Old 08-29-2012, 03:45 PM   #57
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by sparks View Post
This will be one of the easiest DIY's I've done in years. Add 2 pins, run a video cable, power the camera, mount the camera.
I'll try to remember to "keep is simple stupid" when the write up comes
Nice. Any idea when the pins will be available?
Old 08-29-2012, 04:55 PM   #58
sparks
sparks's Avatar
Not sure, Mr. SVXdc has been quite for the last few days, probably work related. All you'll need is the two pin to RCA kit and your choice of camera kit. Again, something without guide lines, or can be disabled.
2013 BRZ Preimum #452 - Sterling Silver
sparks is offline   Reply With Quote
Old 08-29-2012, 05:04 PM   #59
sure74
sure74's Avatar
Drives: 2016 Toyota 4Runner Trail Premium
FYI - I sent him a PM on the 23rd, haven't heard anything back yet.
UPDATE: As of this morning (9/6/12) I have sent payment to SVXdc for the FT rear camera RCA cable.
sure74 is offline   Reply With Quote
Old 09-05-2012, 12:41 PM   #60
Sargy
Long Distance Driver
Sargy's Avatar
That used to be my friends 86, really loved sitting in it. Sold to 21st century downstairs.
Sargy is offline   Reply With Quote
Old 09-05-2012, 01:32 PM   #61
xjohnx
Grip>Slip
xjohnx's Avatar
nice.
random, but nice.
Old 09-05-2012, 04:09 PM   #62
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
nice.
random, but nice.
it was from my OP when I took a cig break from working on my camera and that was parked downstairs. I know the kid who owns it and he also has a mint unmolested supra.
Flat Black VW is offline   Reply With Quote
Old 09-08-2012, 03:40 PM   #63
xcelir8brz
Drives: 2013 BRZ Limited
Originally Posted by Flat Black VW View Post
Yes just a toggle, works exactly as how you described it.
VSS is meant for when the GPS antennae loses signal, it can tell how fast you are going so the NAV can keep up. The most useful place for this is somewhere like a tunnel where the antennas have no chance of getting signal. I have been expiramenting with running the VSS switched off, Ive been driving around town since I did this yesterday and with no VSS it has yet to lose track of me. That being said I have not been going through any tunnels, near tall buildings or anything else that would block my signal.
I did this toggle switch today. And with a 6AT BRZ Limited, this switch does no good. The GPS serves as primary speed indicator while the SPD sensor is backup and is not used. I went into the 3-button service mode to verify that SPD is read by GPS and not the SPD sensor. I'm wondering if it is the version of software on my head unit or because I have a 6AT. I definitely wired everything up correctly, tested it without the switch, and with the switch and still have the issue as stock.
Note: I only tried this with the phone lockout above 5 MPH.
Any thoughts?
xcelir8brz is offline   Reply With Quote
Old 09-08-2012, 03:49 PM   #64
Flat Black VW
Not sure, nav is the same unit so I would think this works for both. Mine is a premium 6mt but I don't see why it would work differently.
Old 09-08-2012, 04:41 PM   #65
Foobar
SLO NO MO
Foobar's Avatar
Limited 6MT here and the toggle switch on pin 17 works for me. I didn't test it with phone, but I tested it with entering navigation address. The nav settings menu also undims while moving if I toggle it off.
Old 09-08-2012, 05:11 PM   #66
msile
msile's Avatar
Drives: ISF
Excellent work!!
1993 MR2 Turbo - Red
1996 Supra Turbo - White
2011 ISF - Mercury Metallic / Black Suede
2013 Scion FR-S - Firestorm Red
2014 Lexus GS F-Sport - White / 2015 Lexus RCF - Blue (Nov Delivery)
msile is offline   Reply With Quote
Old 09-08-2012, 05:21 PM   #67
WiKKiD
WiKKiD Large Penis
WiKKiD's Avatar
Drives: 2001 Audi TT Quattro "BT 300+Whp"
Awesome great job
WiKKiD is offline   Reply With Quote
Old 09-08-2012, 08:20 PM   #68
Foobar
SLO NO MO
Foobar's Avatar
Just tested the pin 17 bypass with DivX video on demand - I started the video while I was parked, then I started moving. The video cut out, sound remained on. I flipped my toggle switch and the video was once again available. Note that I also grounded pin 15 on the 16-pin harness to bypass the e-brake.
The Following User Says Thank You to Foobar For This Useful Post:
mike18 (11-20-2012)
Old 09-10-2012, 07:51 PM   #69
xcelir8brz
I decided to swap out the switch that I had installed to see if that solved my problem. I cut the old switch out, and wired in a new one. Tomorrow morning on my way to work I'll try this out to see if it solved my problem. Looking at the pictures earlier in the post I did in fact use the ping/green wire and cut and tapped it appropriately. If this switch doesn't work, I'll have to remove the deck, check my soldered connections and reassemble. And if that doesn't work, maybe because I am 6AT instead of manual? Or Radio Version? I'll report back tomorrow my status.
Thanks!
Old 09-10-2012, 08:21 PM   #70
Foobar
SLO NO MO
Foobar's Avatar
Those of you who installed toggle switches on the VSS wire, I'm curious as to where you put your switch - mine's on the panel right next to the interior light dimmer/HID level knobs. There was a blank spot to the right of those two, not sure what Subaru/Toyota had planned for that spot, but it was a perfect spot for my speed sensor toggle switch. If I ever need to go back to stock, I can just swap that one little panel out.
DIY Nav unit in FRS with e-brake bypass and iPhone cable by cupholders Nitro DIY (Do-It-Yourself) Guides 42 07-02-2016 11:10 AM
Name that spoiler! (SOLVED) WingsofWar FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 70 12-06-2014 01:22 PM
BRZ NAV/DVD bypass Scooby South Electronics | Audio | NAV | Infotainment 88 02-24-2014 03:41 PM
how I solved my gilrfriend's problem with headrest angle alexmotrix Cosmetic Modification (Interior/Exterior/Lighting) 8 08-08-2012 08:00 AM
Drove the 86GT and NC miata back to back on GT5 Hanzo FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 39 01-07-2012 12:56 PM
