#29 | |
Drives: 2013 Hot lava Fr-s, 2007 Mazda 3
Raising the bar one step at a time!
Kansas City FR-S/BRZ Facebook group. https://www.facebook.com/groups/452909128083343/ Hotlava86's Build thread!http://www.ft86club.com/forums/showthread.php?t=14152 |
#30 |
Drives: Forester 2007, BRZ Limited '13
What good is that going to do, if you are under 30K/3yo anyway?
Its a manufacture warranty case and claim, if they have an official fix.
I am busy. Do not disturb. http://youtu.be/I58ZSqwFlWw?hd=1
#31 |
Hook 'em
Glad to see it's at least a known issue and not something they have no idea how to fix. I think many of us knew what we were getting into with first model year purchases, but it still sucks when stuff like this comes up.
#32 |
Drives: MY00 Impreza 2.5RS
I've never had a vehicle towed before, but can't he bend rotors or brake lines clamping the tires like that?
Is that how they normally do it? I use tie down straps similar to that every day and you can put some serious force down with those bad boys. |
#33 |
Web Designer/Programmer
Drives: WRB BRZ Limited (Lemon)
I was able to drive it today the brakes did feel a little weird that might of been me forgetting how firm it is (the loaner car had very mushy brakes) they couldn't find anything wrong with my car, so I picked it up went around the block then back because the CEL came up. Needless to say they gave me a loaner car again and will look further into it. I'll definitely have them double check I wouldn't want to have any brake failures just because Sunnyvale Towing
#34 |
First FR-S
Drives: Whiteout MT FRS
i think because this kind of problem can be repetitive, who know if it doesn't act up every 25k miles. For a lot of folks, 30k miles only means a year of driving. If you have extended warranty to 80k miles you have a much much better chance to claim warranty a few times until it's fixed correctly.
#35 | |
Drives: 6MT Asphalt FR-S
#36 | |
our engines were a combination of two technologies Toyota+Subaru so something was bound to show up :/ sucks that we were the ones affected |
| The Following User Says Thank You to gdi2290 For This Useful Post: | StarsGarrador (08-30-2012) |
#37 |
Look at it this way, this doesn't necessarily point to a bad design, just bad parts. A bad design would result in every car being affected. Recalls/TSBs can affect any number of cars or other products, even those that have been in production for years. Stay optimistic!
#38 | |
Drives: BRZ WRBL6MT
Google "tsb 02-132-12" and it leads right back to ft86club.com and to techinfo.subaru.com/static/whatsNew.html with link to PDF (if you have access to their site): 02-132-12 - Technical Service Bulletin - DTCs Relating to the AVCS (Active Valve Control System) - Aug 21, 2012 - [View PDF] |
| The Following User Says Thank You to avholic For This Useful Post: | gdi2290 (08-29-2012) |
#39 | |
#40 |
Drives: 2020 GMC Canyon Denali Diesel
False, not all....mine is at 4,000+ miles, no CEL...Dave-ROR's is at 8,000+ miles no CEL...matter of fact we've haven't had 1 BRZ or Impreza in for this concern...and we sell quite a few...
And it's not a top engine rebuild, it involves the Oil Control Valves (for the VVT), the Exhaust Cam Sprocket and the ECM. In some cases just the OCV's need to be replaced, in others only the Cam sprockets, and in a few, all of the parts need to be replaced. It can affect Impreza's with the FB20 and all models with the FA20. The TSB only applies if you have had a CEL.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
#41 | |
#42 |
Sorry, your post read like "all" will do this...not that "all" could do this..
| Check engine light just came on after 2k miles. | danthedirt | Issues | Warranty | Recalls / TSB | 604 | 01-31-2015 04:26 PM |
| First Check Engine Light and Traction control | QFry | Issues | Warranty | Recalls / TSB | 26 | 10-04-2014 11:27 PM |
| Engine sputtering while idling with check engine light flashing, WTF | speedy racer | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 08-27-2012 06:50 AM |
| FR-S: Highbeam turns on lowbeam, how to disable? | civicdrivr | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 07-03-2012 07:08 PM |
| Check Engine Light | b.e | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 06-17-2012 09:50 PM |
