Old 08-23-2012, 11:14 AM   #15
Ashley
Drives: White Scion FR-S
I guess i need to pull out the manual n read it huh lol
Ashley is offline   Reply With Quote
Old 08-23-2012, 11:22 AM   #16
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
it's good to know, there isn't anything in particular that is special to this car from my perspective - its like any other car ..
but there are some funny lines in it .. ie. do not use jack to jack car :]
Originally Posted by DetroitJake View Post
See page 125 of the Owners Manual:
New Vehicle break-in driving (the first 1000 miles [1600km])
The performance and long life of your vehicle are dependent on how you handle and care for your vehicle while it is new. Follow these instructions during the first 1000 miles (1600 km):
  • Do not allow the engine to exceed 4000 rpm except in an emergency.
  • Do not drive at one constant engine or vehicle speed for a long time, either fast or slow.
  • Avoid starting suddenly and rapid acceleration, except in an emergency.
  • Avoid hard breaking, except in an emergency.
The same break-in procedures should be applied to an overhauled engine, newly mounted engine or when brake pads or brake linings are replaced with new ones.
Old 08-23-2012, 12:29 PM   #17
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
You need to fully compress the clutch, then just let it fall into first, like take your time after you depress the clutch then put it into first. I've noticed that if I clutch, then wait a second or two, it will just gracefully fall into first. If I clutch then try to ram it into first it clunks pretty bad.
post_break is offline   Reply With Quote
Old 08-23-2012, 01:18 PM   #18
JSK
Drives: FRS Asphalt
Originally Posted by Bonburner View Post
you can go up to 4k rpm for break in period according to the manual.
under 'emergency situations' above that
I guess I had a lot of "emergency situations" while I was breaking mine in
JSK is offline   Reply With Quote
The Following 2 Users Say Thank You to JSK For This Useful Post:
636 (08-23-2012), Bonburner (08-23-2012)
Old 08-23-2012, 01:34 PM   #19
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
There we're indeed a lot of life threatening situations my friend
Old 08-23-2012, 02:07 PM   #20
636
636's Avatar
Drives: '23 CWP BRZ
I'm in the same boat, I'm not too worried. I used to drive an STi and it did the same things, must just be Subarus!
636 is offline   Reply With Quote
Old 08-23-2012, 02:17 PM   #21
Ashley
Yea i guess i wont worry i figured its cause its a new car n all. So ur not suppose to drive for long periods of time w new car? Ive been driving around everywhere showing everyone my car n i have a ways to work not much i can do there. All i can say is i love this car!!!!
Old 11-14-2021, 04:00 PM   #22
600miles
Drives: 2017 86
9 years gone by
Is it too late to respond? lol My 2017 clunks when I fully depress the clutch at a stand still in neutral before I shift in to first gear. 65,000 miles car.
600miles is offline   Reply With Quote
Old 11-14-2021, 10:30 PM   #23
Wait for the friction disc along with all the gears to quit spinning before engaging one of them. That's all.
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 10:01 AM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
Clutch billysangi BRZ First-Gen (2012+) — General Topics 10 06-15-2012 02:29 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 03:48 PM
