Old 08-30-2012, 01:40 PM   #43
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I can't completely prevent someone hitting my car, I can prevent Jose from working on my car though :P
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 08-30-2012, 01:44 PM   #44
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
Yeah, nothing beats working on your own car. Go to Sears, get the tools, get the manual and DO WORK!
Old 08-30-2012, 01:45 PM   #45
xwd
The reality of it is shops are going to use impact guns to torque down bolts, especially large ones. I took the suspension on and off my WRX for years using the same bolts and always used an impact gun, you generally get a feel for where the torque needs to be.
If you took your car to a dealer and they had to replace a strut, they are going to impact the bolts. They aren't going to take the time to look at torque specs and bring out a wrench to actually measure the torque.
Old 08-30-2012, 02:24 PM   #46
rmjjensen
rmjjensen's Avatar
Drives: 2013 Subaru BRZ Limited in WRB
"Jose" needs to invest in a set of fender covers asap
rmjjensen is offline   Reply With Quote
Old 08-30-2012, 03:13 PM   #47
daytrip00
Drives: S2000
My mechanic properly torques on bolts. That's why I go to him. Anybody that takes the care to go that extra mile is taking good care of your car.
daytrip00 is offline   Reply With Quote
Old 08-30-2012, 09:18 PM   #48
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
I wonder how you all torque down that top mount while the shock shaft spins when your trying to torque it down. Ive never "torque" a top mount, i usually just use the air gun to get it almost all the way down, use the ALLEN key to keep the shaft from spinning and using a wrench to tighten it.
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
*KID* is offline   Reply With Quote
Old 08-31-2012, 06:10 AM   #49
Supermassive
Supermassive's Avatar
Thats the beauty of impact tools...not saying its perfect but, you dont have to worry about that shaft spinning the impact action actually works wonders for stuff like that...speaking of which you reminded me that i need to make sure i have a set of impact allen head bits for my Ohlins cartridges for my Aprilia RSV-4R!!! (When you bolt the cart onto the fork tube the whole cartridge spins unless you have an impact gun, or the over priced special Ohlins tool that keeps the cart from spinning in the tube.
Supermassive is offline   Reply With Quote
Old 08-31-2012, 06:33 AM   #50
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
LOL Car damper shafts spin like mad with an impact. I've done it for years and have never had one NOT spin (tightening). KWs do for sure, I've used an impact on them multiple times also.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 08-31-2012, 10:38 AM   #51
lam86
ano...
lam86's Avatar
Drives: 87 AE86
I want a ROTFL smiley for the person who commented about disgust using impact on lugs..
lam86 is offline   Reply With Quote
The Following User Says Thank You to lam86 For This Useful Post:
Memphis (08-31-2012)
Old 08-31-2012, 12:26 PM   #52
daytrip00
Drives: S2000
I stopped going to a mechanic because he kept using an impact on the lugs. He deformed a few on my mom's car and they were on so tight (probably around 150 ft-lbs) that she and my sister were totally unable to get the tire off to put the spare on using the tire iron. I've also seen my wheel bolts (F##@@ europeans) stripped using an impact wrench.
It's just sloppy work. If a mechanic can't be bothered to take the extra five minutes to do it correctly, then i don't want to know what other corners he's cutting. And if you've followed vivid (and by extension, agency power) you'd know there are a ton of corners being cut.
Old 08-31-2012, 12:47 PM   #53
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
Originally Posted by civicdrivr View Post
Thats makes me cringe.
I also hate when people use impacts on lug nuts.
I dont mind this as much, it's when they zip on the lugs without hand turning them on first to ensure they won't strip.
Ironsquid is offline   Reply With Quote
The Following User Says Thank You to Ironsquid For This Useful Post:
civicdrivr (08-31-2012)
Old 09-06-2012, 02:20 PM   #54
phattyduck
Drives: '03 WRX Wagon, '89 Camry Alltrac
Maybe the video didn't show the part where he did the final tightening with a hand ratchet or torque wrench? If you watch the video again, you can see the gun isn't applying much torque on assembly (light movement of the hand).
That's what the mechanic friends I have do: Disassemble with impact, assemble with low impact, tighten by hand. (unless 19mm+, then its full-on impact...)
I often don't use an impact, but that's 'cause I have neighbors and work on my cars at night.
-Charlie
phattyduck is offline   Reply With Quote
M7 JAPAN COILOVERS for SCION FRS SUBARU BRZ, JDM COILOVERS AMPLIFIED MOTORSPORT Brakes, Suspension, Chassis 0 08-16-2012 02:45 AM
Coilovers vs Springs – What are coilovers and what’s better? phenom86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 07-30-2012 12:24 AM
How do you install the mud guards? Moshpit37 Scion FR-S / Toyota 86 GT86 General Forum 11 07-27-2012 11:13 PM
How to install mudguards? FRiSson Cosmetic Modification (Interior/Exterior/Lighting) 2 07-13-2012 07:34 PM
Spoiler Install CharlieChaos Cosmetic Modification (Interior/Exterior/Lighting) 1 07-07-2012 10:43 AM
