Old 08-27-2012, 05:21 PM   #43
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Car has sat for 48 hours with no problems. I should take voltage readings to see what the drop is between sittings... I'll do that tonight and let it sit tomorrow.
Old 08-27-2012, 05:39 PM   #44
xjohnx
Grip>Slip
xjohnx's Avatar
:brohug:
thanks, buddy.
Old 08-27-2012, 05:51 PM   #45
travace
travace's Avatar
Drives: Scion FR-S
ohh thats hella nice. way better then messing around with a gopro IMO
travace is offline   Reply With Quote
Old 08-27-2012, 06:43 PM   #46
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Originally Posted by xjohnx View Post
still no battery issues with it wired to constant? What's the longest you leave the car sitting without driving?
After about a week in my CL the battery was dead.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 08-27-2012, 07:12 PM   #47
squat12
Drives: 2013 BRZ, 1967 corvette conv
Not to pee in anyone's Wheaties here, but I was kinda hyped to get this device for my car, then I started reading the following thread:
http://forums.redflagdeals.com/merge...ad-1147913/24/
... as you can see, it goes for (currently) 74 pages. The executive summary is that it seems that the Blackvue has a fairly noticeable overheating problem, which appears to be exacerbated by leaving it in "park monitor" (or whatever it's called) mode, which is one of the big things I wanted to use it for to begin with.
squat12 is offline   Reply With Quote
Old 08-28-2012, 07:36 AM   #48
xjohnx
Grip>Slip
xjohnx's Avatar
Actually, I forgot that I went ahead and ordered the Power Magic power controller when I ordered the camera. That should be here today.
If I install the power controller to the same constant hot wire that you wired directly to the camera (Positive to the GRN/YEL, Ground to the BLK/YEL), I should be golden, right?
Old 08-28-2012, 08:06 AM   #49
BRZranger
A problem with this device is that it's a clearly visible electronic device to outside bystanders.
I don't like leaving obviously expensive items in plain view inside of any of my cars, reason being to prevent a potential car prowl.
This would be better IMO if the camera was more hidden. Not sure if a concealable blackvue-type camera exists...
BRZranger is offline   Reply With Quote
Old 08-28-2012, 09:51 AM   #50
Hix
Hix's Avatar
Drives: 2017 WRB PP
They do they are just of poor quality. The blackvue (from my observations of these cams) seems to be very stealthy. Most have large 3-4 piece suction cup clips to hold the camera. The Blackvue has a small round cup that 3m's to the windshield and then the camera locks in to the holster. If you are worried about theft you could remove the camera when parked, but honestly most people will think it is part of the mirror or possibly an anti-theft device.
Hix is offline   Reply With Quote
Old 08-28-2012, 08:20 PM   #51
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Originally Posted by F1point4 View Post
When I get the add a circuits from the courier, I will do a DIY writeup for this camera and the power magic pro tapped into the fuse box.
Should be a jolly good time.
Add a circuits came in. Detailed writeup with power magic pro to come Friday.
Good day.
F1point4
F1point4 is offline   Reply With Quote
Old 08-29-2012, 04:09 PM   #52
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Good day.
F1point4
Looking forward to it!
Old 08-29-2012, 04:32 PM   #53
cgrey
Drives: 2013 Argento Silver FR-S
Good day.
F1point4
I used STOP and DRL for Constant and Switched, and the fuse box mounting screw grounds just fine.
cgrey is offline   Reply With Quote
Old 08-29-2012, 09:11 PM   #54
F1point4
Photo Specialist
F1point4's Avatar
Thanks, I'll keep this in mind and verify with a multimeter.
Old 08-31-2012, 06:02 PM   #55
F1point4
Photo Specialist
F1point4's Avatar
Camera install is done. DIY is coming.
Old 09-04-2012, 04:47 PM   #56
BRZranger
I just ordered the blackvue and power magic pro, but mine is the "Session 2" version, which supposedly addresses the overheating problem.
BRZ/FR-S Coilover Installation Guide GrimmSpeed DIY (Do-It-Yourself) Guides 64 02-21-2020 05:30 PM
Suspension Installation Warning!!!! Don@Accelerated Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 07-20-2012 06:44 PM
Trade my black dash plastic for your silver dash plastic thread. F3dzo Southeast 0 07-17-2012 10:06 PM
TRD parts installation manual Nardi330 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 05-21-2012 03:19 AM
chrome fender trim installation taosracer Cosmetic Modification (Interior/Exterior/Lighting) 1 05-15-2012 03:13 PM
