#4943 | |
Kuruma Otaku
Because titanium. |
#4944 |
Drives: '06 AM V8V Coupe
Actually now that I think of it, with Prius cams and Prius pistons, I need to mill the head to 14:1 compression ratio to reap the benefits of high octane fuel...f*** is that even possible? Okay I guess the cams can't be too crazy then.
#4945 |
Now w/ over 400 womprats!
Drives: BRZ LZR
I have been using Backtrack Linux for a long time for its various hacking tools, and I love it! I run OSX daily though and just boot to a Linux partition to use it! Good stuff!
- The Ancient BRZ Sacrament by Zaku |
#4946 | |
Drives: N/A
Milling the head is not a good idea on an interference DOHC, most SOHC and OHV are fine for milling so long as there is enough clearance. The reason being that DOHC have tighter clearances between pistons and valves so pistons or heads with a smaller combustion chamber are the only ways to raise the SCR without the valves impacting pistons. Unless you're running the serious fuel(E85), maintaining MBT is going to be more important with MPFI. I'm curious why you're looking to run atkinson/miller. A good economy cam/tune is going to be much simpler and it'll get close to the same efficiency while making more power or less weight vs atkinson or miller cycle, respectively. |
#4947 | |
The reason for Miller cycle is because Eaton TVS chargers have peak efficiency at a much higher pressure ratio than the 5th gen chargers, which were much better in the 1.2-1.4 range. The TVS chargers hit peak efficiency at 1.6-1.8, so I'm trying to find an excuse to use that extra boost. Miller cycle bleeds off the boost while increasing efficiency Not terribly concerned with "partial boost" losses, I calculated them to be no more than typical highway cruising throttle losses. In 'Murica they don't sell anything smaller than 1.5L anyways.E85 would be great to do once the engine is actually in the car lol. How feasible is dry sump btw? Can't you just grab a scavenge pump (any old oil pump?), get an external oil tank, and hook things up? |
#4948 | |
Drives: N/A
And there are <1.5L engines, just got to know where to look. The Suzuki Swift AKA the Geo Metro had an aluminum 1.0L 3 banger with TBI and a 1.334L with MPFI until '99-'01 or so when it was discontinued. I found out that the Samurai shared a bellhousing too so that meant a factory RWD transmissions. Honda has the L15, as you well know, it's just Toyota hasn't had a sub <1.5L engine in a while. You could look at a Second gen Prius engine. Those were 1.5L and should bolt right up to the Toyota Echo or even the Yaris gearbox.
#4949 | |
The thing about bolting a Prius engine in is the ECU has all the eCVT functionality integrated into it (I think?). I don't think it would work with a manual transmission. The Prius engine also has weakened rods for mass reduction. I think it would be better to pull everything out of a Yaris and then swap in the pistons and cams. Actually, stealing the cooled EGR off a newer Prius wouldn't be too bad either Since the pistons and cams are coming out, it wouldn't hurt to have the reciprocating assembly balanced, and pistons ceramic coated.
#4950 |
Resident HoneyBadger
Drives: Toyota Tacoma TRD Off-Road
So this is whats planned for lunch:
![]() Walk like a King, Be like a Sir, Swag it out like a Boss |
| The Following 2 Users Say Thank You to S2kphile For This Useful Post: | Allch Chcar (08-24-2012), Snoopyalien24 (08-24-2012) |
#4951 | |
Mr. Sarcasm
Hey man, I haven't forgotten about your request, I just haven't been home lately with mt PS machine. It's on my 1st thing to-do list as soon as I make it up on there.
| The Following User Says Thank You to Snoopyalien24 For This Useful Post: | Guff (08-24-2012) |
#4952 |
Drives: WRB BRZ '13
| The Following 2 Users Say Thank You to JDM-dono For This Useful Post: | raz0rbladez909 (08-24-2012), S2kphile (08-25-2012) |
#4953 |
I'm here for the beer
Drives: 2013 Scion FRS, 1971 Datsun 240z
Car just came out and people are hot and heavy on the knockoff wheels already. *Sigh* What's the rush?
#4954 |
Mr. Sarcasm
#4955 |
Drives: BRZ LZR
No problemo, buddy! Anticipation builds satisfaction!
| The Following User Says Thank You to Guff For This Useful Post: | Snoopyalien24 (08-24-2012) |
#4956 |
USMC Veteran Semper Fi
Drives: 2010 WR Blue STi
I wish they had good Ramen here.
| h6 swapouts? any thoughts or advice? | f1ver | BRZ First-Gen (2012+) — General Topics | 53 | 11-21-2014 11:46 PM |
| Aspera's thoughts on AWD/RWD... | aspera | Scion FR-S / Toyota 86 GT86 General Forum | 89 | 11-16-2013 02:55 PM |
| random casual discussion on dynamic brakes | serialk11r | Other Vehicles & General Automotive Discussions | 4 | 07-16-2012 09:34 PM |
| The "if you wanna kiss the backside of white musicians make a thread about it" Thread | aliphian | Off-Topic Lounge [WARNING: NO POLITICS] | 8 | 12-19-2011 07:59 PM |
