Old 08-23-2012, 10:28 AM   #183
rusty959
Drives: DGM BRZ limited
Originally Posted by bambbrose View Post
Now build a canbus monitoring device for the whole car (my route), and add this functionality in as a standard feature, then it would make sense.
I'm working on a canbus monitor with display for these cars. People are gonna be needing boost gauges, oil temp, etc. and why not just put it in the cluster on an LCD right
Makes sense.
If you need any help testing etc that, let me know.
rusty959 is offline   Reply With Quote
Old 08-23-2012, 12:51 PM   #184
arghx7
Drives: car
You will have to reverse engineer the CAN signals and then generate them to command the various modules.
The preferred tool for reading CAN signals is Vector CANalyzer. It costs a lot of money.
Old 08-23-2012, 04:03 PM   #185
E92M3Guy
Drives: BMW E92 M3
This would be difficult but may be possible.
From what I know about the CANbus network, the remote lock fob will send a signal that is processed by the remote module ECU. This ECU acts as one node with it's own node ID.
It will then send out the "lock" PID packet on the CANbus network to the lock ECU Node, which locks the door.
To make a module, you would have to build a custom Node PCB, which was programmed to watch for the "lock" PID from the remote module ECU, and then it would have to send out the "windows up" PID to the windows Node.
Quite a difficult proposition, although very possible. It would require someone with PID knowledge and a test car.
What would people really pay for this new ECU node as well? The cheapest ones would cost $50+ to manufacture, and that doesn't include all the software and testing, wiring harness, packaging, shipping, and marketing.
It's actually very easy in my opinion. These exact type of modules have existed for BMW's for many years. Windows up on lock; mirrors fold in on lock; vert up on lock, etc. I have a programmable CAN node at home, I could probably write the software for this in an afternoon...just no interest however. But suffice to say, this is probably a very easy thing to do.
E92M3Guy is offline   Reply With Quote
Old 08-23-2012, 08:20 PM   #186
arghx7
Drives: car
I can tell you right now that these types of commands are among the easiest to figure out if you have means to listen along the bus as you activate the windows or lock.
More complicated signals, such as steering angle and yaw rate, are harder to figure out.
Old 08-23-2012, 09:35 PM   #187
xjohnx
Grip>Slip
xjohnx's Avatar
I'd love something like that, but maybe i'm alone.
Old 08-28-2012, 01:45 PM   #188
Deepseadiver
Drives: 2013 BRZ DMG manual Limited
Keep up the hard work! Thanks again!
I'm still working on all the OEM PIDs for the gauge cluster.
Got my test rig running tonight, now I can start sending the packets that I think I've got deciphered and verify that they do what I expect.
Deepseadiver is offline   Reply With Quote
Old 08-28-2012, 02:55 PM   #189
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
You are NOT alone, I am interested too. In the window roll up and down, and in the locks locking after X amount of mph and unlocking on ignition off or something like that.
I'm very interested
Old 08-28-2012, 03:50 PM   #190
Visconti
Drives: 05 STi
Taking about power windows
Anyone every notice that the passenger auto down button on the drivers side door does not work the first time you press it..
Pisses me off
Visconti is offline   Reply With Quote
Old 08-28-2012, 03:54 PM   #191
xjohnx
Grip>Slip
xjohnx's Avatar
Pisses me off
Yeah, there's an art to it. I'm getting better at my first push success rate.
Old 08-28-2012, 09:29 PM   #192
xjohnx
Grip>Slip
xjohnx's Avatar
I'm very interested
the other small item on my wish list was for the radio to keep playing after the motor is turned off, until a door is opened.
Sportsguy83 (08-28-2012)
Old 08-28-2012, 09:41 PM   #193
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Pisses me off
I share your hatred of that button. It's absolutely horrible.
FT-86 SpeedFactory is offline   Reply With Quote
Old 10-04-2012, 10:33 PM   #194
Yruyur
Yruyur's Avatar
Any update on the PID's. Very interested in seeing more data the bus passes. Bet if we knew the PID for the door locks then Visconti could add it to his tune so the doors lock once the car hits a certain speed.
Old 10-04-2012, 10:49 PM   #195
EN2_Squirrel
EN2_Squirrel's Avatar
Pisses me off
yes i just double tap.
EN2_Squirrel is offline   Reply With Quote
Old 10-04-2012, 10:56 PM   #196
D-VO
Drives: Whiteout FR-S, Evo 8 RS
Is there anyone on this forum working on ECUFlash for FR-S/BR-Z?
D-VO is offline   Reply With Quote
Great dealership in NE Ohio.. (still has multiple pre-order slots open) eikond BRZ First-Gen (2012+) — General Topics 15 03-02-2012 01:03 PM
Open Air FR-S Concept Rampant FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 22 02-01-2012 11:01 PM
Open Deck Block nrclptcnsmniak Engine, Exhaust, Transmission 36 01-27-2012 01:00 PM
Keep your eyes/cameras open in SoCal? Buggy51 Scion FR-S / Toyota 86 GT86 General Forum 14 10-10-2011 10:21 PM
