Old 08-22-2012, 01:22 PM   #15
Racecomp Engineering
Koni will probably only be inserts.
We'll have our own custom valved Bilsteins eventually....it takes a while.
Just so no one thinks I'm biased, I run Koni yellows on my own personal car (Mini) and love them. Both will be great options.
KYB and Tokico will probably eventually have an option too but again this is something that takes a lot more time than coilovers because tooling is quite a bit more complicated. And that's probably why Koni does inserts for struts. Hopefully I'm wrong and some good options come out soon.
- Andrew
Old 08-22-2012, 01:26 PM   #16
jamal
jamal's Avatar
Drives: Legacy GT
You'll only have to cut apart the front for Konis at least. In the rear it will be a full replacement shock.
jamal is offline   Reply With Quote
Old 08-22-2012, 07:59 PM   #17
GC_Adam
GC_Adam's Avatar
Drives: '08 Impreza, 03 SV1000S
Originally Posted by simpleisbest View Post
I heard the first release of the Koni's may be inserts....
You have a "sealed strut" front damper not an insert style. All damper manufacturers would have to make a stock style replacement strut for car.
GC_Adam is offline   Reply With Quote
Old 08-22-2012, 08:29 PM   #18
simpleisbest
Senior Citizen
Drives: Scion FR-S
?? I think Koni inserts would require "breaking" that seal with a pipe cutter for install, plus drilling a hole at the bottom to lock them in place. I guess not all manufacturers definition of "applicable products" are the same! LOL!
simpleisbest is offline   Reply With Quote
Old 08-22-2012, 08:51 PM   #19
xwd
That's why you drill a hole in the bottom to release the fluid and pressure. Then hack off the top of the strut and pull out the guts. The Koni insert happens to fit inside the old body.
Old 08-23-2012, 01:45 PM   #20
Synack
Boosted
Synack's Avatar
Drives: Sideways
We make a lowering camber plate...lowers the car an extra 3/8th of an inch up front without sacrificing bump travel. Not cheap, but a high quality and unique part.
- Andrew
Where?!?!? Anything for rear?
If I combined this with Eibach Sportlines I could probably achieve an even flush with my wheels.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 08-23-2012, 03:28 PM   #21
We need to update our site with more BRZ parts...stay tuned.
- Andrew
Old 08-24-2012, 09:29 AM   #22
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
- Andrew
Interesting...assuming with these you get lower ride height without compromising shock travel. Am I right?
Planning on doing rear mounts to match as well?
Curious how these would work with RCE Yellows (if they'd be compatible).
Any thoughts on whether the roll centers might begin to go out of whack with the additional drop?
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 08-24-2012, 03:55 PM   #23
Exactly, you get additional drop without using up bump travel. It still does alter geometry, so with the Yellows it is recommended to use the Whiteline roll center kit as well. Not "required" but recommended.
Rear mounts are under consideration.
- Andrew
Old 08-24-2012, 04:04 PM   #24
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Originally Posted by Turbowned View Post
Aww muffin, you have to pull apart your strut housings? Tough cookies! Us MR2 guys don't have any other option besides coilovers. I did it and survived, and Koni makes a great product!
Seriously! I had koni inserts on my 02 wrx, they were awesome. I would definitely do that again.
industrial is offline   Reply With Quote
Old 08-24-2012, 06:23 PM   #25
Synack
Boosted
Synack's Avatar
Drives: Sideways
- Andrew
To drop the rear a little more as well?
Old 08-25-2012, 02:52 AM   #26
CyberFormula
CyberFormula's Avatar
Drives: gti, nsx, integra type r,porsche911
anybody gonna go KW V3 ....
and call it a day?
CyberFormula is offline   Reply With Quote
Old 08-27-2012, 02:13 PM   #27
colHolm
Default User Title
colHolm's Avatar
- Andrew
When and how much??
colHolm is offline   Reply With Quote
AST Dampers just arrived! Matt Andrews Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 09-20-2012 03:11 PM
OE Replacement Dampers Sccabrz192 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-08-2012 11:52 AM
