR-S / Toyota 86 GT86 General Forum | 70 | 04-17-2011 01:42 AM |
| Dealer Markup?? | prighello | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 10-22-2009 08:14 PM |
