#29 | |
Drives: Monkey-butt red FR-S
Of course, local groups can grant exceptions if they want. Locally, we are talking about letting a 1st generation Boxer run in STR eventhough nationally it can't. |
#30 | |
Drives: 2021 Supra / 2022 Tundra
![]() According to the Subaru website, a BRZ premium has the Limited wing as an line option. Putting it on the FRS of course isn't as grey but I would do it and make fun of anyone saying I did it to make the car faster.
TomR
#31 |
Drives: Some rust bucket
It may not be legal, but doubt anyone would protest the wing.
#32 | |
Drives: 2024 GR86/ 2015 FRS
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts |
#33 | |
Simmons
#34 | |
I ran the car with not quite the light on with no issue but low grip from the stock tires. If its like the WRX, we might be able to run well into the light being on.
TomR
#35 |
I have only heard of Phil at Element Tuning having a fuel starvation issue but that was on a road course using like 285 Hoosier slicks... I really don't think it will be an issue running the car with less than 1/8th of a tank.
Interesting on the rear camber differences. I'm at around -1.2 in the left and -1.3 in the right with regards to rear camber, I don't remember how much gas I had at the time. -.5 and .-9 seems pretty low. The car really changes camber based on height but you figure maybe 60lbs for gas, I'm not sure about it making that big of a difference. |
#36 |
Drives: BRZ(sold), STI
#37 |
It's a port installed option which isn't legal to add to a Premium car. So you would have to turn the Premium into a Limited to legally use it.
#38 |
Subaru has the weird situation where the port options are their factory options installer as you probably know. So many port options are stock legal and listed partially in the rule book. For a WRX things like the port installed short shifter, boost gauge, etc are legal in stock explicitly. You could go and get an SEB clarification on it but again since its no performance advantage, I'd be willing to take my chances.
TomR
#39 |
We've started out with the light on, taken 16 runs on concrete on Dunlops with no fuel-starve issues, and still only been able to put 12 gallons or so into the tank afterward.
#40 |
Drives: ND2, formerly BRZ (MT/CBS)
All my info is over in the other stock class discussion
(http://www.ft86club.com/forums/showthread.php?t=6319) but to address some items here:I've run 225 AD08's for well over 100 runs (flipped at 115), usually with a co-driver, including some pretty hot days (only felt the need to borrow a sprayer once) with no problems. --- FWIW, my BRZ premium weighed 2,650 on the scales at the Dover SuperShootout. I didn't bother recording corner weights because the setup wasn't perfectly level. That was just finished running - no trunk/interior junk, fuel light just on, 15.5 lb wheels, otherwise completely stock. --- We've run 8+ runs with the fuel light on and not had any problems on AD08's on fairly level lots - however, it has never taken more than 11.X gal. to fill it afterward. --- DWX - please keep us posted on your A6 experience - I'm curious how the life expectancy will turn out! |
#41 |
Quick stock class rules question. I would like to install a water temp gauge and have one of those radiator hose adapters, would that be considered legal? I'm guessing yes but you never know since it requires hacking up a radiator hose.
#42 |
AutoX-10/10ths every run
| 2012 BRZ/FR-S Stock Class Autocross Discussion | EMguy | Tracking / Autocross / HPDE / Drifting | 183 | 01-04-2013 03:17 AM |
| What SCCA autocross class will the FRS be most competitive | SVThis | Tracking / Autocross / HPDE / Drifting | 5 | 07-30-2012 04:29 PM |
| Share/discuss (this mornin) 86 Newsletter... | RebootWindows | AUSTRALIA | 6 | 07-19-2012 04:15 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 10:03 AM |
| Discuss.... | carbonBLUE | Off-Topic Lounge [WARNING: NO POLITICS] | 12 | 02-11-2012 12:55 PM |
