#71 | |
Drives: DGM BRZ Limited
Or don't use the TGVs as ITBs, but rather use ITBs to generate tumble like the TGVs do in the first place. That's all I'm saying. There are a lot of different ways to tumble the air, or change intake velocity. |
#72 | |
Drives: '06 AM V8V Coupe
#73 |
Kuruma Otaku
TGVs are irrelevant flow restrictions in a D4-S system. Turbo conventional DI (Subaru's version for the Legacy and ?) needs tumble. D4-S spray patterns vastly reduce the need for low rpm charge motion to produce good mixture/combustion.
So a high flow/rpm head on this should still have acceptable lower rpm response, appropriately tuned.
Because titanium. |
#74 | |
I get what you're saying, but the FA20 has an inefficiency region that may take unconventional methods to solve. It would be nice if we could keep it simple. Perhaps a dual runner intake would be a better option. Run one set of runners with the wall built into it, with the shorter runners without wall or restriction for the top end. Low end combustion on the FA20 is good. Mid range is where there is an issue. You do bring up a good point about cost. The engineers for this engine are going to have to make the accountants happy too. Which begs the question, why add anything at all? You don't NEED the TGVs to solve the torque dip. After all, there's lots of cars out there with no torque dip and no TGVs. Right? ITBs would be cool, but they aren't likely to happen on production engines in this price range. I'll guarantee that. Perhaps all this engine needs is a better intake manifold design. |
#75 | |
Currently, low speed combustion is okay because there is the D4-S system, and because the ports are designed to make it work. Low load the direct injectors do their stratified charge thing, high load port injectors supply some fuel because the DI can't mix the fuel well alone. Subaru wants to ditch this setup but keep direct injection, which is why they are bringing TGVs in. Direct injection requires high tumble flow to work, but a high tumble port restricts airflow. The TGV allows good top end power when open, good low end charge motion when closed. @Dimman, arghx7 said the ports on this are not what you'd call high flow ports. He said D4-S just allows you to strike a better compromise than the usual high tumble port + DI combo. Remember that the direct injectors are providing all the fuel below some load level. |
| The Following User Says Thank You to serialk11r For This Useful Post: | Coheed (08-23-2012) |
#76 |
Oh ok, got what you're saying. I didn't know they were deleting the port injectors next year. I figured they were adding the TGV to alleviate the torque dip issue.
#77 |
I don't remember what those pictures and stuff actually were, and I don't know if that's actually the plan for next year, but it seems like a plausible route for them to take. I think the original thread it appeared on said something along the lines of "these are what the plan is for the next FA20" but I don't think it was totally certain. If they do pull this off that would be pretty neat, since it's been a while since anyone's done a "dual intake runner" (not exactly, but it's got a valve and 2 air passageways lol).
#78 | |
Kuruma Otaku
The high flow I mention is for a modded head. The D4-S reduces the need for turbulence/velocity, so the modded head may get a couple thousand rpm more on the lower end of its powerband than what could typically be expected.
Because titanium. |
#79 |
Drives: 2013 Firestorm FR-S
I thought the dual injectors were also to help keep the valves clean as well as for power and efficiency. Subi wants to dump the port injectors completely? Do the direct injectors have the volume capacity to feed the engine across the rev range?
#80 | |
Drives: Mt Fuji Red 86 GT
#81 | |||
Drives: car
Some engines have an upstream throttle before the plenum and then ITB's right at the intake port, like the Lexus LFA engine. Quote:
Nobody has addressed my point about the lack of variable valve lift. On Celica 2ZZ or basically any Honda engine, you have more than one lift profile. That allows you to have some semblence of low speed torque. If you can succeed in going with a very aggressive camshaft design you will lose a lot of your low-end torque on this engine. |
#82 |
Drives: car
The valve deposit thing is simply a welcome side effect of the dual injection. The main value in dual injection is to help with some of the compromises you have to make when designing a direct injection combustion system. The port injectors are also much better for particular emissions, and particulate emissions standards are about to start tightening... you may be seeing particulate filters on gasoline engines in a few years.
#83 | |||
Señor Member
I hadn't thought about the feedback loop that ETB must run. It certainly kills my idea of splicing the signal. Quote:
If you are worried about low end torque then keeping the FA20 NA probably isn't for you.
1974 TA22 Celica
2013 86 GT |
#84 |
Engineer
Drives: WRB 2022 Subaru Brz
Our cars has some potential
[ame="http://www.youtube.com/watch?v=OutWSkfaNEQ"]http://www.youtube.com/watch?v=OutWSkfaNEQ[/ame] |
| The Following User Says Thank You to vignesh For This Useful Post: | fa5tco (10-11-2013) |
| Tags |
| 9000rpm, aspirated, high, naturally, revv |
| Let's see your computer setup! | Hanakuso | Off-Topic Lounge [WARNING: NO POLITICS] | 79 | 11-06-2022 11:43 AM |
| AutoX Parts Setup | NYC BRZ | Tracking / Autocross / HPDE / Drifting | 38 | 08-17-2012 05:42 PM |
| Audio setup | 315FR-S | Electronics | Audio | NAV | Infotainment | 20 | 05-17-2012 06:23 PM |
| 2 car setup...feasible? | mankarn86 | CANADA | 3 | 03-30-2012 02:00 AM |
