Old 08-30-2012, 12:49 PM   #1
White64Goat
E-85 NOT Recommended
Found this in the owners manual: Pages 422 & 423
SUBARU does not recommend blended gasoline
If you use gasohol in your SUBARU, be sure that it has an octane rating
no lower than 93 AKI.
SUBARU DOES NOT recommend the use of gasoline containing methanol.
SUBARU does not recommend gasoline containing MMT
Some gasoline contains octane enhancing additive called MMT (Methylcyclopentadienyl
Manganese Tricarbonyl).
SUBARU DOES NOT recommend the use of gasoline that contains MMT. If
fuel containing MMT is used, your emission control system may be
adversely affected.
The malfunction indicator lamp on the instrument cluster may come on. If
this happens, contact your SUBARU dealer for service.
Use only gasoline containing a maximum
of 10% ethanol.
DO NOT use any flex-fuel or gasoline
that could contain more than 10% ethanol,
including from any pump labeled
E15, E30, E50, E85 (which are only
some examples of fuel containing more
than 10% ethanol).
I've seen posts where folks are using or thinking about (or are) using E-85. If Subaru says you shouldn't, why would you?
Notice on fuel quality
Do not use improper fuels. If improper fuels are used the engine will be
damaged.
Do not use leaded gasoline.
Leaded gasoline can cause damage to your vehicle’s three-way catalytic
converters causing the emission control system to malfunction.
Do not use gasohol other than that stated here.
Other gasohol may cause fuel system damage or vehicle performance
problems.
Using unleaded gasoline with an octane number or rating lower than the
level previously stated will cause persistent heavy knocking.
At worst, this will lead to engine damage.
Fuel-related poor driveability
If after using a different type of fuel, poor driveability is encountered (poor
hot starting, vaporization, engine knocking, etc.), discontinue the use of that
type of fuel.
When refueling with gasohol
Take care not to spill gasohol. It can damage your vehicle's paint.
The Following User Says Thank You to White64Goat For This Useful Post:
Brzce (09-01-2012)
Old 08-30-2012, 12:54 PM   #2
Justin.b
Drives: 13 Hot Lava, 01 Miata, 09 Outback
I'm assuming the people looking at running e85 are also going to be turbocharging or supercharging the car because you can run more boost.
-Justin
Justin.b is offline   Reply With Quote
The Following User Says Thank You to Justin.b For This Useful Post:
Guff (08-30-2012)
Old 08-30-2012, 12:59 PM   #3
Opposed
Drives: 2013 Asphalt FR-S
There are people that have been running e85 in their Subaru's for tens of thousands of miles for years on end with no issues. John (Visconti) has already had the injectors and fuel pump examined on a BRZ/FRS that has been running e85 with no issues so far. If I remember correctly, there has not been a single failure reported due to running e85...
Opposed is offline   Reply With Quote
Old 08-30-2012, 01:00 PM   #4
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
Nobody should put E85 into their stock car.
HOWEVER, it has been found that some direct injection systems can handle E85 out the box, the only requirement being a change in fuel/timing map such as the ones that can be installed via the new ECUTek/Visconti tuning systems and what not.
With a proper tune, one could find some gains in E85 without forced induction.
- The Ancient BRZ Sacrament
by Zaku
The Following User Says Thank You to Guff For This Useful Post:
Turbowned (09-03-2012)
Old 08-30-2012, 01:00 PM   #5
rusty959
Drives: DGM BRZ limited
I bet subaru also recommends not flashing the ecu, which is something required in order to run e85.
edit: sniped :/
rusty959 is offline   Reply With Quote
The Following 2 Users Say Thank You to rusty959 For This Useful Post:
raz0rbladez909 (09-05-2012), tripjammer (08-30-2012)
Old 08-30-2012, 01:16 PM   #6
fenton
The no E85 is meant for stock cars. If you put it in a stock car(what the manual thinks everyone has) it will run like crap.
Running a special map to allow for the different fuel is completely fine.
fenton is offline   Reply With Quote
Old 08-30-2012, 01:23 PM   #7
Visconti
Drives: 05 STi
Yeah - can't use it stock.
Car isn't flex fuel stock.
Car is tuned for pumpgas only stock.
It's A.O.K with the flash
John
Visconti is offline   Reply With Quote
The Following 5 Users Say Thank You to Visconti For This Useful Post:
PRORICAN (08-30-2012), raz0rbladez909 (09-05-2012), SkAsphalt (08-30-2012), Starscream15 (08-30-2012), tripjammer (08-30-2012)
Old 08-30-2012, 01:26 PM   #8
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
^ correct
After 10%+ tune is needed
/thread
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline   Reply With Quote
Old 08-30-2012, 01:28 PM   #9
FIREISFUN135
FIREISFUN135's Avatar
Drives: 2013 BRZ DGM
Subaru tells us we can't use E85 in our stock BRZ/FRS...
FIREISFUN135 is offline   Reply With Quote
The Following 9 Users Say Thank You to FIREISFUN135 For This Useful Post:
JiB (09-01-2012), lopro25 (08-30-2012), PRORICAN (08-30-2012), r0ma (08-31-2012), SkAsphalt (08-30-2012), Superhatch (08-31-2012), TouchMyHonda (08-30-2012), tripjammer (08-30-2012), UncleFester (08-31-2012)
Old 08-30-2012, 01:38 PM   #10
drifter
Drives: truck and old car
●SUBARU acknowledges we are a bunch of morons for selling cars that require at least 93 octane to states that are not allowed to sell it.
drifter is offline   Reply With Quote
The Following 3 Users Say Thank You to drifter For This Useful Post:
Asphaltfrs1 (08-30-2012), dabocx (08-30-2012), White64Goat (08-30-2012)
Old 08-30-2012, 04:14 PM   #11
White64Goat
Ok, guess I got schooled on that info...
John (Visconti), have you had a chance to read the PM I sent you the other day?
Old 08-30-2012, 04:19 PM   #12
Visconti
Drives: 05 STi
^ it's all a blurrrrrr
Whats up>?
Old 08-30-2012, 04:25 PM   #13
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
Its not recommended because its not tuned for it; It can to be tuned to run on it...
TouchMyHonda is offline   Reply With Quote
Old 08-30-2012, 10:40 PM   #14
arghx7
Drives: car
There's zero long-term durability testing information available for the fuel system. We have no idea whether the high pressure fuel pump or direct injectors will hold up. They might, they might not. Whoever supplies the fuel system probably has some idea, and of course they're not talking.
Don't assume the BRZ will be fine because somebody made a gazillion horsepower with E85 in their '04 STi they put less than 10000 miles a year on. Use E85 at your own risk. I'd think twice about doing so on a brand new car under warranty that you're probably making payments on, unless you dump a ton of money into it anyway.
The Following 2 Users Say Thank You to arghx7 For This Useful Post:
Brzce (09-01-2012), dsgerbc (09-01-2012)
Recommended Car Ramps for the BRZ/FRS? mechaghost Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 49 09-01-2017 12:41 AM
Recommended Detailer/Opticoat in Nashville, TN? schtebie Southeast 16 10-24-2012 10:09 PM
Recommended body/paint shop - SoCal Symbiont Southern California 4 08-18-2012 04:51 PM
Sydney - Recommended Salesperson ex-gti AUSTRALIA 7 06-20-2012 09:54 PM
